I get an error trying to deserialize a JSON response from my JavaScript backend.
The error from ArduinoJson says: NoMemory();
An example response would be:
{"from":"Bern","to":"Zürich HB","gleis":12,"lateInMinutes":0,"departure":"20:34","waggonsCount":14,"vias":0
My Code:
WiFi Web Server LED Blink
A simple web server that lets you blink an LED via the web.
This sketch will print the IP address of your WiFi module (once connected)
to the Serial Monitor. From there, you can open that address in a web browser
to turn on and off the LED on pin 9.
If the IP address of your board is yourAddress:
http://yourAddress/H turns the LED on
http://yourAddress/L turns it off
This example is written for a network using WPA encryption. For
WEP or WPA, change the WiFi.begin() call accordingly.
Circuit:
Board with NINA module (Arduino MKR WiFi 1010, MKR VIDOR 4000 and UNO WiFi Rev.2)
LED attached to pin 9
created 25 Nov 2012
by Tom Igoe
#include <SPI.h>
#include <WiFiNINA.h>
#include <ArduinoJson.h>
#include <ArduinoHttpClient.h>
#include <stdio.h>
#include <string.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key index number (needed only for WEP)
char serverAddress[] = "172.20.10.2"; // server address from Wifi. You can look up this adress in the settings
int port = 8080;
WiFiServer server(80);
DynamicJsonDocument postMessage(2048);
String jsonBody;
String contentType = "application/json";
DynamicJsonDocument doc(2720);
WiFiClient wifi;
HttpClient http = HttpClient(wifi, serverAddress, port);
char webpage[] = R"=====(
<html>
<head>
<meta charset="UTF-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>SBB Fahrplan</title>
</head>
<body>
<script>
const handleSubmit = () => {
const radioButtons = document.querySelectorAll('input[name="zug"]');
const abfahrt = document.getElementById('abfahrt').value
const ankunft = document.getElementById('ankunft').value
let selectedButton;
for (const radioButton of radioButtons) {
if (radioButton.checked) {
selectedButton = radioButton.value;
if (selectedButton === 'false') {
selectedButton = false
if (selectedButton === 'true') {
selectedButton = true
var myHeaders = new Headers();
myHeaders.append("Content-Type", "application/json");
var raw = JSON.stringify({
to: ankunft,
lastOne: selectedButton
var requestOptions = {
method: 'POST',
headers: myHeaders,
body: raw,
redirect: 'follow'
fetch("http://localhost:8080/getDataByTrip", requestOptions)
.then(response => response.json())
.then(result => console.log(result))
.then(fetch(`http://172.20.10.4/H?from=${abfahrt}&to=${ankunft}&lastOne=${selectedButton}`, {
method: "GET"
</script>
<h2>SBB Fahrplan</h2>
<label for="abbh">Abfahrts Bahnhof:</label>
<input type="text" id="abfahrt" name="Abfahrts Bahnhof" placeholder="Abfahrts Bahnhof">
<label for="anbh">Ankunfts Bahnhof:</label>
<input type="text" id="ankunft" name="Ankunfts Bahnhof" placeholder="Ankunfts Bahnhof">
<input type="radio" id="nzug" name="zug" value="false">
<label for="nzug">nächster Zug</label>
<input type="radio" id="lzug" name="zug" value="true">
<label for="lzug">letzter Zug</label>
<br><br>
<button onclick="handleSubmit()">ok</button>
<br><br>
<button onclick="handleTest()">Test</button>
</body>
</html>
void printWifiStatus()
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void percentDecode(char *src)
char *dst = src;
while (*src)
if (*src == '+')
src++;
*dst++ = ' ';
else if (*src == '%')
// handle percent escape
*dst = '\0';
src++;
if (*src >= '0' && *src <= '9')
*dst = *src++ - '0';
else if (*src >= 'A' && *src <= 'F')
*dst = 10 + *src++ - 'A';
else if (*src >= 'a' && *src <= 'f')
*dst = 10 + *src++ - 'a';
// this will cause %4 to be decoded to ascii @, but %4 is invalid
// and we can't be expected to decode it properly anyway
*dst <<= 4;
*dst |= *src++ - '0';
*dst |= 10 + *src++ - 'A';
*dst |= 10 + *src++ - 'a';
dst++;
*dst++ = *src++;
*dst = '\0';
