#include <EEPROMex.h>
EEPROM.setMemPool(0, EEPROMSizeUno);
EEPROM.setMaxAllowedWrites(EEPROMSizeUno * 2); // I don't understand why *2 (it was just trial and error) but if it doesn't report errors. I think the library has "unpolished" details.
// clear_eeprom
for (int i = 0 ; i < EEPROMSizeUno ; i++) {
EEPROM.write(i, 0);
All 0xFF is the "erased" state of the EEPROM. If you execute an EEPROM erase as part of an upload, that is the value all EEPROM locations will be set to.
If you read any cell after doing that how do you know whether the EEPROM has been "erased" or whether 0xFF happens to have been saved in that cell ?
No different from using 0x00 - how do you tell if that is your "erased" state or whether 0x00 happens to be saved in the cell? There is no way to tell, regardless of what value you choose to represent "erased".
Here are the equivalent functions in the EEPROM library.
Note that get() and put() will read/write the appropriate number of bytes needed for the data type of the variable. This also works for structures and arrays. Additionally, put() uses the EEPROM update() function, reading the value from each EEPROM location and only writing data if it is different.
traveled_distance = EEPROM.readFloat(0); //EEPROMEx
EEPROM.get(0, traveled_distance); //EEPROM
EEPROM.writeFloat (0, traveled_distance); //EEPROMEx
EEPROM.put(0, traveled_distance); //EEPROM
That is exactly what I said
So how does writing 0xFF to all locations, as espoused by @GolamMostafa, count as erased ? Initialised, maybe, but not erased
Unless it is the result of the physical construction of EEPROM, it is likely a hold-over from the early UV-erasable EPROM, where exposure to UV light would result in all bits being set to 1.
Excerpt from net:
There are two common methods for erasure:
a. UV Erasure (older technology): In older EEPROMs, erasure was achieved by exposing the memory chip to ultraviolet (UV) light. The UV light causes the charge trapped in the memory cells to dissipate, resetting them to their erased state.
b. Electric Field-Based Erasure (modern technology): In modern EEPROMs, electric field-based erasure is used. High voltage (typically in the range of 10-20V) is applied across the memory cells, which creates an electric field that allows electrons to tunnel through the thin oxide layer that separates the floating gate (where data is stored) from the control gate. This process removes the stored charge, effectively erasing the memory cell.
I have this error when using and verify sketch
exit status 1
no matching function for call to 'EEPROMClass::get(int)'
I have this error
Please post complete code that demonstrates the error.
Did you include the header file for the EEPROM library?
OK .I POST
#include "PinChangeInterrupt.h" // enables the interrupts at the other pin except the ones at the digital pins 2 and 3
#include <avr/sleep.h> // enables the sleep function
#include <avr/power.h> // power management
#include <EEPROMex.h> // enables some special functions for writing to and reading from EEPROM
#include <EEPROMVar.h>
#include <Wire.h> // IIC LIBRARY
#include "RTClib.h" // Real Time Clock Library
#include <math.h> // enables complex math functions
#include <Adafruit_SSD1306.h> // library for the OLED and graphics
#include <Adafruit_GFX.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
RTC_DS3231 rtc;
// variables declaration
volatile static float vss_pulse_distance = 1260;
volatile float LLG_injector_flow;
