I am Wokrking on a project which uses UNO and MEGA
The MEGA is the transmitter , UNO the receiver.
MEGA has a 3x4 keypad and rf 433 mhz module which sends the keypresses via VIRTUALWIRE
The UNO has the receiver connected and a 16,2 LCD connected.
The motto of my project is to receive the keypress and print it on the LCD. However I also want a feature in the receiver where "IT PRINTS A SPACE OR A DOT ’ . ’ if no key is received for 3 seconds.
It should print the space or dot only once i.e.
Suppose I send 1234 and then wait for a few seconds, if the receiver does not get any keypresss from tx for 3 seconds it will print the dot once (not every 3 seconds)
then if i press after say 10 seconds 567, then the display should look like this
"“1234.567"”
Now here is the code of the receiver that i tried.
The question is shouldd i put this feature in tx that it should transmit the space ifi no key is pressed for 3 seconds or i should implement this in the receiver end .
and How?
the code is as follows for tx and rx
TRANSMITTER
#include <Keypad.h>
#include <VirtualWire.h>
#define ledPin 13
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] =
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {32,34,36,38}; //connect to row pinouts
byte colPins[COLS] = {40,42,44,46}; //connect to column pinouts
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
vw_setup(2000);
char msg[0];
char key=keypad.getKey();
if( key!=NO_KEY)
msg[0]=key; // load the array with the key character
msg[1]=NULL; // Rx side seems to work without this
digitalWrite(10,HIGH); // Flash a light to show transmitting
vw_send((uint8_t *)msg, strlen(msg)); // send the character out
Serial.println(key); // for debugging only
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(10,LOW);
delay(50); // need some delay or seem to miss key presses
RECEIVER
#include<LiquidCrystal.h>
const int receiver_pin = 12;
LiquidCrystal lcd(6,7,8,9,10,11);
vw_set_rx_pin(receiver_pin);
vw_setup(2000);
vw_rx_start();
lcd.begin(16,2);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if(vw_get_message(buf, &buflen))
digitalWrite(13,HIGH);
for(int i=0;i<buflen;i++)
Serial.print((char)buf[i]);
lcd.print((char)buf[i]);
delay(100);
digitalWrite(13,LOW);
Now i tried to edit the receiver part which only test the code for serial print rather than lcd.print(i will add the LCD later)
vw_setup(2000);
vw_rx_start();
lcd.begin(16,2);
int null;int i;
// lcd.print((char)buf[i]);
//delay(100);
if(delay(3000))
Serial.print(".");
Please help me if you understood the question as i think i have not explained perfectly .But may be you will understand my problem.
