Problem casting String to Float or double.
Hi, I am programming my Final degree Project using an ESP32.
In this application, I send the information from the laptop in a SLIP frame.
I read this frame, and save the information in Strings, in Hexadecimal.
I want to save and interpret these Bytes as a Float or double. (Usingfloat, I have an OVF whit Serial.println).
Finally I have:
String s1 = "3fa00000"; These four bytes in float are "1,25".
I want:
double d1 = 1,25; And I want to print in Serial port this variable.
I hope your response. Thanks and sorry for my English.
Finally I have:
What "four bytes" are you talking about? There are no bytes anywhere. There is just an instance of the String class which wraps a collection of characters.
Post your code that collects this String. It is extremely likely that you should NOT be using a String AT ALL.
I have a byte Array like this:
byte datosLeidos[TAM_TRAMA];
for (i = 0; i < TAM_TRAMA; i++) {
            datosLeidos[i] = client.read();
datosLeidos[0] = 0xc0; (header)
datosLeidos[1] = 0x3F;
datosLeidos[2] = 0xA0;
datosLeidos[3] = 0x0;
datosLeidos[4] = 0x0;
I parsed and concatenate it into String like "0x3fa00000", but i think it is not neccesary.
I only need to interpret those bytes like this:
Thanks for your answer.
It was a complete waste of time.
Look up what a union is, and see what happens when you union 4 byte array and a float. Assign values to the byte array, and read the float value.
When I use the union, I have an overfload using Serial.println().
pericoj:
You're using the wrong part of the union, possibly? (Assuming you meant "overload" and not "overflowed")
This is the code using an union:
union u_tag {
   byte b[4];
   float dato;
} u;
const char * ssid = "PERICO";
const char * password = "12345678";
// Puerto del servidor
WiFiServer server(80);
WiFiClient client;
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
  delay(50);
   client = server.available(); // listen for incoming clients
  if (client) {
    Serial.println("New Client"); // Se ha conectado un cliente.
   if (client && client.connected()) {
    if (client.available()) {
      //Recibimos datos del Labview.
      while (client.available()) {
        for (int i = 0; i < TAM_TRAMA; i++) {
            Serial.print("datosLeidos[i]:  ");
            Serial.println(datosLeidos[i],HEX);
            delay(50);
      if(datosLeidos[0] == 0xC0)
      Serial.println("");
      Serial.print("Byte 1: ");
      Serial.println(datosLeidos[1]);
      Serial.print("Byte 2: ");
      Serial.println(datosLeidos[2]);
      Serial.print("Byte 3: ");
      Serial.println(datosLeidos[3]);
      Serial.print("Byte 4: ");
      Serial.println(datosLeidos[4]);
      u.b[0]=datosLeidos[1];
      u.b[1]=datosLeidos[2];
      u.b[2]=datosLeidos[3];
      u.b[3]=datosLeidos[4];
      Serial.print("Dato: ");
      Serial.println(u.dato);
After that, dato values is 0.00
This is the exit:
datosLeidos[i]:  C0
datosLeidos[i]:  3F
datosLeidos[i]:  A0
datosLeidos[i]:  0
datosLeidos[i]:  0
datosLeidos[i]:  40
datosLeidos[i]:  A4
datosLeidos[i]:  28
datosLeidos[i]:  F6
datosLeidos[i]:  41
datosLeidos[i]:  32
datosLeidos[i]:  9D
datosLeidos[i]:  E
datosLeidos[i]:  C0
Byte 1: 63
Byte 2: 160
Byte 3: 0
Byte 4: 0
Dato: 0.00
Help please!!
I fix the problem. Thanks a lot.
pericoj:
How?
