PROBLEM USING SWICTH (state)
Hello
I have a problem in creating a control system using Arduino programming.
I use the SWITCH (state) command for a repetition process as follows:
SWITCH (state)
case A:
if (condition 1);
state B
else if (condition 2);
state C
else if (condition 3);
state D
case B:
contains processes with many commands involving delay timers;
state A;
case C:
state A;
case D:
command to stop all process B or process C;
state A;
The problem is that if at the beginning we give the command for condition 1 or condition 2 and during the process condition 1 or condition 2 is running then we give the command condition 3 then the program will not carry it out and will still carry out condition 1 or condition 2.
Even though each case has been returned to state A.
The question is how to ensure that the condition 3 command can be executed when the program is executing condition 1 or condition 2.
Thank You.
Please show your real rather than pseudo code, because the code below is non-sense:
Use the flag variable. Set the flag when condition 1 or condition 2 are meet. Test the flag and execute command 3 only if flag is set.
why don't you check for conditions 1 and 2 while in states B & C?
did you add also the break ?
SWITCH (state)
case A:
  if (condition 1) state B
  else if (condition 2) state C
  else if (condition 3) state D
case B:
  state A;
case C:
  state A;
case D:
  state A;
mind the semicolon after the conditions in your if and don't use local variables in the cases unless you add a compound statement around them with {....}
Was given a break but still failed
post the real code then... we can't make guesses on pseudo code
You seem to have not yet understood how switch-case
and
switch-case-break; works
program starts in state "A"
state "A"
the one and only thing that state "A" is doing
it checks if condition_1 is fullfilled
when condition_1 IS fullfilled change to state "B"
state "B"
state "B" does the B-processes (with many commands involving delaytimer)
and
state "B" checks if condition_2 is fullfilled
when condition_2 IS fullfilled change to state "C"
state "C"
state "C" does the C-processes (with many commands involving delaytimer)
and
state "C" checks if condition_3 is fullfilled
when condition_3 IS fullfilled change to state "D"
this makes no sense:
state "D" stop the processes that were executed in state "B"
and
stop the processes that were executed in state "C"
You should either post the REAL code or
As there might be a misconception about how the code works
You should write a normal worded
do you understand normal worded means
avoid each and every programming-term and avoid each and every C++-language element
and only use normal words to describe the wanted functionality
best regards Stefan
I too had problems with switch and if block. At that moment I solved choosing a different path... hehe! no time to go that way...
without details your message seems useless
Below I provide code written in normally worded.
Please check the AUTO case, where the last ELSE IF was not implemented by the program when I pressed the STOP button
SWITCH (state)
case AUTO:
if relay_auto active,
state AA.
Else if PB_auto is pressed,
-activate relay_auto
-print lcd (0,1) "AUTO"
-state AA.
Else if PB_stop_auto is pressed,
-deactivate relay_forward,
-deactivate relay_reverse,
-activate relay_forward
-print lcd (12,1) "MoveUp "
-state STOP
case STOP:
if PB_ls1 is pressed
-print lcd (12,1) "Top "
-deactivate relay_bvo
-activate relay_bvc
-print lcd (0,4) "BV:C"
-deactivate relay_auto
-state AUTO
case AA:
-deactivate relay_bvc
-activate relay_bvo
-print lcd (0,4) "BV:O"
-delay(2000) //open
  • activate relay_reverse
    -print lcd (12,1)"MoveDown"
  • delay (7000) //down
  • deactivate relay_reverse
    -print lcd (12,1) "Bottom "
    -activate relay_filling
    -print lcd (12,1) "Filling "
  • delay (2000) //filling
    -deactivate_relay_filling
  • activate relay_forward
  • deactivate relay_empty
  • state AB
case AB:
if relay_empty inactive
-state AB1
else if relay_empty active
-state AB2
case AB1: //naik2
if PB_ls2 is pressed
-activate relay_bvc
-delay (2000) //bv close
-state AC
case AB2:
-if PB_ls2 is pressed
-activate relay_emptying
-print lcd (12,1) "Emptying"
-delay (2000) //emptying
-deactivate relay_emptying
-state AC
case AC:
-state AC1
-state AC2
case AC1:
-state AD
case AC2:
-activate relay_bvo
-state AD
case AD:
if PB_ls3 is pressed
-activate relay_reverse
-print lcd (12,1) "MoveDown"
-activate realy_empty
-state AB
else if PB_ls4 is pressed
-state AUTO
that's totally useless.
As we say around here, our crystal ball is in the dishwasher...
if that's the code
then the C++ norm states that the MCU won't even evaluate condition2 and condition3 if condition1 is true
if you want them to be still evaluated then do
if (condition1) state B
if (condition2) state C
if (condition3) state D
with the risk of course that if two conditions are true then the last state set wins
not code normally worded
normally worded
functionality
by
avoiding
each and every similarity to code
if you do not understand how to do that
the simpelst way is to post your
complete sketch
using this method
best regards Stefan
after simulated but not work or fail
Ok this turned into nonsense-amusement.
If you tripple-couple the flux-compensator into a for-loop while praying 42 - 42 - 42
everything will work
mine as well :grinning:
