Problem with "asm volatile ()" in my Sketch
I would like to save and restore GPIO registers on the stack for certain reasons. For this I wrote a small test program, which is not compiled without errors. Where is the problem? Why are the two registers "PORTB" and "DDRB" unknown?
The error messages (Arduino IDE 2.1, Arduino UNO):
C:\Users\Rudol\AppData\Local\Temp\cccgm7Sb.ltrans0.ltrans.o: In function loop':* *D:\Arduino\Tests\AsmPushPop/AsmPushPop.ino:40: undefined reference to DDRB'
D:\Arduino\Tests\AsmPushPop/AsmPushPop.ino:40: undefined reference to PORTB'* *D:\Arduino\Tests\AsmPushPop/AsmPushPop.ino:50: undefined reference to PORTB'
D:\Arduino\Tests\AsmPushPop/AsmPushPop.ino:50: undefined reference to `DDRB'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
... and my Sketch:
	UNO/Nano (ATMEGA328P): Test push/pop with assembler instructions
//==== Arduino-Standard: setup() ==========================
	pinMode(13,OUTPUT);	// Signal: Prozessor is running
        digitalWrite(13,HIGH);
	delay(2000);
	while(!Serial) delay(10);
	Serial.println("Test push / pop GPIO");
//==== Arduino-Standard: loop() ===========================
  //---- Save DDRB and PORTB con Stack ----
	asm volatile
    "PUSH R20 \n"
    "IN R20,DDRB \n"
    "PUSH R20 \n"
    "IN R20,PORTB \n"
    "PUSH R20 \n"
	digitalWrite(13,LOW);
	delay(250);
  //---- Restore PORTB / DDRB from stack ----
	asm volatile
    "POP R20 \n"
    "OUT PORTB, R20 \n"
    "POP R20 \n"
    "OUT DDRB, R20 \n"
    "POP R20 \n"
	delay(250);
I don't know the answer to your question, but I have successfully used DDRB and PORTB to do direct port manipulation.
For example this generates a 62.5ns pulse on pins D8-D13:
  DDRB = B00111111;  // Set D8-D13 as outputs
  PORTB = B00111111;  // pins D8-D13 high
  PORTB = B00000000;  // pins D8-D13 low
  delay(10);
This may help: Inline Assembler Cookbook
Is this in a library? Does it require arguments? Does it contain or reference the errors? It is not available in your sketch.
Sorry, I have reduced my Sketch to a minimum and forgot to change the LED.on(); It is now corrected to pinMode/digitalWrite..
To all other answers: I have often seen the port manipulation like "PORTB = ...". The problem must be in relation with PUSH and POP!
To 6v6gt: Thanks, but unfortunately that doesn't help. PUSH and POP are not handled.
PORTB and DDRB are not defined at assembly level; they are C preprocessor symbols.
To access them via "asm" C statements, you'd normally do something like:
asm("in r20, %0" : : "I" (_SFR_IO_ADDR(PORTD)) );
(Described in the cookbook 6v6gt linked.)
It has nothing to do with the use of PUSH and POP.
The internet suggests that a #define __AVR__(your processor)__ is missing or out-dated... and that will have the pre-defined DDRB, et c. that are causing the error(s).
No, that only pulls in the C preprocessor symbols, and they are no longer available when you get to the ASM phase of the build.
Thank you everyone for your contributions. But after x attempts with all possible variants I do without "asm(...) and stay with the register names that are understood in the sketch by C/C++.
