Hi all
I'm trying to build a calendar/timer to switch on and off lights via modbus.
I'm using ATmega328-PU with a 16x2 lcd , a DS1307 and serial connection for modbus ( i'm using it over RS232 for tests now ).
All work fine, modbus send and receive command and lcd display is working fine.
When i try to write timer data on EEprom it works fine, but when i try to retrieve it all the program stop to work, lcd dislay shows weird things, serial data are a mess.
If i try to load only 9 values from the EEprom it works, but if i try to load more values i have the problem:
// this portion of code mess up all things :
for ( int i=1; i<128; i++ )
buffer_EEprom[i]=EEPROM.read(i);
Large portion of code here :
// MODBUS CALENDAR WITH LCD SCREEN
// CPU : ATMEGA328-PU
// pin map
// 0,1 : serial port for modbus link
// 2,3,4,5,7,8 : 16x2 lcd
// 13 : led
// A0,A1,A2,A3 : butttons with pull down resistor
// A4,A5(SDA/SCL) : DS1307 via i2c
// EEPROM
#include <EEPROM.h>
int buffer_EEprom[128];
// LCD
// FASTER LIBRARY :
// https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 7, 5, 4, 3, 2);
// MODBUS
#include <ModbusMaster.h>
ModbusMaster node(1);
// DS1307
#include <Wire.h>
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
byte second ;
byte minute ;
byte hour ;
byte weekDay;
byte monthDay;
byte month;
byte year;
char buffer_lcd[3]="";
//MENU
#define MENU_OROLOGIO 10
#define SPLASH 16
const char* riga_1[] = {
"< IMPOSTAZIONI >", // menu 0 "menu impostazioni"
"< NORMALE >", // menu 1 "funzionamento normale"
"<SOLO ENTRATA >", // menu 2 "sola entrata"
"<SOLO USCITA >", // menu 3 "sola uscita"
"<SEMPRE CHIUSO >", // menu 4 "sempre chiuso"
"<SEMPRE APERTO >", // menu 5 "sempre aperto"
"<APERT.PARZIALE>", // menu 6 "apertura parziale"
"CONNESSIONE ", // menu 7 "monitor"
"CONNESSIONE ", // menu 8 "stato cancello"
"<AP.PARZ. SET. >", // menu 9 "set % apertura parziale
"<ORARIO> ", // meno 10 "orologio"
"<TIMER >", // meno 11 "TIMER"
"<TIMER ATTIVO ?>", // MENU 12 //"<TIPO TIMER >", // MENU
"<ORARIO INIZIO >", // MENU 13 // "<ORARIO FINE >", // MENU
"<INVIA COMANDO >", // MENU 14
"<TIPO COMANDO >", // MENU 15
"SERIALE CN3 "
const char* riga_2[] = {
"[OK] ",
"IMPOSSIBILE "};
int REFRESH=100 ;
int menu_visualizzato = SPLASH;
int setting_orario = 0;
// TIMER
byte timer_numero = 1;
byte timer_abilitato=EEPROM.read(2);
byte timer_comando =EEPROM.read(3);
byte timer_tipo_comando =EEPROM.read(4);
byte timer_giorno_inizio =EEPROM.read(5);
byte timer_ora_inizio = EEPROM.read(6);
byte timer_minuto_inizio = EEPROM.read(7);
byte timer_giorno_fine = EEPROM.read(8);
byte timer_ora_fine = EEPROM.read(9);
byte timer_minuto_fine = EEPROM.read(10);
byte timer_comando_inviato = 0 ;
// BUTTONS
int state_button_SX;
int laststate_button_SX=LOW;
int state_button_DX;
int laststate_button_DX=LOW;
int state_button_OK;
int laststate_button_OK=LOW;
int state_button_CANC;
int laststate_button_CANC=LOW;
int reading_button_SX ;
int reading_button_DX ;
int reading_button_OK ;
int reading_button_CANC ;
long lastDebounceTime_SX = 0;
long lastDebounceTime_DX = 0;
long lastDebounceTime_OK = 0;
long lastDebounceTime_CANC = 0;
long debounceDelay = 20;
// VARIABILI VARIE
int timer_lcd=0;
int percentuale_apertura_parziale=50;
int sempre_aperto = 0;
byte low ;
byte high;
int kk=0;
low = EEPROM.read(1002);
high = EEPROM.read(1001);
pinMode(13, OUTPUT);
// INPUTS
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
// Instantiate the RTC
Wire.begin();
// 16X2 LCD
lcd.begin(16, 2);
requestDateTime();
weekDay=(byte)dow2(year, month,monthDay);
// modbus
node.begin(19200);
static uint32_t i;
uint8_t result;
int reading_button_SX = analogRead(A0);
int reading_button_DX = analogRead(A1);
int reading_button_OK = analogRead(A2);
int reading_button_CANC = analogRead(A3);
if ( reading_button_SX > 500 ) reading_button_SX=1000;
else reading_button_SX=0;
if ( reading_button_DX > 500 ) reading_button_DX=1000;
else reading_button_DX=0;
if ( reading_button_OK > 500 ) reading_button_OK=1000;
else reading_button_OK=0;
if ( reading_button_CANC > 500 ) reading_button_CANC=1000;
else reading_button_CANC=0;
switch(menu_visualizzato)
case SPLASH:
// read some registers
result = node.readHoldingRegisters(0x1020,16);
// write some registers
node.setTransmitBuffer(0,213);
result = node.writeMultipleRegisters(0xFFFC,1);
node.setTransmitBuffer(0,35161);
result = node.writeMultipleRegisters(0xFFFD,1);
lcd.setCursor(0,0);
lcd.print(" HELLO ");
lcd.setCursor(0,1);
lcd.print(low);
lcd.setCursor(8,1);
lcd.print(high);
if(timer_lcd==5) menu_visualizzato = MENU_OROLOGIO;
laststate_button_SX = reading_button_SX;
laststate_button_DX = reading_button_DX;
laststate_button_OK = reading_button_OK;
laststate_button_CANC = reading_button_CANC;
I have not problem to load other data from EEProm like parameters low and high at address 1001 and 1002.
I'm going out of memory ?
Sram is full ?
