Problem to receive serial data from processing to arduino duemilanove
Hi all,
Does anyone has information to receive data commnunication from processing to "arduino duemilanove" by sending "0" or "1" byte through serial ? I've received nothing when communicate from serial to arduino and need someone to further guide me. Those reference I took from websites "Connecting Arduino to Processing - SparkFun Learn"
My coding in processing:
import processing.serial.*;
Serial myport;
void setup(){
String portname = Serial.list()[0];
myport = new Serial(this,portname,9600);
void draw(){
if (myport.available() > 0 )
myport.write("1");
println("Print 1 to arduino Now");
My coding in arduino : (I'd tried to monitor incoming byte from process in serial monitor)
int incomingByte = 0 ;
if (Serial.available() > 0 )
incomingByte = Serial.read();
Serial.print("check :");
Serial.println(incomingByte,DEC);
The situation is weird where It show nothing happened and returned empty in output once I opened serial monitor to check out. I've managed to pluged in to power arduino(First) and click to run processing(second).
How i could possible to receive "1" from processing to arduino through serial monitor?
Hopw someone could guide me in further, Thanks.
I don't know Processing. You may find some useful stuff in Serial Input Basics
Please use the code button </> so your code looks like this and is easy to copy to a text editor
...R
if (myport.available() > 0 ) {
    myport.write("1");
"If something was received, then start a never ending stream of output"
seems to me a very strange strategy for a communication.
That is stupid. That variable REALLY should be called incomingFloat, don't you think?
PaulS:
This may be a little too cryptic for a beginner. What @PaulS means is that if you want to receive an int you should have
int incomingInt = 0 ;
and if you want to receive a byte (which is more likely) you should have
byte incomingByte = 0 ;
...R
