Hi Folks,
i am using a DHT11 sensor and a DS1820 Sensor to read some data and write them to a connetced sd-card and to the usb-port, so i can catch the datas with pc-software - this works well.
Since now i pushed the pc datetime into the stream that was written to get a timestamp for the read datas.
i am using actual the follwoing libs:
#include <OneWire.h>
#include <SoftwareSerial.h>
#include <dht11.h>
#include <SPI.h>
#include <SD.h>
//#include <Wire.h>
//#include <RTClib.h>
Now i got a RTC DS1307 and connected it to the I2C-Pins on an UNO - this works well also, but only "stand alone", means the demo sketch is working fine.
when i then want to read the datas from within my sketch there a problem occurs- the chip resets after some seconds each time.
when i disable the <RTClib.h> and the <Wire.h> then all works fine (after REMming the parts which needs the libs)
Does anyone know what is going wrong ?
This is the demo code i am using and which works well:
// Date and time functions using just software, based on millis() & timer
#include <Wire.h>
#include "RTClib.h"
RTC_Millis RTC;
void setup () {
Serial.begin(57600);
// following line sets the RTC to the date & time this sketch was compiled
RTC.begin(DateTime(__DATE__, __TIME__));
void loop () {
DateTime now = RTC.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.print(" seconds since 1970: ");
Serial.println(now.unixtime());
// calculate a date which is 7 days and 30 seconds into the future
DateTime future (now.unixtime() + 7 * 86400L + 30);
Serial.print(" now + 7d + 30s: ");
Serial.print(future.year(), DEC);
Serial.print('/');
Serial.print(future.month(), DEC);
Serial.print('/');
Serial.print(future.day(), DEC);
Serial.print(' ');
Serial.print(future.hour(), DEC);
Serial.print(':');
Serial.print(future.minute(), DEC);
Serial.print(':');
Serial.print(future.second(), DEC);
delay(3000);
As you see, not really complicated code, even i the part at the buttom is not needed, only date and time.
As written, works fine - but not after implementing in my code.