volatile static float unleadedFlow = 173e-11;
byte LLG1, LLG2, LLG3, LLG4, digitLLG, pos = 0;
volatile unsigned long vss_pulses;
volatile float traveled_distance, traveled_distance2, traveled_distance3, seconds_passed, speed, avg_speed, distance_to_LLGstation;
volatile float used_LLG, used_LLG2, instant_LLG_consumption, avg_LLG_consumption, LLG_in_tank, Full_tank = 49;
volatile float used_Unleaded, used_Unleaded2;
volatile float average_L_100km_Unlead;
volatile unsigned long unleadTime1=0, unleadTime2=0, unleadinj_Open_Duration=0;
volatile unsigned long LLG_injector_open_duration = 0, injTime1=0, injTime2=0;
int postemp;
int vss_pin = 2; // VSS signal input at digital pin 2 (INT0)
int LLG_pin = 3; // LLG injector signal input at digital pin 3 (INT1)
int ignition_pin = 19; // ignition signal input
int unleaded_pin = 12; // Unleaded injector signal input
boolean buttonState, buttonState2;
boolean lastButtonState2 = HIGH;
long lastDebounceTime = 0, logohold, counter, counter2;
volatile boolean ignition = false;
boolean ignoreRelease = false;
boolean inst_disp = true;
byte menunumber = 0, menunumbermax = 10;
int h=0, m=0, s, m1;
boolean timeRead = false, displaychange = true;
float thermReading, steinhart;
boolean dots = true;
//Below are the variables declaration for the thermistor -- you can find more info at: https://learn.adafruit.com/thermistor/using-a-thermistor
#define THERMISTORPIN A0
#define THERMISTORNOMINAL 10000
#define TEMPERATURENOMINAL 25
#define NUMSAMPLES 5
#define BCOEFFICIENT 3630
#define SERIESRESISTOR 10000
int samples[NUMSAMPLES];
int i=0;
const unsigned char leaf [] PROGMEM= {
0x00, 0x00, 0x07, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x07, 0xFF, 0xFF, 0x00, 0x3F, 0xFC, 0x1E,
0x00, 0xFF, 0x80, 0x1C, 0x01, 0xFC, 0x00, 0x3C, 0x07, 0xF0, 0x00, 0x38, 0x0F, 0xC0, 0x00, 0x38,
0x1F, 0x00, 0x00, 0x70, 0x1E, 0x00, 0x00, 0x70, 0x3C, 0x00, 0x80, 0x70, 0x38, 0x03, 0xC0, 0x70,
0x70, 0x07, 0xC0, 0x70, 0xF0, 0x1F, 0x80, 0x70, 0xF0, 0x1E, 0x00, 0x70, 0xE0, 0x3E, 0x00, 0x70,
0xE0, 0x78, 0x00, 0x70, 0xE0, 0xF0, 0x00, 0xF0, 0xE1, 0xE0, 0x00, 0xF0, 0xE3, 0xE0, 0x00, 0xE0,
0xE3, 0x80, 0x00, 0xE0, 0xE7, 0x80, 0x01, 0xE0, 0xEF, 0x00, 0x03, 0xE0, 0xEE, 0x00, 0x03, 0xC0,
0xFE, 0x00, 0x07, 0x80, 0x7C, 0x00, 0x1F, 0x00, 0x7C, 0x00, 0xFE, 0x00, 0x3D, 0xFF, 0xFC, 0x00,
0x39, 0xFF, 0xF0, 0x00, 0x70, 0xFE, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00
const unsigned char dist_to_LLG [] PROGMEM= {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFE, 0x00,
const unsigned char average [] PROGMEM= {
0x00, 0x00, 0x07, 0xCE, 0x1F, 0xFE, 0x3F, 0xFE, 0x7C, 0x7C, 0x70, 0xFC, 0xF1, 0xFE, 0xE3, 0xEE,
0xE7, 0xCE, 0xEF, 0x8E, 0xFF, 0x1E, 0x7E, 0x1C, 0x7C, 0x7C, 0xFF, 0xF8, 0xFF, 0xF0, 0xE7, 0xC0
const unsigned char averagecons [] PROGMEM= {
0x00, 0x00, 0x01, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x07, 0xCE, 0x01, 0xFF, 0xFE, 0x00, 0x00, 0x00,
0x1F, 0xFE, 0x01, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x3F, 0xFE, 0x01, 0xC0, 0x0E, 0x20, 0x00, 0x00,
0x7C, 0x7C, 0x01, 0xC0, 0x0E, 0x70, 0x00, 0x00, 0x70, 0xFC, 0x01, 0xC0, 0x0E, 0x38, 0x00, 0x00,
0xF1, 0xFE, 0x01, 0xC0, 0x0E, 0x1C, 0x00, 0x00, 0xE3, 0xEE, 0x01, 0xC0, 0x0E, 0x0C, 0x00, 0x00,
0xE7, 0xCE, 0x01, 0xC0, 0x0F, 0x8C, 0x00, 0x00, 0xEF, 0x8E, 0x01, 0xC0, 0x0F, 0x8C, 0x00, 0x00,
0xFF, 0x1E, 0x01, 0xC0, 0x0F, 0x8C, 0x00, 0x00, 0x7E, 0x1C, 0x01, 0xFF, 0xFF, 0x8C, 0x00, 0x00,
pinMode(5, INPUT); // Button 2
pinMode(6, INPUT); // Button 1
pinMode(vss_pin, INPUT);
