Hello,
I am new to this forum and Arduino programming. I apologize for any mistakes on my side in advance.
I am trying to program a pushbutton to select one of three LEDs (cycling through them - red - yellow - green - again red - ...) on a short press (<1000ms). Once I press the button for a longer period of time (>1000ms), I want the current LED to be either getting more or less bright, depending on the previous brightness. I programmed this to happen in increments of 5 everytime the loop repeats and the button is pressed.
To use the same brightness on the current LED, no matter which one is selected, I write the brightness into a variable named brightnessState. This way I can either set the LED to 0 or said variable.
Unfortunatly there seems to be a fault in my code as only the red LED is lit up and my button press is not doing anything.
I already tried to look at some integers, that should be changing (as you can see in the code, where my Serial.println is defined).
I hope someone can help me point out where the problem in the code is.
Components used:
- Arduino Uno
- red, yellow, green LEDs
- pushbutton
/* red LED in 3, yellow LED in 5, green LED in 6, button in 8
const int ledRed = 3; //Red LED in pin A3
const int ledYel = 5; //Yellow LED in pin A4
const int ledGre = 6; //Green LED in pin A5
const int button1 = 8; //Pushbutton for activity
//variables for the debounce function
int buttonState; //the current reading from the input pin
int lastButtonState = LOW; //the previous reading from the input pin
long lastDebounceTime = 0; //last time the input pin is toggled
long debounceDelay = 50; //the debounce time
//variales for the function of the switch
long lastButtonPressTime = 0; //last time the input pin is toggled
const int buttonPressTime = 1000; //the time until the second function is activated
//states of the LEDs
long brightnessState = 255;
long lastBrightnessState = 25;
int ledRedState = brightnessState;
int ledYelState = 0;
int ledGreState = 0;
//debug serial monitor
//LEDs as output
pinMode(ledRed, OUTPUT);
pinMode(ledYel, OUTPUT);
pinMode(ledGre, OUTPUT);
//Buttons as input
pinMode(button1, INPUT);
//LED initial state
digitalWrite(ledRed, ledRedState);
digitalWrite(ledYel, ledYelState);
digitalWrite(ledGre, ledGreState);
int reading = digitalRead(button1); //read the state of the switch into variable "reading"
if(reading != lastButtonState) { //if the switch changed due to noise or pressing
lastDebounceTime = millis(); //reset the debounce timer
if((millis() - lastDebounceTime) > debounceDelay) {
//whatever the reading is, it's been there for longer than the debounce delay
//so take it as the actual current state
if(reading != buttonState){
buttonState = reading; //the setButtonState shall be now set to the initial read state
if(buttonState != lastButtonState) { //if the switch changed due to letting it go
if(lastButtonState == 1){
lastButtonPressTime = millis(); //reset the button-press timer
if((millis() - lastButtonPressTime) > buttonPressTime) { //if the button is pressed for longer than 1000ms do the function nr.2
//action for second function of the button
if(brightnessState == 255){
lastBrightnessState = brightnessState;
brightnessState = brightnessState - 5;
if(brightnessState < lastBrightnessState) {
if(brightnessState >= 30){
else{
brightnessState = brightnessState + 5;
if(brightnessState > lastBrightnessState){
//debug Serial Monitor
//Serial.println(millis() - lastButtonPressTime);
Serial.println(buttonState);
//the action if the button is pressed shortly
if((millis() - lastButtonPressTime) <= buttonPressTime) { //if the button is pressed shorter or equal to 250ms do the function nr.1
//option 1: The red LED is on while the button is pressed
if(ledRedState >= 1){
ledRedState = 0;
ledYelState = brightnessState;
//option 2: The yellow LED is on while the button is pressed
if(ledYelState >= 1){
ledYelState = 0;
ledGreState = brightnessState;
//option 3: The green LED is on while the button is pressed
if(ledGreState >= 1){
ledGreState = 0;
lastButtonState = reading; //reset the last button state
Thank you for everyone taking the time to help me.
Custos
