I'm quite new to Arduinos and have problem storing sensor values to MySQL database. I have read a lot in different forums yesterday and today and found that other have had the same problem but their solutions havn't helped me (maybe because of my lack of knowledge) so i hope you can get me on track again.
On server I have this code:
<?php
if ($_GET["key"] == "7RrlaA2tubH2") {
$servername = "xxx";
$username = "yyy";
$password = "zzz";
$dbname = "123";
// Create connection
$conn = mysqli_connect($servername, $username, $password, $dbname);
// Check connection
if (!$conn) {
die("Connection failed: " . mysqli_connect_error());
$val_ktSensorTemp = $_GET["SensorTemp"];
$val_ktSensorHum = $_GET["SensorHum"];
$val_ktSetTemp = $_GET["SetTemp"];
$val_ktSetHum = $_GET["SetHum"];
$val_ktFridge = $_GET["Fridge"];
$val_ktHeat = $_GET["Heat"];
$val_ktHum = $_GET["Hum"];
$val_ktDehum = $_GET["Dehum"];
$val_ktLog = $_GET["Log"];
$sql = "INSERT INTO kt_data (ktSensorTemp, ktSensorHum, ktSetTemp, ktSetHum, ktFridge, ktHeat, ktHum, ktDehum, ktLog)
VALUES (" . $val_ktSensorTemp .", " . $val_ktSensorHum .", " . $val_ktSetTemp .", " . $val_ktSetHum .", '" . $val_ktFridge ."', '" . $val_ktHeat ."', '" . $val_ktHum ."', '" . $val_ktDehum ."', '" . $val_ktLog . "')";
if (mysqli_query($conn, $sql)) {
echo "Posten sparad";
echo "Fel: " . $sql . "
" . mysqli_error($conn);
mysqli_close($conn);
echo "Behörighet saknas";
If I browse to
"http://api.gotfarm.se/korvtork/kt_save.php?key=7RrlaA2tubH2&SensorTemp=22.20&SensorHum=82.21&SetTemp=20&SetHum=80&Fridge=J&Heat=N&Hum=J&Dehum=N&Log=This is a test" the values are saved in MySQL so I think the server part works as expected.
In the Arduino I have this code for testing:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "api.gotfarm.se";
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 65);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
//Serial.println("connecting...");
Serial.println("Test");
Serial.println("-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-\n");
Serial.print("IP Address : ");
Serial.println(Ethernet.localIP());
Serial.print("Subnet Mask : ");
Serial.println(Ethernet.subnetMask());
Serial.print("Default Gateway IP: ");
Serial.println(Ethernet.gatewayIP());
Serial.print("DNS Server IP : ");
Serial.println(Ethernet.dnsServerIP());
if (client.connect(server,80)) { // REPLACE WITH YOUR SERVER ADDRESS
Serial.println("Connected");
client.print("GET /korvtork/kt_save.php?key=7RrlaA2tubH2&SensorTemp=22.20&SensorHum=82.21&SetTemp=20&SetHum=80&Fridge=J&Heat=N&Hum=J&Dehum=N&Log=From Arduino");
client.println(" HTTP/1.1");
client.print("Host: "); // SERVER ADDRESS HERE TOO
client.println(server);
client.println("Connection: close");
client.println();
client.stop();
else {
// you didn't get a connection to the server:
Serial.println("--> connection failed/n");
if (client.connected()) {
Serial.println("connected");
client.stop(); // DISCONNECT FROM THE SERVER
Serial.println("Client stopped");
delay(5000);
The output in Serial Monitor is:
Test
IP Address : 192.168.1.141
Subnet Mask : 255.255.255.0
Default Gateway IP: 192.168.1.1
DNS Server IP : 192.168.1.1
connecting...
Connected
So it seems it get IP and connects to the server.
What do you think cause the problem that the data isn't saved on the server?
