Problem connecting IOT Board to computer
Hey, I tried to connect my Arduino board MKR 1010 Wifi using a general code, but it keeps saying COM PORT is busy. I have entered the wifi password and ssid correctly. Thank you guys for helping out!
  WiFi Web Server
 A simple web server that shows the value of the analog input pins.
 This example is written for a network using WPA encryption. For
 WEP or WPA, change the WiFi.begin() call accordingly.
 Circuit:
 * Analog inputs attached to pins A0 through A5 (optional)
 created 13 July 2010
 by dlf (Metodo2 srl)
 modified 31 May 2012
 by Tom Igoe
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;                 // your network key index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  printWifiStatus();
  // listen for incoming clients
  WiFiClient client = server.available();
  if (client) {
    Serial.println("new client");
    // an HTTP request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the HTTP request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard HTTP response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("<br />");
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Here is the error code:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino MKR WiFi 1010"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries D:\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\mdars\AppData\Local\Temp\arduino_build_705424 -warnings=all -build-cache C:\Users\mdars\AppData\Local\Temp\arduino_cache_153773 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.openocd.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -verbose C:\Users\mdars\AppData\Local\Temp\arduino_modified_sketch_293487\WiFiWebServer.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries D:\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\mdars\AppData\Local\Temp\arduino_build_705424 -warnings=all -build-cache C:\Users\mdars\AppData\Local\Temp\arduino_cache_153773 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.openocd.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -verbose C:\Users\mdars\AppData\Local\Temp\arduino_modified_sketch_293487\WiFiWebServer.ino
Using board 'mkrwifi1010' from platform in folder: C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.13
Using core 'arduino' from platform in folder: C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.13
Detecting libraries used...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\sketch\\WiFiWebServer.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\sketch\\WiFiWebServer.ino.cpp" -o nul
Alternatives for WiFiNINA.h: [WiFiNINA@1.8.14]
ResolveLibrary(WiFiNINA.h)
  -> candidates: [WiFiNINA@1.8.14]
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\sketch\\WiFiWebServer.ino.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFi.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiClient.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiSSLClient.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiServer.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiStorage.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiUdp.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\WiFiSocketBuffer.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\nano_rp2040_support.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\server_drv.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\spi_drv.cpp" -o nul
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\wifi_drv.cpp" -o nul
Generating function prototypes...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\sketch\\WiFiWebServer.ino.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\sketch\\WiFiWebServer.ino.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\sketch\\WiFiWebServer.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI\\SPI.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\SPI\\SPI.cpp.o"
Compiling library "WiFiNINA"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiUdp.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiUdp.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiServer.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiServer.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFi.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFi.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiStorage.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiStorage.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiClient.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiClient.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiSSLClient.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiSSLClient.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\WiFiSocketBuffer.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\WiFiSocketBuffer.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\nano_rp2040_support.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\nano_rp2040_support.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\wifi_drv.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\wifi_drv.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\server_drv.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\server_drv.cpp.o"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\utility\\spi_drv.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\spi_drv.cpp.o"
Compiling core...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010\\variant.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\core\\variant.cpp.o"
Using precompiled core: C:\Users\mdars\AppData\Local\Temp\arduino_cache_153773\core\core_arduino_samd_mkrwifi1010_7a73bc5c601d99b39152d267a43b8bdf.a
Linking everything together...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424/WiFiWebServer.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424/WiFiWebServer.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\sketch\\WiFiWebServer.ino.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFi.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiClient.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiSSLClient.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiServer.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiStorage.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\WiFiUdp.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\WiFiSocketBuffer.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\nano_rp2040_support.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\server_drv.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\spi_drv.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\libraries\\WiFiNINA\\utility\\wifi_drv.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424/..\\arduino_cache_153773\\core\\core_arduino_samd_mkrwifi1010_7a73bc5c601d99b39152d267a43b8bdf.a" -Wl,--end-group
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424/WiFiWebServer.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424/WiFiWebServer.ino.bin"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424/WiFiWebServer.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424/WiFiWebServer.ino.hex"
Using library SPI at version 1.0 in folder: C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.13\libraries\SPI
Using library WiFiNINA at version 1.8.14 in folder: D:\libraries\WiFiNINA
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_705424/WiFiWebServer.ino.elf"
Sketch uses 20920 bytes (7%) of program storage space. Maximum is 262144 bytes.
Global variables use 3324 bytes (10%) of dynamic memory, leaving 29444 bytes for local variables. Maximum is 32768 bytes.
