Problem getting multiple inputs on D1 Mini
I hope i am at the right spot over here,
I am having trouble getting this code to work it needs to post sensor info from PIR sensors to MQTT
tho 1 sensor works (sensor1)
but the other 2 wont ... they do nothing
I hope you guys can help , thanks in advance.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* ssid = "#######";
const char* password =  "#######";
const char* mqttServer = "######";
const int mqttPort = 1883;
const char* mqttUser = "########";
const char* mqttPassword = "#######";
String alarmstate = "disarmed";
//Pin Numbers...
int sensor1 = 15;
char* sensor1state = "OFF";
char* sensor1laststate = "OFF";
int sensor2 = 13;
char* sensor2state = "OFF";
char* sensor2laststate = "OFF";
int sensor3 = 12;
char* sensor3state = "OFF";
char* sensor3laststate = "OFF";
WiFiClient espClient;
PubSubClient client(espClient);
  pinMode(sensor1, INPUT);
  pinMode(sensor2, INPUT);
  pinMode(sensor3, INPUT);
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
  client.setServer(mqttServer, mqttPort);
  client.setCallback(callback);
  while (!client.connected()) {
    Serial.println("Connecting to MQTT...");
    if (client.connect("AlarmSYS", mqttUser, mqttPassword )) {
      Serial.println("connected");
      Serial.print("failed with state ");
      Serial.print(client.state());
      delay(2000);
  Serial.print("Publishing available...");
  client.publish("HAlarm/available", "online");
  Serial.print("Subscribing to HAlarm/command");
  client.subscribe("HAlarm/command");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived in topic: ");
  Serial.println(topic);
  Serial.print("Message:");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
      if (!strncmp((char *)payload, "disarmed", length)){
      Serial.println("Received disarmed signal... disarming...");
      client.publish("HAlarm/internal/state", "disarmed");
      else if (!strncmp((char *)payload, "pending", length)){
      Serial.println("Received pending signal... pending...");
      client.publish("HAlarm/internal/state", "pending");
      alarmstate = "pending";
      else if (!strncmp((char *)payload, "armed_away", length)){
      Serial.println("Received armed_away signal... ARMING...");
      client.publish("HAlarm/internal/state", "armed_away");
      alarmstate = "armed_away";
      else if (!strncmp((char *)payload, "triggered", length)){
      Serial.println("Received triggered signal... triggering...");
      client.publish("HAlarm/internal/state", "triggered");
      alarmstate = "triggered";
  client.loop();
  //Do alarm stuff here...
sensor1func();
sensor2func();
sensor3func();
void sensor1func(){
    sensor1laststate = sensor1state;
  if (digitalRead(sensor1)==HIGH){
    sensor1state = "ON";
  else if (digitalRead(sensor1)==LOW){
  if (sensor1laststate != sensor1state) {
    client.publish("HAlarm/sensor/1", sensor1state);
  void sensor2func(){
    sensor2laststate = sensor2state;
  if (digitalRead(sensor2)==HIGH){
    sensor2state = "ON";
  else if (digitalRead(sensor2)==LOW){
  if (sensor2laststate != sensor2state) {
    client.publish("HAlarm/sensor/2", sensor2state);
  void sensor3func(){
    sensor3laststate = sensor3state;
  if (digitalRead(sensor3)==HIGH){
    sensor3state = "ON";
  else if (digitalRead(sensor3)==LOW){
  if (sensor3laststate != sensor3state) {
    client.publish("HAlarm/sensor/3", sensor2state);
I'm missing the links to the used hardware and a wiring diagram!
Your problems might have their source in the fact that pin D8 (GPIO15) has an onboard pull-down resistor while the others don't. Depending on the used PIRs they need pull-downs. That's why the sticky post at the top of the topic tells you to post all relevant information.
