Problem Installing Arduino 1.8.2 Linux 64 bit (Ubuntu 16.04)
After downloading and extracting and right clicking install.sh
there was no NO RUN COMMAND
Used Terminal and received the following “No Vendor Error”
dmk@dmk-HP7800:~/Downloads/arduino-1.8.2$ ./install.sh
Adding desktop shortcut, menu item and file associations for Arduino IDE…xdg-mime: file ‘/home/dmk/Downloads/arduino-1.8.2/lib/cc.arduino.arduinoide.xml’ does not exist
xdg-icon-resource: icon name ‘cc.arduino.arduinoide’ does not have a proper vendor prefix
A vendor prefix consists of alpha characters ([a-zA-Z]) and is terminated
with a dash ("-"). An example icon name is ‘example-cc.arduino.arduinoide’
Solved- see
opened 08:42PM - 24 Mar 17 UTC
closed 11:14AM - 11 Apr 17 UTC
I'm trying to install arduino-1.8.2-linux64 under a Gentoo Linux system but when… running the `install.sh` script I get the following error messages:
$ ./install.sh
Adding desktop shortcut, menu item and file associations for Arduino IDE...touch: cannot touch '/home/fturco/.local/share/icons/hicolor/.xdg-icon-resource-dummy': No such file or directory
xdg-mime: file '/home/fturco/Buffer/arduino-1.8.2/lib/cc.arduino.arduinoide.xml' does not exist
xdg-icon-resource: icon name 'cc.arduino.arduinoide' does not have a proper vendor prefix
with a dash ("-"). An example icon name is 'example-cc.arduino.arduinoide'
Use --novendor to override or 'xdg-icon-resource --manual' for additional info.
xdg-desktop-menu: filename 'cc.arduino.arduinoide.desktop' does not have a proper vendor prefix
with a dash ("-"). An example filename is 'example-cc.arduino.arduinoide.desktop'
Use --novendor to override or 'xdg-desktop-menu --manual' for additional info.
xdg-desktop-icon: filename 'cc.arduino.arduinoide.desktop' does not have a proper vendor prefix
Use --novendor to override or 'xdg-desktop-icon --manual' for additional info.
done!
There's no Arduino IDE among my applications after the previous installation process.
Please notice I can install the previous Arduino version (1.8.1) without any problems.
hmattiasl Comment 03-29-2017
"I had the same problem while installing Arduini IDE 1.8.2 on a Ubuntu machine. The resource name in the install.sh file is wrong. When I looked in the Arduino-1.8.2/lib there is a file named arduino-arduinoide.xml file. So I changed the "RESOURCE_NAME=cc.arduino.arduinoide" to "RESOURCE_NAME=arduino-arduinoide" and then run ./install.sh and that worked fine for me.
DMKWSU