pinMode(LLG_pin, INPUT);
pinMode(ignition_pin, INPUT);
pinMode(unleaded_pin, INPUT);
// below recalls the values stored in case of power loss
traveled_distance2 = EEPROM.readFloat (5);
used_LLG = EEPROM.readFloat (10);
used_LLG2 = EEPROM.readFloat(15);
LLG_in_tank = EEPROM.readFloat(20);
seconds_passed = EEPROM.readFloat(25);
used_Unleaded = EEPROM.readFloat(30);
traveled_distance3 = EEPROM.readFloat (35);
used_Unleaded2 = EEPROM.readFloat(45);
LLG1 = EEPROM.readByte (40);
LLG2 = EEPROM.readByte (41);
LLG3 = EEPROM.readByte (42);
LLG4 = EEPROM.readByte (43);
LLG_injector_flow = (LLG1 * 1000 + LLG2 * 100 + LLG3 * 10 + LLG4) * 1e-11;
noInterrupts();
// set and initialize the TIMER1
TCCR1A = 0; // set entire TCCR1A register to 0
TCCR1B = 0; // set entire TCCR1B register to 0
TCCR1B |= (1 << CS12);
TIMSK1 |= (1 << TOIE1);
TCNT1 = 3036;
attachPCINT(digitalPinToPinChangeInterrupt(ignition_pin), ignitionSignal, CHANGE);
interrupts();
delay(10);
{// When the ignition switch is turned, executes the next two ifs
if (ignition == false && digitalRead(19) == LOW)
detachInterrupt(digitalPinToInterrupt(vss_pin));
detachInterrupt(digitalPinToInterrupt(LLG_pin));
detachPCINT(digitalPinToPinChangeInterrupt(unleaded_pin));
delay(50);
ignition = true;
if (menunumber == 11)
EEPROM.writeByte(40, LLG1); //stores the new LLG coef.
EEPROM.writeByte(41, LLG2);
EEPROM.writeByte(42, LLG3);
EEPROM.writeByte(43, LLG4);
inst_disp = false;
menunumber = 0;
if (menunumber == 12) // same as previous for "Time Set" menu
DateTime dt = rtc.now();
s = dt.second();
if (m != m1) s = (((millis() - counter)/1000))%60;
else s = dt.second(), m = dt.minute();
rtc.adjust(DateTime(dt.year(), dt.month(), dt.day(), h, m, s));
ignoreRelease = true;
lastButtonState2 = LOW;
menunumber = 8;
// when the ignition switched off it stores the values to the EEPROM
EEPROM.writeFloat (5, traveled_distance2);
EEPROM.writeFloat (10, used_LLG);
EEPROM.writeFloat (15, used_LLG2);
EEPROM.writeFloat (20, LLG_in_tank);
EEPROM.writeFloat (25, seconds_passed);
EEPROM.writeFloat (30, used_Unleaded);
EEPROM.writeFloat (35, traveled_distance3);
EEPROM.writeFloat (45, used_Unleaded2);
display.ssd1306_command(SSD1306_DISPLAYOFF);
sleep_enable(); // enables the sleep mode
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // set the sleep mode
cli();
sleep_disable(); // disables the brown out detector to consume less power while sleeping
sei();
sleep_mode(); // microcontroller goes to sleep
// when it wakes up continues from here -- also the first time we turn the ignition key to ON starts from here
if (ignition == false && digitalRead(9) == LOW)
ignition = true; // this variable is needed in order to run once the code inside this if
logohold = millis(); // hold the LOGO screen on, for 2 sec
inst_disp = false;
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.drawBitmap(0, 0, average, 128, 64, WHITE);
display.display();
attachInterrupt(digitalPinToInterrupt(vss_pin), distance, RISING); // attaches the interrupt which related to the VSS signal
attachInterrupt(digitalPinToInterrupt(LLG_pin), LLG_injector_time, CHANGE); // interrupt for LLG injector signal
attachPCINT(digitalPinToPinChangeInterrupt(unleaded_pin), UnleadedTime, CHANGE); // petrol injector signal input and interrupt
while (millis() - logohold < 2000) ;
// every 5sec calculates average LLG consumption, remaining distance accordingly to the calculated remaining fuel in tank, average speed and average Unleaded cons.