int parseUrlParams(char *queryString, char *results[][2], int resultsMaxCt, boolean decodeUrl)
int ct = 0;
while (queryString && *queryString && ct < resultsMaxCt)
results[ct][0] = strsep(&queryString, "&");
results[ct][1] = strchrnul(results[ct][0], '=');
if (*results[ct][1])
*results[ct][1]++ = '\0';
if (decodeUrl)
percentDecode(results[ct][0]);
percentDecode(results[ct][1]);
ct++;
return ct;
int status = WL_IDLE_STATUS;
Serial.begin(9600); // initialize serial communication
pinMode(9, OUTPUT); // set the LED pin mode
// char *string = "?from=Zurich-HB&to=Bern&lastOne=false";
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE)
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true)
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION)
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while (status != WL_CONNECTED)
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid); // print the network name (SSID);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the web server on port 80
printWifiStatus(); // you're connected now, so print out the status
char url[70];
boolean done = false;
char responseCopy = "";
WiFiClient client = server.available(); // listen for incoming clients
char buf[100];
char *params[5][2];
if (client)
{ // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
String httpGetUrl = "";
while (client.connected())
{ // loop while the client's connected
if (client.available())
{ // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
// Serial.write(c); // print it out the serial monitor
if (c == '\n')
{ // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0)
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
// client.print("Click <a href=\"/H\">here</a> turn the LED on pin 9 on<br>");
client.print(webpage);
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
{ // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r')
{ // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
if (currentLine.startsWith("GET /H?from="))
httpGetUrl += currentLine;
httpGetUrl.remove(0, 7);
int http = httpGetUrl.indexOf(" HTTP/1.1");
httpGetUrl.remove(http, 9);
httpGetUrl.toCharArray(url, 100);
char *tests[] = {
url,
for (int i = 0; i < sizeof(tests) / sizeof(*tests); i++)
Serial.print("parsing \"");
Serial.print(tests[i]);
// copy test[i] into the buffer
// because the parser overwrites what is i the string it is passed.
strcpy(buf, tests[i]);
// parse the buffer into params[][]
int resultsCt = parseUrlParams(buf, params, 5, true);
// print off the results;
Serial.print("\" produced ");
Serial.print(resultsCt);
Serial.print(" parameters:");
for (int i = 0; i < resultsCt; i++)
Serial.print("param ");
Serial.print(i);
Serial.print(" name \"");
Serial.print(params[i][0]);
Serial.print("\", param \"");
Serial.print(params[i][1]);
Serial.print("\".");
postMessage["from"] = params[0][1];
postMessage["to"] = params[0][3];
postMessage["lastOne"] = params[0][5];
serializeJson(postMessage, jsonBody);
Serial.println("making POST request");
done = true;
// Check to see if the client request was "GET /H" or "GET /L":
// if (currentLine.endsWith("GET /H")) {
while (done)
http.post("/getDataByTrip", contentType, jsonBody);
// read the status code and body of the response
int statusCode = http.responseStatusCode();
String responseRequest = http.responseBody();
Serial.print("Json Body: ");
Serial.println(jsonBody);
Serial.print("Status code: ");
Serial.println(statusCode);
Serial.print("Response: ");
Serial.println(responseRequest);
DeserializationError error = deserializeJson(doc, responseRequest);
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.f_str());
return;
const char* from = doc["from"];
Serial.print("From Request: ");
Serial.println(from);
jsonBody = "";
if (responseRequest.length() > 10)
done = false;
done = false;
responseRequest = "";
// close the connection:
client.stop();
Serial.println("client disconnected");
Could someone help me solve this problem?
