Problem Setting Booleans
I am having issues setting bool variables. It seems they randomly don't set correctly. If I change the variable name to something completely different, they start to work. If I change it back to the name that wasn't working, they stop working again. I have checked that I am not using any reserved names.
For example the below code prints that flashFlood is false:
bool flashFlood = false;
     Serial.begin();
    if (1 <= 2) {
      flashFlood = true;
    else {
      flashFlood = false;
   Serial.println(flashFlood);
but the below code works, and prints that flashFloodd is true....
bool flashFloodd = false;
     Serial.begin();
    if (1 <= 2) {
      flashFloodd = true;
    else {
   Serial.println(flashFloodd);
Any thoughts? I have a similar problem with other variable names. It seems that there is about a 50% chance a certain name won't work with booleans? I am using an Arduino MKR NB1500 in the Arduino IDE. I have tried on 2 different MKRs with the same result.
Your code does not seem to compile
C:\Users\sterretje\Documents\Arduino\rc9\test_changeBoard\test_changeBoard.ino:5:16: error: no matching function for call to 'Serial_::begin()'
   Serial.begin();
The optimizer can solve the if at compile time and will get rid of everything and the loop will just be
Serial.println(1);
Serial needs to be setup the right way to see anything - and it’s going to fill up the outgoing buffer very quickly
If you submit technically valid data to the Computer, then it can do something meaningful for you. Is 1<= 2 statement technically correct?
What does your question mean?
To ask, as @twist27896 did, if (1 <= 2) is "technically correct" (whatever that may mean), although the answer is of course always going to be false oops true. They were obviously using that as a way to force the program flow into one specific half of the if structure, in much the same was as one might force a stop in a program with a while(1) which is always true.
My intention was to know what OP was answering -- yes or no as by measurement 1 is not equal to 2!
Yes, it's testing too many features at one time. A test of the claimed (dubious) phenomenon is just:
      flashFlood = true;
...unless you are testing the 'if' statement. Adding that makes it no longer an MRE.
The term (1 <= 2) returns boolean true because 1 is less than or equal to 2 as described here https://www.arduino.cc/reference/tr/language/structure/comparison-operators/lessthanorequalto/
For this reason both sketches from post #1 should give the same result.
I second @J-M-L 's post regarding the missing baud rate and would expect that both sketches should not compile and produce this error:
exit status 1
no matching function for call to 'HardwareSerial::begin()'
Not for me. After adding the required baud rate value I run the sketch on an Arduino UNO and it reports '1' (== true) over and over.
What I suspected. :slight_smile: The posted code is not the test code.
Exactly, compiling the sketches should produce the error from post #8 ...
Ah, I forgot to add the baud rate in the post. I set it to 9600 in the actual code. Still getting the error.
Hello twist27896
Take this simple example and gain the knowledge about.
  Serial.println("");
  Serial.println("1 <= 2");
  if (1 <= 2)
    flashFlood = true;
    flashFlood = false;
  Serial.println(flashFlood ? "true" : "false");
  Serial.println(1 <= 2);
  Serial.println("");
  Serial.println("2 <= 1");
  if (2 <= 1)
    flashFlood = true;
    flashFlood = false;
  Serial.println(2 <= 1);
void loop(){}
Have a nice day and enjoy programming in C++ and learning.
Errors and omissions excepted.
Post the exact code that gives the error. Use the ide copy for forum and paste it here.
Or post #2 :slight_smile:
I tried compiling and uploading on a different laptop and it fixed the issue. I reinstalled the Arduino IDE and it works on the original laptop now as well. This fix doesn't really make sense but I guess it works...
you sure?
Are you implying that c++ compiler has somehow compiled this simple sketch with errors on one laptop?
Uggggg... brain failure. Thanks.
I guess, I don't understand why this fixed the issue.