if(millis()%88000 < 50)
avg_LLG_consumption = 100 * used_LLG2/traveled_distance2;
distance_to_LLGstation = 100 * LLG_in_tank/avg_LLG_consumption;
avg_speed = (traveled_distance3 / seconds_passed)*3600;
average_L_100km_Unlead = 100 * used_Unleaded2/traveled_distance2;
// For the short and long press function I consulted: http://jmsarduino.blogspot.gr/2009/05/click-for-press-and-hold-for-b.html
// There are many differences though
// "button 1" -- only SHORT PRESS function -- changes occur on press, because there is no LONG PRESS function
if (digitalRead(6) != buttonState) {
buttonState = digitalRead(6);
if (buttonState == HIGH)
if (menunumber <= menunumbermax){ // changes the display indications forwards
if (menunumber == menunumbermax) menunumber =0;
else menunumber += 1;
if (menunumber == 12) //if we are at the "Time Set" menu it changes the Hour
if (h < 23) h += 1, counter = millis();
else h = 0, counter = millis();
// if we are at the "LLG Coef." menu it changes the LLG_injector_flow digits
if (menunumber == 11 && digitLLG == 1){
if (LLG1 < 9) LLG1 += 1, counter = millis();
else LLG1 = 0, counter = millis();
if (menunumber == 11 && digitLLG == 2){
if (LLG2 < 9) LLG2 += 1, counter = millis();
else LLG2 = 0, counter = millis();
if (menunumber == 11 && digitLLG == 3){
if (LLG3 < 9) LLG3 += 1, counter = millis();
else LLG3 = 0, counter = millis();
if (menunumber == 11 && digitLLG == 4){
if (LLG4 < 9) LLG4 += 1, counter = millis();
else LLG4 = 0, counter = millis();
////////// "button 2" functions /////////////////
buttonState2 = digitalRead(5);
if (buttonState2 == LOW && lastButtonState2 == HIGH) lastDebounceTime = millis(); //keeps the time that button2 pressed
if (buttonState2 == HIGH && lastButtonState2 == LOW)
if (ignoreRelease == false) // "button 2" SHORT PRESS functions -- on release
{ if (menunumber == 0) menunumber = menunumbermax;
else menunumber = menunumber - 1;
{ if (m < 59) m=m+1, counter = millis();
else m = 11, counter = millis();
if (menunumber == 11) // LLG coef. setting menu -- "button 2" short press changes the position of the cursor
{ pos += 18;
digitLLG += 1;
counter = millis();
if (digitLLG == 5)
{ pos = 0;
digitLLG = 1;
else ignoreRelease = false;
//////////////////// "button 2" LONG PRESS functions /////////////////////////////////////////////////////
if (digitalRead(5) == HIGH) displaychange = true;
if (buttonState2 == LOW && (millis() - lastDebounceTime) > 3000 && displaychange == true) // below are the long press functions for button 2
if (menunumber == 0) menunumber = 11, counter = millis(), counter2 = millis(), displaychange = false, digitLLG = 1; //goes to the "LLG Coef." menu
if (menunumber == 1) traveled_distance2 = 0, used_LLG2 = 0, avg_LLG_consumption = 0, used_Unleaded2 = 0;// average LLG consumption and average Unleaeded cons. reset
if (menunumber == 3) traveled_distance3 = 0, seconds_passed = 0, avg_speed = 0; // average speed reset
if (menunumber == 4) traveled_distance = 0; //traveled Distance = 0
if (menunumber == 6) used_LLG = 0; // total LLG litres = 0
if (menunumber == 7) LLG_in_tank = Full_tank; // LLG tank reset to full
if (menunumber == 8) menunumber = 12, counter = millis(), counter2 = millis(), timeRead = true, displaychange = false; //goes to the "Time Setting" menu
if (menunumber == 9) traveled_distance2 = 0, used_LLG2 = 0, avg_LLG_consumption = 0, used_Unleaded2 = 0; // same with menunumber = 1
if (menunumber == 10) used_Unleaded = 0; // total unleaded fuel reset
lastButtonState2 = buttonState2;
// below are the misc screens
switch (menunumber)
case 0:
cons1: display.clearDisplay();
if(inst_disp == true) displaychange = false, inst_disp = false, digitLLG = 0, pos = 0;
display.setTextColor(WHITE);
display.drawBitmap(0, 0, average, 32, 32, WHITE);
display.setCursor(40, 0);
display.setTextSize(1);
display.print(F("LLG"));
display.setCursor(40,12);
display.setTextSize(2);
