Problem Mit Millis
Hallo,
ich habe hier ein kleines Problem mit meinem Code für eine MAX7219 Matrix. Per Push Button sollen einzelnen Programme gewählt werden. Funktioniert auch alles soweit ohne Probleme. Ein Counter wird mit millis() gesteuert.
include "LedControl.h"
#define BUTTON_PIN                 2
LedControl lc = LedControl(12,11,10,1);
int buttonState;
int lastButtonState = LOW;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
unsigned long previous_millis = 0;
byte counter = 0;
byte program = 0;
byte squares[5][8]  =
	{0b11111111,0b10000001,0b10000001,0b10000001,0b10000001,0b10000001,0b10000001,0b11111111},
	{0000000000,0b01111110,0b01000010,0b01000010,0b01000010,0b01000010,0b01111110,0b00000000},
	{0000000000,0b00000000,0b00111100,0b00100100,0b00100100,0b00111100,0b00000000,0b00000000},
	{0000000000,0b00000000,0b00000000,0b00011000,0b00011000,0b00000000,0b00000000,0b00000000},
	{0000000000,0b00000000,0b00000000,0b00000000,0b00000000,0b00000000,0b00000000,0b00000000},
void testing(uint16_t interval, byte arr[0][8])
	if (millis() - previous_millis >= interval)
		previous_millis += interval;
		for (byte row = 1; row < 9; row++)
			lc.setRow(0, row-1, arr[counter][row - 1]);
		counter++;
    if (counter == 5)
			counter = 0;
void debounce()
	int reading = digitalRead(BUTTON_PIN);
  if (reading != lastButtonState)
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay)
    if (reading != buttonState)
      buttonState = reading;
      if (buttonState == HIGH)
				lc.clearDisplay(0);
				program++;
				counter = 0;
  lastButtonState = reading;
	lc.shutdown(0,false);
  lc.setIntensity(0,1);
  lc.clearDisplay(0);
	pinMode(BUTTON_PIN, INPUT);
	debounce();
  Serial.println(counter);
	switch(program)
		case 1:
			testing(1000, squares);
		case 2:
			testing(500, squares);
		default:
			counter = 0;
			program = 0;
Anstatt
if (millis() - previous_ms >= interval)
previous_ms = millis();
habe ich folgendes probiert: (wie in dem beispiel ganz unten,
, Modifikation für exakte Intervalle)
previous_ms += interval;
Funktioniert auch soweit, jedoch wird die counter variable nach jedem Tastendruck teilweise nicht wieder auf 0 gesetzt, also manchmal nach dem ersten Durchlauf (also case wieder auf 1)
, startet der counter bei 3 oder 4 ( laut Serial Monitor) , obwohl er eigentlich bei 0 starten sollte.
woran kann das liegen?
vielen Dank schonmal im Voraus
gruß
Hendrik
LedControl lc = LedControl(12, 11, 10, 1);
bool buttonState;
bool lastButtonState = LOW;
byte counter = 0;
byte program = 0;
  {0b11111111, 0b10000001, 0b10000001, 0b10000001, 0b10000001, 0b10000001, 0b10000001, 0b11111111},
  {0000000000, 0b01111110, 0b01000010, 0b01000010, 0b01000010, 0b01000010, 0b01111110, 0b00000000},
  {0000000000, 0b00000000, 0b00111100, 0b00100100, 0b00100100, 0b00111100, 0b00000000, 0b00000000},
  {0000000000, 0b00000000, 0b00000000, 0b00011000, 0b00011000, 0b00000000, 0b00000000, 0b00000000},
  {0000000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000},
void testing(unsigned long interval, byte arr[][8]) {
  if (millis() - previous_millis >= interval) {
    for (byte row = 1; row < 9; row++) {
      lc.setRow(0, row - 1, arr[counter][row - 1]);
    counter++;
    if (counter == 5) counter = 0;
void debounce() {
  bool reading = digitalRead(BUTTON_PIN);
  if (reading != lastButtonState) {
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (reading != buttonState) {
      if (buttonState == HIGH) {
        lc.clearDisplay(0);
        program++;
        counter = 0;
        Serial.println("Tastendruck");
  lc.shutdown(0, false);
  lc.setIntensity(0, 1);
  lc.clearDisplay(0);
  debounce();
  Serial.print("program: ");
  Serial.print(program);
  Serial.print("; counter: ");
  switch (program) {
    case 1:
    case 2:
    default:
      counter = 0;
      program = 0;
Kannst du das mal testen und die Serielle Ausgabe posten?
Wie ist der Button angeschlossen?
