Problem from real time clock value convert to varaible
#include <WiFi.h>
#include "time.h"
const char* ssid       = "*****";
const char* password   = "*****";
const char* ntpServer = "asia.pool.ntp.org";
const long  gmtOffset_sec = 28800;
const int   daylightOffset_sec = 28800;
void printLocalTime()
  struct tm timeinfo;
  if (!getLocalTime(&timeinfo)) {
    Serial.println("Failed to obtain time");
    return;
  Serial.println(&timeinfo, "%B %d %Y %H:%M:%S");
  //connect to WiFi
  Serial.printf("Connecting to %s ", ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println(" CONNECTED");
  //init and get the time
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  printLocalTime();
  //disconnect WiFi as it's no longer needed
  WiFi.disconnect(true);
  WiFi.mode(WIFI_OFF);
  printLocalTime();
if wan use the %d %Y %H:%M:%S the get the variable like
hr = %H;
A = hr + 3 + 5
to get the answer A
The .println() function doesn't have the feature you are trying to use.
When the documentation says "format", it does not mean like the C library 'printf' function.
If you want values from the 'struct tm' you can look at the definition of 'struct tm' in the library you are using.
