Problem Using Buttons to Control my Temperature Controller
Please, i am very new in Arduino as well as Programming, i am working on a temperature controller than uses two buttons. The buttons are used to increase or decrease the working temperature range of the controller. if the temperature range set by pressing the button is different from the sensor temperature reading, the controller would take certain actions.
I have tried this in two ways but NOT working;
  1. When i use the void loop for all the codes, the buttons would work very slow, infact, you have to press and hold before it would work and sometimes doesn't work at all
  2. when i tried creating another function outside the void loop function. (i.e.) i used the void loop for the buttons alone and the rest of the codes on another loop outside the void loop. the buttons would work okay but the other function loop will not work
Below is the code for the first (1) scenario..
#include <LiquidCrystal.h>
#include <dht.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
dht DHT;
#define DHT11_PIN A0
#define DHTTYPE DHT11 DHT dht(DHTPIN, DHTTYPE);
int ledRed = 8;
int ledGreen = 9;
int ledYellow = 10;
int Buzzer = 6;
int frequency = 50;
int buttonPin1 = 7;
int buttonPin2 = 13;
int activeButtonstate1;
int activeButtonstate2;
int stndtemp = 0;
int range = 2;
int heat = A1;
int fan = A2;
void setup(){
//Initialize Serial Monitor
//Setting Up INPUT and OUTPUT Pins
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
pinMode(Buzzer, OUTPUT);
pinMode(ledRed, OUTPUT);
pinMode(ledYellow, OUTPUT);
pinMode(ledGreen, OUTPUT);
digitalWrite(buttonPin1,LOW);
digitalWrite(buttonPin2,LOW);
//Initializing LCD
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("Set Your Control");
lcd.setCursor(0,1);
lcd.print("Temp In Degree C");
delay(2000);
lcd.clear();
void loop(){
//Declaring Variables
int chk = DHT.read11(DHT11_PIN);
int temperature = DHT.temperature;
int humidity = DHT.humidity;
int buttonState1 = digitalRead(buttonPin1);
int buttonState2 = digitalRead(buttonPin2);
int celsius = ((((5.0/1023.0)*temperature)*100) * 2);
//Prints the Sensor Reading on LCD
lcd.setCursor(0,0);
lcd.print("Sys Temp:"); //
lcd.print(celsius);
lcd.print((char)223);
lcd.print("C");
//I WOULD USE THE BUTTONS TO SET THE TEMPERATURE RANGE THE SYSTEM SHOULD WORK ON
//If Button 1 is Pressed Increase Set-Point Temperature Value by 1
if (buttonState1 == HIGH){
if (stndtemp<150){
stndtemp++;
//If Button 2 is Pressed Decrease Set-Point Temperature Value by 1
if (buttonState2 == HIGH){
if (stndtemp>0){
stndtemp--;
//Display the Set point Temperature on the LCD for Me to see After the Buttons have been Pressed
lcd.setCursor(0,1);
lcd.print("Set Temp:");
lcd.print(stndtemp);
lcd.print("C");
//Use the Lower Limit and Upper Limit Working Temperature on LCD
lcd.setCursor(0, 1);
lcd.print("LT= "); //Lower Limit
lcd.print(stndtemp); //My Set-Point Temperature is the Lower Limit
lcd.print(" HT= "); //Upper Limit
lcd.print(stndtemp + range); //My Upper Limit Temperature is the Set-Point + a certain value (range)
//---------THESE ACTIONS SHOULD ONLY EXECUTE AFTER THE BUTTONS HAVE BEEN PRESSED -----------------
// -------- AND THE LOOP SHOULD RETURN FROM HERE UNTIL THE BUTTON IS PRESSED AGAIN -------
//Compare the Temperature I have Set (Set-Point) to the Temperature Reading of the Environment
//and then Take an Action if there is any difference between them
if (celsius < stndtemp){
digitalWrite(ledRed,HIGH); //Turn on Red LED
digitalWrite(heat, HIGH); //Turn on the Heater
digitalWrite(fan, LOW); //Turn off the Fan
tone(Buzzer,1000); //Turn on Alarm
noTone(Buzzer); //
else if (celsius > (stndtemp+range)){
digitalWrite(ledYellow,HIGH); //Turn on Yellow LED
digitalWrite(heat, LOW); //Turn Off the Heater
digitalWrite(fan, HIGH); //Turn On the Fan
noTone(Buzzer);
lcd.print("Fan is On"); //Print on the LCD
else {
digitalWrite(ledGreen, HIGH); //Turn on Green LED
lcd.print("Temp is OKAY"); //Print on the LCD
return;
Please, i really need help am stocked here
You've got a lot of delay() statements in your loop there. You know nothing else can happen during during a delay(), yeah?
Welcome to the Forum. Please read these two posts:
General Guidance and How to use the Forum
and
Read this before posting a programming question ...
You may also find useful information that would answer your question here:
Useful links - check here for reference posts / tutorials
You have posted code without using code tags. The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click. Also, if you don't do it, some of the character sequences in the code can be misinterpred by the forum code as italics or funny emoticons. The "Code: [Select]" feature allows someone to select the entire sketch so it can be easily copied and pasted into the IDE for testing or review.
If you have already posted without using code tags, open your message and select "modify" from the pull down menu labelled, "More", at the lower right corner of the message. Highlight your code by selecting it (it turns blue), and then click on the "</>" icon at the upper left hand corner. Click on the "Save" button. Code tags can also be inserted manually in the forum text using the code and /code metatags.
