Hello,
I am using servo library to control the motor speed and at the same time using the interrupt to get the speed feedback. The interrupt I use for encoder is 2 and 3, also I set the pin pull-up resistor. If I do so, the motor will rotate back and forth, without control. If I do not use the pull-up resistor, the motor can be controlled. But I can't get the feedback speed. Does anyone know why is that? Thanks!
There's a problem with your code or your wiring.
Since you haven't posted either, we can't venture a guess on the specifics.
Can you provide more detail on just how this setup works, or is supposed to work?
