Hello, I made one SMPS using LM2596-ADJ Buck converter IC to get 5v/2amps from it to power my external circuit.
I designed the Layout and tested the circuit on PCB three times till now but I am not getting stable output.
The last PCB which I designed provides 5v output for some time initially and later the voltage start fluctuating between 5-10v. I checked the values of feedback resistors properly and they are correct.
I have included the links for my schematic and Layout, I hope someone will help to resolve this issue.
https://drive.google.com/file/d/1C0IOHgW5fGKC2UehGiTHf3Yu1PCMOgkf/view
https://drive.google.com/file/d/1EamGO5s7WK7t8YmyqB9LEr42q_KHdYwO/view
The issue is only with SMPS circuit and not the rest of the circuits (LM1117, Under voltage lockout).
Thank You