Forcing reset using 1200bps open/close on port COM4
processing.app.debug.RunnerException
	at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
	at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
	at processing.app.SketchController.upload(SketchController.java:732)
	at processing.app.SketchController.exportApplet(SketchController.java:703)
	at processing.app.Editor$UploadHandler.run(Editor.java:2061)
	at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM4'.
	at processing.app.Serial.touchForCDCReset(Serial.java:107)
	at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
	... 5 more
Caused by: jssc.SerialPortException: Port name - COM4; Method name - openPort(); Exception type - Port busy.
	at jssc.SerialPort.openPort(SerialPort.java:164)
	at processing.app.Serial.touchForCDCReset(Serial.java:101)
	... 6 more
Error opening serial port 'COM4'. (Port busy)
Your topic has been moved to the section that is more dedicated to upload problems.
Did you manage to upload to that MKR in the past (e.g. blink or other sketches that don't involve WiFi)?
A possible workaround
  1. Double tap the reset button.
  2. In the IDE 1.x, select the port that shows (it will probably contain something with the word "bootloader").
  3. Start the upload of an innocent sketch (e.g. blink).
  4. When the IDE shows you the message Linking everything together... (see your output), double tap the reset button again.
Note:
I don't have your board.
Hello!
As suggested before, first try to upload Blink.ino (from the example) because it's sure this code works.
Did you tried to reboot your computer? It may be just another software that opened this port 'COM4'; and you can't access it from different software at the same time.
You can also try to connect your board to another USB port of your computer
Also as an extra piece of information, the sketch takes way too long to upload, close to 10 minutes.
And I'd also like to clarify what is IDE 1.x
Thank you very much
IDE 1.x is the "old" version of the IDE since now there is IDE 2.x (2.1.1 is the last one).
The last version of the IDE 1.x is 1.8.19
You can found it on the offcial website (you need to scroll down to find the old version of the IDE):
Software | Arduino
Sorry to bother you, but the code is stuck for a very long time on uploading the sketch. Here is what the display shows while uploading. The code being uploaded is the same as above. Thank you.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries D:\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\mdars\AppData\Local\Temp\arduino_build_256578 -warnings=all -build-cache C:\Users\mdars\AppData\Local\Temp\arduino_cache_600747 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.openocd.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -verbose C:\Users\mdars\AppData\Local\Temp\arduino_modified_sketch_110927\WiFiWebServer.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries D:\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\mdars\AppData\Local\Temp\arduino_build_256578 -warnings=all -build-cache C:\Users\mdars\AppData\Local\Temp\arduino_cache_600747 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.openocd.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -verbose C:\Users\mdars\AppData\Local\Temp\arduino_modified_sketch_110927\WiFiWebServer.ino
Using board 'mkrwifi1010' from platform in folder: C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.13
Using core 'arduino' from platform in folder: C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.13
Detecting libraries used...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\sketch\\WiFiWebServer.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\sketch\\WiFiWebServer.ino.cpp" -o nul
Alternatives for WiFiNINA.h: [WiFiNINA@1.8.14]
ResolveLibrary(WiFiNINA.h)
  -> candidates: [WiFiNINA@1.8.14]
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\sketch\\WiFiWebServer.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\hardware\samd\1.8.13\libraries\SPI\SPI.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\WiFi.cpp
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiClient.cpp" -o nul
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\WiFiSSLClient.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\WiFiServer.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\WiFiStorage.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\WiFiUdp.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\utility\WiFiSocketBuffer.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\utility\nano_rp2040_support.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\utility\server_drv.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\utility\spi_drv.cpp
Using cached library dependencies for file: D:\libraries\WiFiNINA\src\utility\wifi_drv.cpp
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\sketch\\WiFiWebServer.ino.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\sketch\\WiFiWebServer.ino.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\sketch\\WiFiWebServer.ino.cpp.o"
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\SPI\SPI.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\WiFiSSLClient.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\WiFiUdp.cpp.o
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\libraries\\SPI" "-ID:\\libraries\\WiFiNINA\\src" "D:\\libraries\\WiFiNINA\\src\\WiFiClient.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\WiFiClient.cpp.o"
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\WiFi.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\WiFiStorage.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\WiFiServer.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\utility\WiFiSocketBuffer.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\utility\nano_rp2040_support.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\utility\server_drv.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\utility\wifi_drv.cpp.o
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\libraries\WiFiNINA\utility\spi_drv.cpp.o
Compiling core...
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_256578\core\variant.cpp.o
Using precompiled core: C:\Users\mdars\AppData\Local\Temp\arduino_cache_600747\core\core_arduino_samd_mkrwifi1010_7a73bc5c601d99b39152d267a43b8bdf.a
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578/WiFiWebServer.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578/WiFiWebServer.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\sketch\\WiFiWebServer.ino.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\WiFi.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\WiFiClient.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\WiFiSSLClient.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\WiFiServer.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\WiFiStorage.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\WiFiUdp.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\utility\\WiFiSocketBuffer.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\utility\\nano_rp2040_support.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\utility\\server_drv.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\utility\\spi_drv.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\libraries\\WiFiNINA\\utility\\wifi_drv.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578/..\\arduino_cache_600747\\core\\core_arduino_samd_mkrwifi1010_7a73bc5c601d99b39152d267a43b8bdf.a" -Wl,--end-group
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578/WiFiWebServer.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578/WiFiWebServer.ino.bin"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578/WiFiWebServer.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578/WiFiWebServer.ino.hex"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_256578/WiFiWebServer.ino.elf"
	... 5 more
	... 6 more
Again, try to upload Blink to see if everything goes well
If not, try to reboot everything (cut the power of your board AND your computer if you can disconnect from the plug)
And when you are uploading, if this is stuck then click rapidly twice on the reset button of the board; you should here the song of windows saying that you unplugged the board and then plugged it again
I tried all of the above, but the board seems to be stuck on uploading. Is there anything I can try to solve it?
