Good afternoon,
I have downloaded this library and tried to install it into the IDE by going to
Sketch > Include Library > Add .ZIP Library
But I promptly get this error:
Error: 13 INTERNAL: Library install failed: archive is not valid: multiple files found in zip file top level
I am using Arduino IDE 2.0.3
dlloyd
2
Worked OK here (and compiles without error) using Arduino 1.8.19
The zipped library was added using:
Sketch > Include Library > Add .ZIP Library... > DS3231_Simple-master.zip
xfpd
3
Just verifying you used the green dropdown CODE v >> DOWNLOAD ZIP on the linked page?
dlloyd
4
Just tested using Arduino 2.0.3, worked OK, no errors.
Perhaps you may need to close and re-open Arduino 2.0.3
I did not download it from there, I downloaded it from the link further down in the instructions area.
I did it your way and it worked just fine!
Thank you.
wdhare
6
I am a real Newbie and I need clarification and where to find "the green dropdown CODE v >> DOWNLOAD ZIP on the linked page"
