Greetings ... I commented that I have a problem when concatenating variables of type double to a string. It turns out that I am doing readings for the analog inputs, so also for the spi bus, and these readings I am storing them in an array for data of type double, and every so often I concatenate this data in a chain, where each data is separated by a character ';' then send it by bluetooth. The problem is that I can not concatenate all the readings and I do not understand why? In total there are 9 readings that I make, when concatenating and I only manage to concatenate 8 ... and there are times when there are only 7. Someone who can help me with this problem please. Thanks in advance.
I leave attached the code that I am using in addition to an image of the error I get..
#include <SPI.h>
#include <SdFat.h>
#include <LowPower.h>
#include <SoftwareSerial.h>
#include <Time.h>
#include <TimeLib.h>
#include <Adafruit_MAX31855.h>
SdFat SD;
File dataFile;
SoftwareSerial bluetooth(7,8);
Adafruit_MAX31855 thermo1(5,2,6);
Adafruit_MAX31855 thermo2(5,3,6);
Adafruit_MAX31855 thermo3(5,4,6);
char conf_inicial[55],aux;//array para recibir configuracion inicial
int time_ref[6]={0,0,0,0,0,0};//tiempo de referencia
double variables[9]={0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0};//array para guardar las variables de lectura
unsigned long actual,previo=0,periodo;//guardan valores de temporizacion y periodo de muestreo
int i,punt=0,ref,stringSize;//variables auxiliares
String paramRecta[8];//almacena cadena de parametros A y B de la recta
float param_Recta[8];//almacena valores de parametros A y B de la recta
String date_time="";
String data_var="";
String peakData="";
String dateReceiveBT="";
bluetooth.begin(57600);
thermo1.begin();
thermo2.begin();
thermo3.begin();
if(!SD.begin(SS)){
Serial.println("Memoria SD no presente o mal conectado");
while(true);
Serial.println("Esperando parametros");
while(!bluetooth.available());
while(bluetooth.available()>0){
conf_inicial[punt]=bluetooth.read();
punt++;
delay(10);
punt=0;
for(ref=0;ref<5;ref++){//separamos la hora y fecha de referencia
for(i=1;i>=0;i--){
time_ref[ref]+=(conf_inicial[punt]-48)*pow(10,i);
punt++;
for(i=3;i>=0;i--){//separamos el año
if(i==0){
conf_inicial[punt]++;
punt++;
switch(conf_inicial[punt]-48){//verificamos el intervalo de muestreo
case 1:
periodo=100;
case 2:
periodo=1000;
case 3:
periodo=10000;
case 4:
periodo=60000;
punt++;
for(ref=0;ref<8;ref++){//separamos la cadena de parametros de la recta
for(i=0;i<5;i++){
if(i==2){
paramRecta[ref]+=conf_inicial[punt];
punt++;
}else{
paramRecta[ref]+=(conf_inicial[punt]-48);
punt++;
param_Recta[ref]=paramRecta[ref].toFloat();
setTime(time_ref[0],time_ref[1],time_ref[2],time_ref[3],time_ref[4],time_ref[5]);//inicializamos hora y fecha de referencia
ref=0;
void loop(){
if(Serial.available()||bluetooth.available()){
if(Serial.available()>0){
aux=Serial.read();
if(aux=='1'){
dataFile = SD.open("lectura.txt");
if (dataFile) {
Serial.println("lectura.txt:");
while (dataFile.available()) {
Serial.write(dataFile.read());
dataFile.close(); //cerramos el archivo
Serial.println("Error al abrir el archivo");
}else{
aux=bluetooth.read()-48;
switch(aux){//verificamos el intervalo de muestreo
case 0:
SD.remove("lectura.txt");//eliminamos el archivo "lectura.txt"
dataFile = SD.open("lectura.txt",FILE_WRITE);//se crea nuevo archivo "lectura.txt"
dataFile.close();
bluetooth.print('1'); //notifica a Android que se realizo la limpieza de la memoria
case 1:
periodo=100;
case 2:
periodo=1000;
case 3:
periodo=10000;
case 4:
periodo=60000;
case 5:
Serial.println("El muestreo se ha detenido");
while(!bluetooth.available()){
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
aux=bluetooth.read();
Serial.println("El muestreo se ha retomado");
}else{
actual = millis();
if((actual-previo)>=periodo){
concTime();
date_time+=';';
for(ref=0;ref<9;ref++){
data_var+=variables[ref];
data_var+=';';
bluetooth.println(data_var);
Serial.println(data_var);
if(dataFile){
date_time+=data_var;
dataFile.println(date_time);
dataFile.close();
data_var="";
date_time="";
previo=millis();
}else{
variables[0] = (8.85*(analogRead(0)*(5/1023.0)))+0.87;//Voltaje de Bateria
variables[1] = (param_Recta[0]*(analogRead(1)*(5/1023.0)))-param_Recta[1];//Corriente de Bateria
if(variables[0]>20||variables[1]>100){
date_time+='*';
concTime();
date_time+='*';
bluetooth.println(date_time);
Serial.println(date_time);
if(ref==0||ref==1){
data_var+='
;data_var+=variables[ref];//concatenamos variables
}else{
data_var+=';';//concatenamos caracter de separacion
data_var+=variables[ref];//concatenamos los valores de las variables
dataFile = SD.open("lectura.txt", FILE_WRITE);
if(dataFile){
dataFile.close();
data_var="";
date_time="";
while(variables[0]>20||variables[1]>100){
if(ref==0||ref==1){
data_var+='
}else{
dataFile = SD.open("lectura.txt", FILE_WRITE);//abrimos el archivo lectura.txt
if(dataFile){
dataFile.println(data_var);
dataFile.close();
data_var="";
date_time="#";
concTime();
date_time+=';';
if(dataFile){//verificamos si existe el archivo en la memoria
dataFile.println(date_time);//guardamos el dato en la memoria
dataFile.close();//cerramos cesion con la memoria
data_var="";
date_time="";
variables[2] = (param_Recta[2]*(analogRead(2)*(5/1023.0)))-param_Recta[3];
variables[3] = (param_Recta[4]*(analogRead(3)*(5/1023.0)))-param_Recta[5];
variables[4] = (param_Recta[6]*(analogRead(4)*(5/1023.0)))-param_Recta[7];
variables[5] = thermo1.readCelsius();
variables[6] = thermo2.readCelsius();
variables[7] = thermo3.readCelsius();
variables[8] = 0.00;//Temperatura de PCB
void concTime(){
time_t t = now();
date_time+=month(t);
date_time+='/';
date_time+=day(t);
date_time+='/';//concatenamos caracter de separacion
date_time+=year(t);
date_time+=';';//concatenamos caracter de separacion
date_time+=hour(t);
date_time+=':';
date_time+=minute(t);
date_time+=':';
date_time+=second(t);
