hello, anyone knows why when I try to write into the setup in the SD card and I want to read into the loop from the data of SD card on the internet with the web server configuration and I can not. If you test only read or only write the code works but when do you try both at the same time not works
any idea, thanks
#include <SPI.h>
#include <SD.h>
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
#include <util.h>
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0x5C, 0x18};
EthernetServer server(80);
String readString;
File myfile;
pinMode(9, OUTPUT);
digitalWrite(9,LOW);
Serial.println("COMUNICACION SERIAL");
delay(2000);
SD.begin();
pinMode(4,OUTPUT);
if (SD.begin(4))
Serial.println("MICRSD");
if (!SD.begin(4))
Serial.println("MICRSD PROBLEMA");
delay(2000);
if (Ethernet.begin(mac) == 0)
Serial.println("PROBLEMA RED");
if (!Ethernet.begin(mac) == 0)
Serial.print("IP : ");
for (byte thisByte = 0; thisByte < 4; thisByte++)
Serial.print(Ethernet.localIP()[thisByte], DEC);
Serial.print(".");
delay(2000);
server.begin();
Serial.println("SERVER");
delay(2000);
myfile = SD.open("evento.txt",FILE_WRITE);
if (myfile)
Serial.println("WRITE DOC");
myfile.println("TEST SAVE DATA");
myfile.close();
Serial.println("DONE");
Serial.println("ERROR DOC");
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (readString.length() < 100) {
readString += c;
if (c == '\n') {
Serial.println(readString);
if(readString.indexOf('?') >=0) {
client.println("HTTP/1.1 204 Zoomkat");
client.println();
client.println();
else {
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>WEB SERVER READ/WRITE SD CARD</H1>");
client.println("
client.println("<a href='/?on' target='inlineframe'>ON</a>");
client.println("<a href='/?off' target='inlineframe'>OFF</a>");
client.println("<IFRAME name=inlineframe style='display:none'>");
client.println("</IFRAME>");
client.println("
client.println("
client.println("
client.println("</BODY>");
client.println("</HTML>");
myfile = SD.open("evento.txt");
if (myfile)
Serial.println("READ DOC");
while (myfile.available())
client.write(myfile.read());
myfile.close();
delay(1);
client.stop();
if(readString.indexOf("on") >0)
digitalWrite(9, HIGH);
Serial.println("Led On");
if(readString.indexOf("off") >0)
digitalWrite(9, LOW);
Serial.println("Led Off");
readString="";