if (speed > 2) display.print(F("l/100km"));
else display.print(F("l/h")); //when the car is stopped displays the instant consumption in l/h
display.setCursor(0,36);
display.setTextSize(4);
if(instant_LLG_consumption > 99.9) display.print(F("--.-"));
else display.print(instant_LLG_consumption,1);
display.display();
case 1:
display.drawBitmap(0, 0, averagecons, 64, 32, WHITE);
display.setCursor(54, 0);
display.setCursor(54,15);
display.print(F("l/100"));
display.setCursor(0, 36);
if(isnan(avg_LLG_consumption)|| isinf(avg_LLG_consumption)) display.print(F("---"));
else display.print(avg_LLG_consumption, 1);
display.display();
case 2:
display.drawBitmap(49, 1, average, 32, 32, WHITE);
display.print(speed, 0);
display.setCursor(84, 34);
display.print(F("km"));
display.setCursor(104, 37);
display.setTextSize(3);
display.print(F("/"));
display.setCursor(115, 48);
display.print(F("h"));
display.display();
case 3:
display.drawBitmap(31, 0, average, 64, 32, WHITE);
display.print(avg_speed, 0);
display.display();
case 4:
display.drawBitmap(48, 0, average, 32, 32, WHITE);
display.setCursor(88,18);
display.print(traveled_distance, 1);
display.display();
case 5:
display.drawBitmap(0, 0, dist_to_LLG, 128, 32, WHITE);
if(distance_to_LLGstation < 10 || isnan(distance_to_LLGstation) || isinf(distance_to_LLGstation) ) display.print(F("---"));
else display.print(distance_to_LLGstation,0);
display.setCursor(90,48);
display.display();
case 6:
display.drawBitmap(0, 0, leaf, 32, 32, WHITE);
display.setCursor(40, 2);
display.print(F("Total"));
display.setCursor(40, 12);
display.print(used_LLG,1);
display.print(F("l"));
display.display();
case 7:
if (LLG_in_tank <= 0 ) display.print(F("0.0"));
else display.print(LLG_in_tank,1);
display.setCursor(105,43);
display.display();
case 8:
temp1: if(inst_disp == true) displaychange = false, inst_disp = false;
printTemperature();
display.drawFastHLine(0, 28, 128, WHITE);
display.drawFastHLine(0, 29, 128, WHITE);
display.setCursor(7, 36);
printTime();
if(steinhart < 3.5)
display.drawBitmap(0, 3, average, 16, 16, WHITE);
display.display();
case 9:
display.drawBitmap(0, 8, average, 16, 16, WHITE);
display.drawBitmap(17, 0, average, 32, 32, WHITE);
display.setCursor(54,13);
if(isnan(average_L_100km_Unlead)|| isinf(average_L_100km_Unlead)) display.print(F("---"));
else display.print(average_L_100km_Unlead, 1);
display.display();
case 10:
display.drawBitmap(96, 0, average, 32, 32, WHITE); //(x,y, name, DX, DY, color)
display.setCursor(0, 0);
display.setCursor(0, 10);
display.print(F("Unleaded"));
display.print(used_Unleaded,1);
display.display();
// the following are secondary displays and activated only in case we want to set the LLG Coef.(case 11) or the Time (case 12)
case 11: // LLG Coef. Setting menu
display.setCursor(0,9);
display.print(F("LLG Coef."));
display.print(LLG1);
display.print(LLG2);
display.print(LLG3);
display.print(LLG4);
display.setCursor(pos,42);
display.print(F("_"));
if (digitalRead(5) == HIGH) counter2 = millis(), displaychange = true; //we must release "button 2" at least once in order to be able to go back to instant LLG consuption
if ((digitalRead(5) == LOW && millis() - counter2 > 3000 && displaychange == true) || millis() - counter > 10000){
inst_disp = true;
menunumber = 0;
goto cons1;
display.display();
case 12: //RTC set
display.print(F("Time Set"));
if (timeRead == true){
h = dt.hour();
m = dt.minute();
m1 = dt.minute();
timeRead = false;
char sdt[15];
sprintf(sdt, "%02d:%02d", h, m);
display.print(sdt);
display.display();
if(digitalRead(5) == HIGH) counter2 = millis(), displaychange = true; //we must release the button 2 at least once in order to be able to go back to Temp and Time screen
if((digitalRead(5) == LOW && millis() - counter2 > 3000 && displaychange == true) || millis() - counter > 59000){
s = dt.second();
inst_disp = true;
menunumber = 8;
