Proble with code
Hello.
I'm new in arduino world and i need some help.
So, when i have 2 loop on same time 1st one have delay, if i have only the 1st loop all things are fine.
there is my code, where i'm wrong?
#include <AFMotor.h>
#include <Servo.h>
//defining pins and variables
#define left A0
#define right A1
//defining motors
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
Servo myservo;
int i = 0;
    myservo.attach(10);
  pinMode(left,INPUT);
  pinMode(right,INPUT);
void loop1(){
  Serial.println(digitalRead(left));
  Serial.println(digitalRead(right));
  if(digitalRead(left)==0 && digitalRead(right)==0){
    motor1.run(FORWARD);
    motor1.setSpeed(100);
    motor2.run(FORWARD);
    motor2.setSpeed(100);
    motor3.run(FORWARD);
    motor3.setSpeed(100);
    motor4.run(FORWARD);
    motor4.setSpeed(100);
  else if(digitalRead(left)==0 && digitalRead(right)==1){
    //turn left
    motor1.run(BACKWARD);
    motor1.setSpeed(150);
    motor2.setSpeed(150);
    motor3.setSpeed(150);
    motor4.run(BACKWARD);
    motor4.setSpeed(150);
  else if(digitalRead(left)==1 && digitalRead(right)==0){
    //turn right
    motor2.run(BACKWARD);
    motor3.run(BACKWARD);
  //line detected by none
  else if(digitalRead(left)==1 && digitalRead(right)==1){
    //stop
    motor1.run(RELEASE);
    motor1.setSpeed(0);
    motor2.run(RELEASE);
    motor2.setSpeed(0);
    motor3.run(RELEASE);
    motor3.setSpeed(0);
    motor4.run(RELEASE);
    motor4.setSpeed(0);
void loop2(){
      for (i = 45; i <= 140; i= i+1) {
    // in steps of 1 degree
    myservo.write(i);
    delay(15);
  for (i = 140; i >= 45; i =  i- 1) {
    myservo.write(i);
   delay(15);
void loop(){
  loop1();
  loop2();
Welcome to the forum
You have about 200 delay()s of 15 milliseconds each in loop2() during which time loop1() will not run
Your procedures are blocking. When one works, the other is waiting.
Controller can't do more than one thing in the time.
Your code stays about 3 seconds in the loop2() function, at this time the first loop stops.
You have to rewrite your code in non-blocking style and get rid delays.
Read the BlinkWithoutDelay IDE example
You need to get away from using the blocking delay() and for loops and use blink without delay timing using millis() (or micros()) as suggested by @b707.
Here are some good tutorials on using millis() for timing and doing multiple things at the same time.
Blink without delay().
Beginner's guide to millis().
Several things at a time.
