Problem: initializing member array before loop
Hello dear community,
I´ve been experiencing a scope problem that I don´t know how to solve.
I am trying to initialize an object member before the loop(). I tried different ways, but all of them return 0 even though I´m convinced, that the actual inititlization is okay. I'm not getting any compile errors, I simply get a zero, where I think I already assigned a value.
  1. Attempt: initializing in the constructor of the object.
//----Obj.h
#define SIZE 5
class Obj
  public:
  Obj();
  void getval(uint8_t pos);
  private:
  std::array <uint8_t, SIZE> member;
//----Obj.cpp
Obj::Obj()
  std::array <uint8_t, SIZE> member = {0, 1, 2, 3, 4 };
void getval(uint8_t pos) {
  Serial.println("Loop: "+String(member[pos]));
//----main.ino
Obj MyObj();
setup(){
loop() {
  MyObj.getval (0);
Result:
Loop: 0
Loop: 0
Loop: 0
  1. Attempt: initializing in function in setup.
//----Obj.h
#define SIZE 5
class Obj
  public:
  Obj();
  void begin();
  private:
//----Obj.cpp
Obj::Obj() {}
void begin() {
  Serial.println("Setup: "+String(member[1]));
//----main.ino
Obj MyObj();
setup(){
  MyObj.begin();
loop() {
  MyObj.getval (1);
Result:
Setup: 1
Loop: 0
Loop: 0
I really want to avoid putting the begin function in the main loop (didn't even try it yet), since the array needs to be non-static and non-const later on in the project.
From my understanding the obejct is global, hence the members should be too (except of being private), so this should work.
Where am I wrong?
Thanks in advance
Cheers
Jokinger
the posted code had numerous errors
here's a re-write the generated the following
output
Loop: 1
Loop: 2
Loop: 3
Loop: 99
Loop: 2001
#define SIZE 5
class Obj {
    int member [SIZE] = { 1, 2, 3, 99, 2001 };
  public:
    Obj ()                    { }
    void getval (uint8_t pos) {
        Serial.print    ("Loop: ");
        Serial.println  (member[pos]);
} myObj;
void setup (){
    Serial.begin (9600);
    for (int n = 0; n < SIZE; n++)
        myObj.getval (n);
void loop () {
I am no expert on C++ but it looks like a local variable that simply shadows your real “member“.
errors from posted code
Tst:11:8: error: 'array' in namespace 'std' does not name a template type
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino:14:1: warning: extra qualification 'Obj::' on member 'Obj' [-fpermissive]
 Obj::Obj()
Tst:14:1: error: 'Obj::Obj()' cannot be overloaded
Tst:7:3: error: with 'Obj::Obj()'
   Obj();
Tst:19:6: error: 'void Obj::getval(uint8_t)' cannot be overloaded
Tst:8:8: error: with 'void Obj::getval(uint8_t)'
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino:26:7: warning: ISO C++ forbids declaration of 'setup' with no type [-fpermissive]
 setup(){
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino:30:6: warning: ISO C++ forbids declaration of 'loop' with no type [-fpermissive]
 loop() {
Tst:32:1: error: expected '}' at end of input
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino: In constructor 'Obj::Obj()':
Tst:16:8: error: 'array' is not a member of 'std'
Tst:16:22: error: expected primary-expression before ',' token
Tst:16:30: error: 'member' was not declared in this scope
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino:16:30: note: suggested alternative: 'memmem'
                              memmem
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino: In member function 'void Obj::getval(uint8_t)':
Tst:20:34: error: 'member' was not declared in this scope
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino:20:34: note: suggested alternative: 'memmem'
                                  memmem
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino: In member function 'int Obj::setup()':
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino:28:1: warning: no return statement in function returning non-void [-Wreturn-type]
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino: In member function 'int Obj::loop()':
Tst:31:3: error: invalid use of member function 'Obj Obj::MyObj()' (did you forget the '()' ?)
   MyObj.getval (0);
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino:32:1: warning: no return statement in function returning non-void [-Wreturn-type]
C:\stuff\SW\Arduino\_Others\Tst\Tst.ino: At global scope:
Tst:32:1: error: expected unqualified-id at end of input
exit status 1
Yes, Variable Shawdowing.
The local variable being initalized is destroyed when the function (constructor or begin) ends.
It still works with std::array
/* Online C++ Compiler and Editor */
#include <iostream>
#include <cstdint>
#include <algorithm>
#include <array>
#include <iterator>
#include <string>
using namespace std;
#define SIZE 5
class Obj
  public:
  //private:
Obj myObj ;
int main()
    for ( int i = 0; i < SIZE ; i++ )    {
       std::cout << (uint16_t)myObj.member[i] << endl;
   return 0;
Thank you. You´re right about the mistakes. I only posted it as an example.
But you are using the variable public, which I don´t attend to declare it.
Why is it local though?
myObj is initialized before the setup, so it should be global.
Thanks for the link. I´ll browse through it
If you're asking for (free) help, common courtesy would suggest that you post your actual code (or an abbreviated) version so that members don't waste time fixing errors that aren't part of your problem.
Regarding initialization ... most efficient would be an initializer list in the constructor:
#define SIZE 5
class Obj {
  public:
    Obj() : member ( {
      0, 1, 2, 3, 4
    uint8_t getVal(uint8_t pos);
  private:
uint8_t Obj::getVal(uint8_t pos) {
  return member[pos];
Obj myObj;
  for (size_t i = 0; i < SIZE; i++) {
    Serial.println(myObj.getVal(i));
You've defined it inside the function. That makes it local.
There's a bit more to it, so I didn't want to bother you with that stuff, but yes, thank you. I´ll keep it in mind for the next time.
Because it is declared as a local variable. Instead of assigning you are declaring AND assigning.
Compare two pieces of code:
int Global_variable = 10;
void some_function() {
  int Global_Variable = 666;
  Serial.printf("some_function() : Global_Variable is %d\r\n", Global_Variable);
  Serial.printf("loop() : Global_Variable is %d\r\n", Global_Variable);
  some_function();
And
  some_function();
Note that in second code fragment, the Global_Variable is assigned in a right way. In first code example the same variable is declared local in the function.
Yeah, I saw it when you wrote it.
Thank you.
Fun fact: I was taught wrong but never had problems with it, because I rarely used different intial values than zero.
Thank you very much for elaborating. You´re absolutely right.