ISR(TIMER1_OVF_vect) //TIMER1 overflow interrupt -- occurs every 1sec --
instantSpeed();
LLG_Consumption();
LLG_injector_open_duration = 0;
unleadedConsumption();
unleadinj_Open_Duration = 0;
seconds_passed++;
vss_pulses = 0;
TCNT1 = 3036;
void distance()
vss_pulses++;
traveled_distance += vss_pulse_distance;
traveled_distance2 += vss_pulse_distance;
traveled_distance3 += vss_pulse_distance;
// we calculate 3 times the same thing in order to reset the distance, the average cons. and average speed independently
void instantSpeed()
speed = (vss_pulse_distance * vss_pulses * 3600);
// The following routine is giving the way to calculate the total time that LLG injector open during the 1sec interval
void LLG_injector_time()
injTime2 = micros();
if ((injTime2 - injTime1)<5400 && (injTime2 - injTime1)> 4)
LLG_injector_open_duration = LLG_injector_open_duration + injTime2 - injTime1;
injTime1 = injTime2;
void LLG_Consumption()
if (speed > 2 ) instant_LLG_consumption = (100*((LLG_injector_open_duration * LLG_injector_flow)*3600))/speed;
else instant_LLG_consumption = LLG_injector_open_duration * LLG_injector_flow * 3600; // when the car stops calculates the instant consumption in l/h
used_LLG = used_LLG + (LLG_injector_open_duration * LLG_injector_flow);
used_LLG2 = used_LLG2 + (LLG_injector_open_duration * LLG_injector_flow);
LLG_in_tank = LLG_in_tank - (LLG_injector_open_duration * LLG_injector_flow);
void UnleadedTime() // it is called every time a change occurs at the gasoline injector signal and calculates gasoline injector opening time, during the 1sec interval
if (digitalRead(12) == HIGH)
unleadTime1 = micros();
if (digitalRead(12) == LOW)
unleadTime2 = micros();
if (unleadTime2 > unleadTime1)
{if ((unleadTime2 - unleadTime1) > 500 && (unleadTime2 - unleadTime1) < 12000) // some conditions to avoid false readings because of noise
unleadinj_Open_Duration = unleadinj_Open_Duration + (unleadTime2 - unleadTime1); //total useconds that the gasoline injector opens throughout 1sec
void unleadedConsumption()
used_Unleaded = used_Unleaded + (unleadinj_Open_Duration * unleadedFlow);
used_Unleaded2 = used_Unleaded2 + (unleadinj_Open_Duration * unleadedFlow);
void ignitionSignal() // this is called everytime the ingintion signal changes -- if the microcontroller is in sleep mode, it will wake up
ignition = !ignition;
void printTime()
char sdt[15];
sprintf(sdt, "%02d:%02d", dt.hour(), dt.minute());
display.print(sdt);
void printTemperature()
for (i=0; i< NUMSAMPLES; i++) {
samples[i] = analogRead(THERMISTORPIN);
delay(10);
// average all the samples out
thermReading = 0;
thermReading += samples[i];
thermReading /= NUMSAMPLES;
// convert the value to resistance
thermReading = 1023 / thermReading - 1;
thermReading = SERIESRESISTOR / thermReading;
steinhart = thermReading / THERMISTORNOMINAL; // (R/Ro)
steinhart = log(steinhart); // ln(R/Ro)
steinhart /= BCOEFFICIENT; // 1/B * ln(R/Ro)
steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
steinhart = 1.0 / steinhart; // Invert
steinhart -= 273.15; // convert to C
//steinhart = (steinhart * 9.0)/ 5.0 + 32.0; // Uncomment if you want to convert Celcius to Fahrenheit
if (steinhart <0 && steinhart > -0.6){ //this is in order not to display "-0"
steinhart = 0;
if(steinhart >= 9.5 || (steinhart <= -0.6 && steinhart > -9.6)) postemp = 62; //postemp: the x position of the cursor is depended on how many characters the temp has (1, 2 or 3)
if(steinhart < 9.5 && steinhart > -0.6) postemp = 80;
if(steinhart <= -9.6) postemp = 44;
display.setCursor(postemp,0);
display.print(steinhart, 0);
display.setCursor(100, -2);
display.print(F("o"));
display.setCursor(108, 0);
display.print(F("C"));
Now please post the full error message. using code tags when you do
my sketch uses the eepromex library
Now the problem is to replace the eeprom library with the eeprom.h library
The posted code makes not attempt to convert to EEPROM.h.
