Hallo liebe Forumsgemeinde,
ich habe mir oben genanntes RTC Modul schicken lassen. Gestern abend auf dem Steckbrett vom Arduino Uno R3 versorgt:
ARDUINO RTC
GND GND
5V VC
SDA SDA
SCL SCL
dann folgenden Sketch eingespielt:
Display the date and time from a DS3231 or DS3232 RTC every second.
Display the temperature once per minute. (The DS3231 does a
temperature conversion once every 64 seconds. This is also the
default for the DS3232.)
Set the date and time by entering the following on the Arduino
serial monitor:
year,month,day,hour,minute,second,
Where
year can be two or four digits,
month is 1-12,
day is 1-31,
hour is 0-23, and
minute and second are 0-59.
Entering the final comma delimiter (after "second") will avoid a
one-second timeout and will allow the RTC to be set more accurately.
No validity checking is done, invalid values or incomplete syntax
in the input will result in an incorrect RTC setting.
Jack Christensen 08Aug2013
Tested with Arduino 1.0.5, Arduino Uno, DS3231/Chronodot, DS3232.
This work is licensed under the Creative Commons Attribution-
ShareAlike 3.0 Unported License. To view a copy of this license,
visit http://creativecommons.org/licenses/by-sa/3.0/ or send a
letter to Creative Commons, 171 Second Street, Suite 300,
San Francisco, California, 94105, USA.
#include <DS3232RTC.h> //http://github.com/JChristensen/DS3232RTC
#include <Streaming.h> //http://arduiniana.org/libraries/streaming/
#include <Time.h> //http://playground.arduino.cc/Code/Time
#include <Wire.h> //http://arduino.cc/en/Reference/Wire
void setup(void)
//setSyncProvider() causes the Time library to synchronize with the
//external RTC by calling RTC.get() every five minutes by default.
setSyncProvider(RTC.get);
Serial << F("RTC Sync");
if (timeStatus() != timeSet) Serial << F(" FAIL!");
Serial << endl;
void loop(void)
static time_t tLast;
time_t t;
tmElements_t tm;
//check for input to set the RTC, minimum length is 12, i.e. yy,m,d,h,m,s
if (Serial.available() >= 12) {
//note that the tmElements_t Year member is an offset from 1970,
//but the RTC wants the last two digits of the calendar year.
//use the convenience macros from Time.h to do the conversions.
int y = Serial.parseInt();
if (y >= 100 && y < 1000)
Serial << F("Error: Year must be two digits or four digits!") << endl;
else {
if (y >= 1000)
tm.Year = CalendarYrToTm(y);
else //(y < 100)
tm.Year = y2kYearToTm(y);
tm.Month = Serial.parseInt();
tm.Day = Serial.parseInt();
tm.Hour = Serial.parseInt();
tm.Minute = Serial.parseInt();
tm.Second = Serial.parseInt();
t = makeTime(tm);
RTC.set(t); //use the time_t value to ensure correct weekday is set
setTime(t);
Serial << F("RTC set to: ");
printDateTime(t);
Serial << endl;
//dump any extraneous input
while (Serial.available() > 0) Serial.read();
t = now();
if (t != tLast) {
tLast = t;
printDateTime(t);
if (second(t) == 0) {
float c = RTC.temperature() / 4.;
float f = c * 9. / 5. + 32.;
Serial << F(" ") << c << F(" C ") << f << F(" F");
Serial << endl;
//print date and time to Serial
void printDateTime(time_t t)
printDate(t);
Serial << ' ';
printTime(t);
//print time to Serial
void printTime(time_t t)
printI00(hour(t), ':');
printI00(minute(t), ':');
printI00(second(t), ' ');
//print date to Serial
void printDate(time_t t)
printI00(day(t), 0);
Serial << monthShortStr(month(t)) << _DEC(year(t));
//Print an integer in "00" format (with leading zero),
//followed by a delimiter character to Serial.
//Input value assumed to be between 0 and 99.
void printI00(int val, char delim)
if (val < 10) Serial << '0';
Serial << _DEC(val);
if (delim > 0) Serial << delim;
return;
Über Serial Datum und Uhr gestellt (nach Atomzeit)und seitdem läuft das Ding.
Allerdings habe ich jetzt das Phänomen, das nach ca. 14 Stunden mein RTC um 1,5 Sekunden hinten nachhängt.
Das nenne ich nicht präzise, hat jemand eine Idee bzw. ähnlich Erfahrungen?
Danke, Claus