Und erklär mal bitte mit ein paar Worten, was da passieren soll.
r: 0
program: 0; counter: 0
program: 0; co□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□□ɽ���program: 0; counter: 0
Tastendruck
program: 1; counter: 0
program: 1; counter: 1
program: 1; counter: 2
Tastendruck
program: 2; counter: 0
program: 2; counter: 1
program: 2; counter: 2
program: 2; counter: 3
program: 2; counter: 4
Tastendruck
program: 3; counter: 0
Tastendruck
program: 1; counter: 3
program: 1; counter: 4
Tastendruck
Tastendruck
Tastendruck
Tastendruck
Tastendruck
Tastendruck
Tastendruck
Tastendruck
Tastendruck
Tastendruck
Tastendruck
Tastendruck
10k Pullup Resistor an besagten Pin. Bei Knopfdruck sollen die Programme im Switch(Program) ausgewählt werden. Das Phänomen mit dem Counter tritt aber wie gesagt nur sporadisch auf
bool buttonState;
byte counter = 0;
byte program = 0;
byte squares[5][8]  = {
    counter++;
    Serial.print("counter: ");
void debounce() {
        lc.clearDisplay(0);
        program++;
        counter = 0;
        Serial.println(program);
  lc.clearDisplay(0);
  debounce();
  switch (program) {
    case 1:
    case 2:
    default:
      counter = 0;
      program = 0;
Kannst du es so noch mal testen
counter: 1
counter: 2
counter: 3
Tastendruck
program: 2
counter: 1
counter: 2
counter: 3
counter: 4
counter: 0
counter: 1
counter: 2
counter: 3
counter: 4
Tastendruck
program: 3
Tastendruck
program: 1
counter: 1
counter: 2
counter: 3
counter: 4
counter: 0
Tastendruck
program: 2
counter: 1
counter: 2
counter: 3
counter: 4
counter: 0
counter: 1
counter: 2
Tastendruck
program: 3
Tastendruck
program: 1
counter: 1
counter: 2
counter: 3
Tastendruck
program: 2
counter: 1
counter: 2
Tastendruck
program: 3
Tastendruck
program: 1
counter: 1
counter: 2
Tastendruck
program: 2
counter: 1
counter: 2
counter: 3
counter: 4
counter: 0
Also erster Knopfdruck case 1 - zweiter Knopfruck case 2 - dritter Knopfdruck default (alles löschen)
Jetzt passt es doch. Oder?
Setze solche (langen) Ausgaben bitte in Codetags, damit man nicht ewig scrollen muss.
Wie das geht, steht hier. Das kannst Du auch nachträglich ändern.
Gruß Tommy
ok danke , poste hier noch so oft
leider kommt bei case 1 immer noch ein kleine verzögerung
Augenblick, füge mal hinter Zeile 49 previous_millis = 0; ein.
das hatte ich auch schon probiert , bringt aber keine besserung .
Dann ändere es bitte auch in Deinem Posting #8.
Gruß Tommy
Das ist doch Murks!
Der wartet jetzt erst das prellen ab, dann wartet er nach dem letzten prellen nochmal 50ms (debouncetime) bis er merkt, dass er die Taste gedrückt hat.
@rermtoe8
Ich hab leider nicht verstanden, wann die Taste was auslösen soll, da Du programm und counter gemischt verwendest.
per Tastendruck soll die Program-Variable inkrementiert werden, der Counter ist für die Darstellung des Musters , im Loop also von 0 - 5
// #include "LedControl.h"
constexpr uint8_t BUTTON_PIN {2};
// LedControl lc = LedControl(12, 11, 10, 1);
constexpr bool isPressed {LOW};
uint8_t lastProgramm;
bool buttonState;
byte counter = 0;
byte program = 0;
      // lc.setRow(0, row - 1, arr[counter][row - 1]);
    counter++;
    if (counter >= 5)
    { counter = 0; }
    Serial.print(F("Counter: "));
    Serial.print(counter);
void getButton()
  bool buttonState = digitalRead(BUTTON_PIN);
  if (buttonState == isPressed)
    if (lastButtonState != isPressed)
      lastButtonState = isPressed;
      program++;
  else if (millis() - lastDebounceTime > debounceDelay)
    lastButtonState = !isPressed;
    lc.clearDisplay(0);
  getButton();
  setProgramm();
void setProgramm()
  if (lastProgramm != program)
    counter = 0;
//    lc.clearDisplay(0);
    lastProgramm = program;
    Serial.print(F("programmAuswahl: "));
  switch (program)
    case 0:
    case 1:
    case 2:
    default:
      program = 0;
Es kommt momentan nix auf den LED raus, das ist Absicht.
Theoretisch müsste mit jedem Tastendruck das Programm weiterzählen.
Der counter kommt dann erst mit der 1 - ich bin nicht so schnell heute....
EDIT: Evtl. stimmt die Zeit nach dem umschalten nicht.
Dann neue Zeile 90
und die schliessende Klammer wird dann Zeile 91
programmAuswahl: 1
Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2programmAuswahl: 2
Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2programmAuswahl: 3
programmAuswahl: 0
programmAuswahl: 1
Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1programmAuswahl: 2
Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0programmAuswahl: 3
programmAuswahl: 0
programmAuswahl: 1
Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0programmAuswahl: 2
Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2Counter: 3Counter: 4Counter: 0Counter: 1Counter: 2programmAuswahl: 3
programmAuswahl: 0
programmAuswahl: 1
Sieht für mich nicht falsch aus.
bool buttonState;
byte counter = 0;
byte program = 0;
    counter++;
    if (counter >= 5)
    { counter = 0; }
void getButton()
      program++;
  lc.clearDisplay(0);
  getButton();
  setProgramm();
void setProgramm()
    counter = 0;
    lc.clearDisplay(0);
  switch (program)
    case 0:
    case 1:
    case 2:
    default:
      program = 0;