You said that you were going to convert, so please post your best effort to do so.
ok this frist try
#include <EEPROM.h> // enables some special functions for writing to and reading from EEPROM
RTC_DS3231 rtc;
int postemp;
int i=0;
traveled_distance = EEPROM.read (0);
traveled_distance2 = EEPROM.read (5);
used_LLG = EEPROM.read (10);
used_LLG2 = EEPROM.read( 15);
LLG_in_tank = EEPROM.read (20);
seconds_passed = EEPROM.read (25);
used_Unleaded = EEPROM.read (30);
traveled_distance3 = EEPROM.read (35);
used_Unleaded2 = EEPROM.read (45);
LLG1 = EEPROM.read (40);
LLG2 = EEPROM.read (41);
LLG3 = EEPROM.read (42);
LLG4 = EEPROM.read (43);
noInterrupts();
TCNT1 = 3036;
interrupts();
delay(10);
delay(50);
ignition = true;
EEPROM.write(40, LLG1); //stores the new LLG coef.
EEPROM.write(41, LLG2);
EEPROM.write(42, LLG3);
EEPROM.write(43, LLG4);
inst_disp = false;
menunumber = 0;
s = dt.second();
menunumber = 8;
EEPROM.put (0, traveled_distance);
EEPROM.put (5, traveled_distance2);
EEPROM.put (10, used_LLG);
EEPROM.put (15, used_LLG2);
EEPROM.put (20, LLG_in_tank);
EEPROM.put (25, seconds_passed);
EEPROM.put (30, used_Unleaded);
EEPROM.put (35, traveled_distance3);
EEPROM.put (45, used_Unleaded2);
cli();
sei();
inst_disp = false;
display.display();
{ pos += 18;
digitLLG += 1;
counter = millis();
if (digitLLG == 5)
{ pos = 0;
digitLLG = 1;
switch (menunumber)
case 0:
display.display();
case 1:
display.display();
case 2:
display.display();
case 3:
display.display();
case 4:
display.display();
case 5:
display.display();
case 6:
display.display();
case 7:
display.display();
case 8:
printTemperature();
printTime();
if(steinhart < 3.5)
display.display();
case 9:
display.display();
case 10:
display.display();
EEPROM.update(40, LLG1); //stores the new LLG coef.
EEPROM.update(41, LLG2);
EEPROM.update(42, LLG3);
EEPROM.update(43, LLG4);
inst_disp = true;
menunumber = 0;
goto cons1;
display.display();
case 12: //RTC set
h = dt.hour();
m = dt.minute();
m1 = dt.minute();
timeRead = false;
char sdt[15];
display.print(sdt);
display.display();
s = dt.second();
inst_disp = true;
menunumber = 8;
instantSpeed();
LLG_Consumption();
seconds_passed++;
vss_pulses = 0;
TCNT1 = 3036;
void distance()
vss_pulses++;
void instantSpeed()
void printTime()
char sdt[15];
display.print(sdt);
delay(10);
thermReading = 0;
steinhart = 0;
and now i have this log
Have I replaced the library correctly?
E:\trip visitor\BASE_SH1106_1.3_UNO___NON_INGINITION\BASE_SH1106_1.3_UNO___NON_INGINITION.ino: In function 'void loop()':
E:\trip visitor\BASE_SH1106_1.3_UNO___NON_INGINITION\BASE_SH1106_1.3_UNO___NON_INGINITION.ino:166:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
E:\trip visitor\BASE_SH1106_1.3_UNO___NON_INGINITION\BASE_SH1106_1.3_UNO___NON_INGINITION.ino:167:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
E:\trip visitor\BASE_SH1106_1.3_UNO___NON_INGINITION\BASE_SH1106_1.3_UNO___NON_INGINITION.ino:168:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
E:\mega_2560.ino:169:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
E:\mega_2560.ino:170:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
E:\mega_2560.ino:171:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
E:\mega_2560.ino:172:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
E:\mega_2560.ino:173:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
E:\mega_2560.ino:174:18: warning: implicit dereference will not access object of type 'const volatile float' in statement
Sketch uses 29768 bytes (11%) of program storage space. Maximum is 253952 bytes.
Global variables use 586 bytes (7%) of dynamic memory, leaving 7606 bytes for local variables. Maximum is 8192 bytes.
