Pro Mini crystal change: upload issue
With too many Pro Mini with 8MHz crystal lying around here, I am replacing these crystals with a 16MHz crystal.
All original 8MHz Pro Minis can be uploaded to, showing 30k memory, indicative of the old original Pro Mini bootloader.
Crystal type: CSTCE16M
images
After installing the new crystal, no more uploading is possible. Only after re-installing the old original bootloader (over SPI) can there be new uploads (and 30k program space).
Obviously also the Optiboot bootloader can be installed (using the MiniCore from McDude for example), and the uploads work too (giving 32k of program space).
Why can a 8MHz crystal not be simply replaced by a (same form factor) 16MHz crystal, without having to reinstall the bootloader?
When the microcontroller is running at twice the speed, you need to double the upload baud rate speed. If the 8 MHz bootloader communicates at 57600 baud, it will communicate at 115200 baud when running at 16 MHz.
Thanks!
But isn't the standard 16MHz upload speed not 115200 baud anyway? So, when selecting the 16MHz board definition, the uploader speed is set at 115200 baud, and since the uC is now running at 16MHz, then that shouldn't that correspond?
Not sure about that, but i am pretty sure you need to set the fuses to the corresponding clock frequency regardless, and that gets done when burning the bootlaoder.
I checked the required fuse settings for the 328P: there is no separate option for 8MHz versus 16MHz:
fuse calculator
I'm curious. What application or project do you have where 16MHz is fast enough but 8Mhz is too slow?
And are you also changing out the 3.3V regulators for 5V? The atmega328 is not rated to run at 16MHz at 3.3V.
If you are in doubt, why not take a look at the boards.txt file for the AVRs ?
Indeed it is not.
And it would have been odd for an 8Mhz Pro Mini to have been fitted with a 5V regulator, I dont recall seeing any ...........................
@PaulRB
That is an interesting observation. But as can be seen from the added Pro Mini schematic, Vcc goes directly to the Vcc µC pins 18, 4 and 6.
And since I use the Pro Mini PCB pin that is connected to Vcc, 5V is directly sent to the controller Vcc pins, bypassing the regulator (which is only used when the PCB RAW pin is used).
But my initial question about the crystal change issue remains unanswered?
Arduino Pro Mini Schematic.pdf (59.1 KB)
@srnet
If the Pro Mini board type with 5V 16MHz is used, then of course the upload speed will be 115200. Yet this corresponds with the actual processor running at 16MHz.
And yet uploading after the crystal change only seems to work after reloading the bootloader. Why?
which shows quite clearly for both 5v & 3.3v
## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328P
pro.menu.cpu.16MHzatmega328=ATmega328P (5V, 16 MHz)
pro.menu.cpu.16MHzatmega328.upload.maximum_size=30720
pro.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048
pro.menu.cpu.16MHzatmega328.upload.speed=57600
pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0xFD
pro.menu.cpu.16MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
pro.menu.cpu.16MHzatmega328.build.mcu=atmega328p
pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328P
pro.menu.cpu.8MHzatmega328=ATmega328P (3.3V, 8 MHz)
pro.menu.cpu.8MHzatmega328.upload.maximum_size=30720
pro.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
pro.menu.cpu.8MHzatmega328.upload.speed=57600
pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0xFD
pro.menu.cpu.8MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
pro.menu.cpu.8MHzatmega328.build.mcu=atmega328p
pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
the same upload speed as far as the IDE is concerned, but with a different crystal, the settings would therefore not be correct anymore as was stated already in reply #2 This is the basic issue that you want to solve and for that you need to burn the bootloader again, which includes the calculation for the baud-rate depending on the Clock-speed.
Eh yeah, but you are applying 5v on the 3.3v regulators Vout, and there is a good chance it doesn't deal with that gracefully. Then again you will never use it again, but i do suggest to remove it just in case.
Well if uploading works, presumably when you reload the bootloader (for a 16Mhz board), the uploader sets the correct baud rate ?
@Deva_Rishi
That is clear; same upload speeds in boards definitions for both 8MHz as for 16Mhz.... hence a crystal twice as fast would expect to see an effective upload speed x2. Which it is not...
I had overlooked that in the actual board definitions, thanks!
Indeed, not healthy for that voltage controller. But I never use that anyway. Removing the voltage regulator? ..should better be done, agreed.
I like to know why things do not work, or why a solution doés work :wink:
Mine too.
Now that mine is answered I will answer yours :grinning:
A supply of standard 16MHz Pro Mini's saves me the hassle of checking frequencies and continually adjusting the board selection.
As an experiment you could create a sketch the shows F_CPU (and maybe some other things like baud-rate register settings) on the Serial monitor (at 9600) as well. Upload it with the 8Mhz Crystal still on there, change the Crystal and set the monitor to 19200 and view the result.
F_CPU is a Macro which is defined within the binary.
The Baud-rate registers for an upload are set in the bootloader.
The registers are then set again in the binary.
@Deva_Rishi
Good idea! Will do..
Even modifying the Boards.txt to create an extra option for a board with 115200 as an upload speed might work, but i guess it might not be practical.
@Deva_Rishi
Interesting. Yet I had been under the assumption all along that the boards.txt for 16MHz would be at 115200 upload speed. It is the case in the McDude MiniCore boards.txt...
So why is it different in the original Arduino Pro Mini boards.txt (ie 57600) for 16MHz?
