hello together,
I have a problem with my Bluetoothsensor Hc-05(when I wanted to connect it with my cell phone).
Can you help me???
Thanks a lot!!
Max
hello together,
Can you help me???
Thanks a lot!!
Max
This is just as much a phone problem as an Arduino one.
Please confirm that you are using an Android phone.
Please confirm that there is a flashing LED on the Bluetooth module.
I have an android phone huawei p30 lite
Here is a good page on connecting the HC05 to an Arduino.
Before you can use the HC05 to send and receive data to/from your Arduino you must pair the HC05 with the phone and connect the paired HC05 to an app on the phone that can send and receive data. My favorite app for setting up the initial communication is the Serial Bluetooth Terminal app.
What Arduino board are you using? Show how the HC05 is wired to the mystery Arduino.
Here is my test code for an Uno (or Nano) to test communication between a HC05 and a Bluetooth capable device running serial Bluetooth terminal.
//Sends from serial monitor to the Bluetooth device app
// receives from the Bluetooth device app
#include <SoftwareSerial.h>
SoftwareSerial BTserial(4, 7); // RX | TX
BTserial.begin(9600);
if (Serial.available())
BTserial.write(Serial.read());
if (BTserial.available())
Serial.write(BTserial.read());
Whatever you type into the serial monitor should show up in the Bluetooth terminal and visa versa.
You might find the following background notes useful.
Hello together,
thank you for your helpfull tipps but the situation is:
Max
PS: I ORDERED THE hc-05 at ali-express.
Well, I guess that that is all one can do - guess.
bad wiring
inadequate power
car goes out of range
inadequately exposed antenna
