Problem in Uploading program into Arduino Uno Board
I have window 10- i5 7400 system with 16GB RAM. I brought a Arduino UNO R3 and i used it from last 7 month. During that period the Arduino Board was working fine and used it for demo project also. Yesterday my windows 10 gets updated and then problem in Uploading a program start happing. I try reinstall Arduino IED also but still problem persist. the problem is
When i click on UPLOAD button the error is ....
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe4
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe4
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I search on gogole regarding these and i found that their is so many chances or cause that can give these error. My observation or setup is as follows :-
  1. Connect Arduino Uno Board and PC- Both power LED and PIN 13 LED will glow. Orange LED i.e LED connected to PIN 13, gets OFF after very 6-7 second and on immediately (in short it blinks).
  2. I choose proper board on in Arduino IED.
  3. I have doubt against the COM Port. In Arduino IED software only COM1 is shown sceen shot attached.
    but in my device manager nothing showing regarding the Arduino. Also when i plug the Arduino to the
    PC no sound or no unknow device is shown in Device Manager Tab. I don't known whether the driver
    was properly installed or not.
Please help me to solve these propblem.... please...
Make sure the USB cable is completely plugged into both the Arduino board and the PC.
You may have a damaged/defective or charge-only USB cable. Try a different cable.
When you plug in the Arduino to your PC - a driver is installed to emulate a serial port. I would guess that the Windows update affected the driver. Try to re-install the driver on the PC.(remove the driver while the UNO is plugged out and plug it in again after removing the driver). The proper reply to AVRDUDE for a GetSync is 0x14 followed by 0x10 and it is getting 0xE4 instead.
It may be helpful to also point out that If you're using a cheap Arduino clone board you may need a different driver
Sparkfun have a detailed guide for the clone boards here - https://learn.sparkfun.com/tutorials/how-to-install-ch340-drivers/all
Hello pert,
I used same cable from last 5-6 month for uploading the code to the board so there is no faulty selection of cable i think. It will working very fine. And also i try another cable but same problem will pop-pup.
And also when i plug the cable Green LED and Orange LED will glow up.
Also i found that when i disconnected the Arduino board from my PC and then upload the code to board
  1. the error was getting like
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x82
"But i think the actual error was something user board is not connected" something like that
  1. Also Serial monitor window will open even if i don't connect Arduino Board to PC.
Hello daveve,
I try to re-install the driver. But for when i try to uninstall the it, the driver is not showing in Device Manager. I also try the option of "View - Show Hidden Devices" but nothing was showing regarding Board driver. Then i plugged the Arduino Uno Board to PC and again check device Manager. But nothing was showing regarding Board driver again and also the unknown device.
And also i perform the loop test. when i type a number on serial monitor and the click send button, nothing was get reply from the Board and serial monitor screen will remain blank.
Hello Cheetor,
I tried these one but not showing driver on device manager when i connect Arduino Uno Board to PC
Sparkfun have a detailed guide for the clone boards here - How to Install CH340 Drivers - SparkFun Learn
