Problem defining Serial2 in order to Make SERCOM2 into UART
Hello. I am attempting to redirect some of the pins on the MKRZero board so I can use multiple serial communication methods at the same time. I am running into a problem when trying to make SERCOM2 into a UART. I feel like the solution is simple, but I could be wrong. Any help is appreciated!
Here is my code:
//puts TX on PA10 D1 - SERCOM2.2
//puts RX on PA11 D0 - SERCOM2.3
#include <Arduino.h>          //required before wiring_private.h
#include "wiring_private.h"   //pinPeripheral() function
Uart Serial2 (&sercom2, 0, 1, SERCOM_RX_PAD_3, UART_TX_PAD_2);
void SERCOM2_Handler()
  Serial2.IrqHandler();
  Serial2.begin(9600);
  //assign pins 0 &1 SERCOM functionality
  pinPeripheral(0, PIO_SERCOM_ALT);   //use ALT b/c pin 3 and 4 use SERCOM alt mux
  pinPeripheral(1, PIO_SERCOM_ALT);
uint8_t i=0;
  Serial.print(i);
  Serial2.write(i++);
  if(Serial2.available())
    Serial.print(" -> 0x");
    Serial.print(Serial2.read(), HEX);
  delay(10);
And here is the error message I am receiving:
Arduino: 1.8.12 (Windows 10), Board: "Arduino MKRZERO"
core\variant.cpp.o:(.bss.Serial2+0x0): multiple definition of `Serial2'
sketch\Sercom2_to_UART.ino.cpp.o:(.bss.Serial2+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino MKRZERO.
option enabled in File -> Preferences.
Here is the document I am following when trying to do this:
use a different name, not Serial2
EDIT: did you do some changes in variant files? MKR Zero normally doesn't have Serial2 in variant.cpp