Also, does the type of USB cable I use matter? I've connected USB A to micro USB, but I'm not sure if its upload or download type.
There are only two types, charge-inly and data/sync cables. With the first one, your board would not even be recognised by your PC. With the second one, there is no upload/download type; but you might need a good quality cable (no idea what that would be, I use the cables that come (came) with cell phones).
I tried uploading, and the issue seems to be the upload time. No matter how many times I try to reboot, the upload takes an infinitely long time, and resetting the board does not seem to work. When I try to get board info, it reads, "Native serial port, can't obtain info,".
What else can I try?
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries D:\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\mdars\AppData\Local\Temp\arduino_build_367875 -warnings=all -build-cache C:\Users\mdars\AppData\Local\Temp\arduino_cache_17828 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.CMSIS.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.openocd.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose D:\sketch_aug14a\sketch_aug14a.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries D:\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\mdars\AppData\Local\Temp\arduino_build_367875 -warnings=all -build-cache C:\Users\mdars\AppData\Local\Temp\arduino_cache_17828 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.CMSIS.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.openocd.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\mdars\OneDrive - Anglo-Chinese School (Independent)\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose D:\sketch_aug14a\sketch_aug14a.ino
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875\\sketch\\sketch_aug14a.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875\\sketch\\sketch_aug14a.ino.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\cores\\arduino" "-IC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875\\sketch\\sketch_aug14a.ino.cpp" -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875\\sketch\\sketch_aug14a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\mdars\AppData\Local\Temp\arduino_build_367875\core\variant.cpp.o
Using precompiled core: C:\Users\mdars\AppData\Local\Temp\arduino_cache_17828\core\core_arduino_samd_mkrwifi1010_7a73bc5c601d99b39152d267a43b8bdf.a
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\hardware\\samd\\1.8.13\\variants\\mkrwifi1010/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875/sketch_aug14a.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875/sketch_aug14a.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875\\sketch\\sketch_aug14a.ino.cpp.o" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875/..\\arduino_cache_17828\\core\\core_arduino_samd_mkrwifi1010_7a73bc5c601d99b39152d267a43b8bdf.a" -Wl,--end-group
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875/sketch_aug14a.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875/sketch_aug14a.ino.bin"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875/sketch_aug14a.ino.elf" "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875/sketch_aug14a.ino.hex"
"C:\\Users\\mdars\\OneDrive - Anglo-Chinese School (Independent)\\Documents\\ArduinoData\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\mdars\\AppData\\Local\\Temp\\arduino_build_367875/sketch_aug14a.ino.elf"
Sketch uses 12288 bytes (4%) of program storage space. Maximum is 262144 bytes.
Global variables use 2996 bytes (9%) of dynamic memory, leaving 29772 bytes for local variables. Maximum is 32768 bytes.
	... 5 more
	... 6 more
This indicates COM4 is not the port of your MKR WiFi 1010.
If you open the Tools > Port menu in Arduino IDE, is the port listed as "COM4 (Arduino MKR WiFi 1010)", or is it listed only as "COM4"?
Hi, it is only listed as COM4.
This tells us that COM4 is not the port of your MKR WiFi 1010. So you are only wasting your time trying to upload with that port selected since there is no hope the upload will ever succeed when you have the wrong port selected.
Please try this experiment and then report back with the results:
  1. Connect your Arduino board to your computer with the USB cable.
  2. Press and release the reset button on your Arduino board quickly twice.
  3. If it is already open, close the Tools > Port menu in Arduino IDE.
  4. Open the Tools > Port menu in Arduino IDE.
Now please reply here on the forum thread with the answers to the following questions:
  • Do you now see the LED on the board pulsing?
  • Do you see a port for the board in the Tools > Port menu?
Hello, the LED on the board is pulsing as expected, in the order of red green and blue. But I do not see the port for Arduino MKR 1010 WiFi listed under Ports, but it works for my Mega 2560. Thank you
That is actually unexpected. The expected result is that the yellow LED next to the "5V" pin on the board will pulse. I'm talking about the LED indicated by the arrow on this diagram:
Does that LED pulse after you press the reset button on the MKR WiFi 1010 board twice quickly?