You are using variables declared as 'volatile', make a local copy of the variable (with interrupts temporarily disabled since you are using floats), then save the local copy to EEPROM. Accessing any 'volatile' variable larger than a single byte without disabling interrupts risks an interrupt occuring and changing the value between individual bytes.
goto cons1;
case 0:
if (inst_disp == true) displaychange = false, inst_disp = false, digitLLG = 0, pos = 0;
if (instant_LLG_consumption > 99.9) display.print(F("--.-"));
else display.print(instant_LLG_consumption, 1);
display.display();
Please no. Using a goto to jump from one case to another in a switch/case makes the code terribly convoluted. Just make the entire case 0 contents (except the break; ) into a functions, and call that in the two places it is needed.
The compiler does not like the use of volatile variables being passed to the .put() and .get() functions. I think it is related to the use of pointers here in the templates.
//Functionality to 'get' and 'put' objects to and from EEPROM.
template< typename T > T &get( int idx, T &t ){
EEPtr e = idx;
uint8_t *ptr = (uint8_t*) &t;
for( int count = sizeof(T) ; count ; --count, ++e ) *ptr++ = *e;
return t;
template< typename T > const T &put( int idx, const T &t ){
EEPtr e = idx;
const uint8_t *ptr = (const uint8_t*) &t;
for( int count = sizeof(T) ; count ; --count, ++e ) (*e).update( *ptr++ );
return t;
I think that one way to deal with this issue is to use a non volatile transfer variable to pass to .put() and .get().
This little piece of code gives the warning, but not for the transfered variable.
#include <EEPROM.h>
volatile float value = 123.45;
float transfer_value;
transfer_value = value;
EEPROM.put(0,value);
EEPROM.put(5, transfer_value);
void loop() {}
What happens if I use EEPROM.write or EEPROM.update instead of EEPROM.put?
You can't use .write() or .update() with multi byte variables like floats, ints, or longs.
When using .write() with a volatile byte variable, there is no compiler warning.
This is a very bad idea, but if you insist on not making a local copy of the volatile variable, you can cast it to a non-volatile float
noInterrupts();
EEPROM.put (0, (float)traveled_distance);
EEPROM.put (5, (float)traveled_distance2);
interrupts();
There is no guarantee the compiler will not treat this improperly and ignore the changes made in the interrupt routine, and it will be disabling interrupts for a long time, so if your interrupts are occurring too frequently you risk missing some. (it can take 3mS or more for an EEPROM write, so the millis count will be corrupted). ( < edit > this likely will not work at all, I can find some reference to the EEPROM library using interrupts itself)
You need to be using local copies of the volatile variables anyway, otherwise you risk getting corrupt values.
hi dear
I just want to replace the EEPROM library in the sketch with the EEPROMEX library, but I don't know what replacement command to use
This is my frist try
RTC_DS3231 rtc;
int postemp;
int i=0;
noInterrupts();
TCNT1 = 3036;
interrupts();
delay(10);
delay(50);
ignition = true;
inst_disp = false;
menunumber = 0;
s = dt.second();
menunumber = 8;
cli();
sei();
inst_disp = false;
display.display();
{ pos += 18;
digitLLG += 1;
counter = millis();
if (digitLLG == 5)
{ pos = 0;
digitLLG = 1;
switch (menunumber)
case 0:
display.display();
case 1:
display.display();
case 2:
display.display();
case 3:
display.display();
case 4:
display.display();
case 5:
display.display();
case 6:
display.display();
case 7:
display.display();
case 8:
printTemperature();
printTime();
if(steinhart < 3.5)
display.display();
case 9:
display.display();
case 10:
display.display();
inst_disp = true;
menunumber = 0;
goto cons1;
display.display();
case 12: //RTC set
h = dt.hour();
m = dt.minute();
m1 = dt.minute();
timeRead = false;
char sdt[15];
display.print(sdt);
display.display();
s = dt.second();
inst_disp = true;
menunumber = 8;
instantSpeed();
LLG_Consumption();
seconds_passed++;
vss_pulses = 0;
TCNT1 = 3036;
void distance()
vss_pulses++;
void instantSpeed()
void printTime()
char sdt[15];
display.print(sdt);
delay(10);
thermReading = 0;
steinhart = 0;
You first posted that you had written a sketch using eepromex. What is preventing you from going back to it? Does the eepromex template for storing multibyte values like .write(address, float) not produce compiler warnings about volatile variables?
I would recommend that you continue to use eeprom.h and use transfer variables to deal with the compiler issues.
I do not think the the syntax for an if conditional with multiple comma separated statements on one line will work as you intend.
Did you write this program. How does it function? Your original question was about erasing the eeprom. What problem were you trying to solve?
