Problem with BME688 Devkit + LoRa transmission sketch
Context
I am trying to write a sketch that uses two different functionalities:
  1. Some environmental data is measured by 8 BME688 sensors of a BME688 Devkit (an Adafruit Feather compatible shield) and is further processed using a sensor fusion library (bsec2 library from Bosch Sensortech) which allows to perform a classification task between different kind of gases. Once all the processing is done, the library outputs classification probabilities for two classes.
  2. Once I got these class probabilities, I would like to send this data using LoRa communication technology, using the RadioHead library.
Code
I split the two distinct functionalities in different files, with the .ino main sketch calling the functionalities exported from these files
BME688-Classifier.ino
#include "devkit.h"
#include "loratx.h"
void setup(void)
  setupDevkit();
  lora_setup();
  Serial.println("lora_setup(): Success");
/* Function that is looped forever */
void loop(void)
  checkNewDevKitData();
devkit.h
#ifndef DEVKIT_H
#define DEVKIT_H
void setupDevkit();
void checkNewDevKitData();
#endif
devkit.cpp
#include <bsec2.h>
#include <EEPROM.h>
#include <commMux\commMux.h>
#include "config.h"
#include "devkit.h"
#define COMPLETED       1
// bsec2 library state saving period
#define STATE_SAVE_PERIOD   UINT32_C(360 * 60 * 1000) /* 360 minutes - 4 times a day */
// Number of sensors to operate
#define NUM_OF_SENS    8
#define PANIC_LED	LED_BUILTIN
#define ERROR_DUR   1000
// Update bsec2 state
void updateBsecState(Bsec2 bsec);
// Function called each time new data is available
void newDataCallback(const bme68xData data, const bsecOutputs outputs, Bsec2 bsec);
// Check status of bsec2 library
void checkBsecStatus(Bsec2 bsec);
// Load state from non-volatile memory
bool loadState(Bsec2 bsec);
bool saveState(Bsec2 bsec);
void errLeds(void);
Bsec2 envSensor[NUM_OF_SENS];
// Handles communication with multiple sensors
comm_mux commConfig[NUM_OF_SENS];
uint8_t bsecMemBlock[NUM_OF_SENS][BSEC_INSTANCE_SIZE];
uint8_t sensor = 0;
static uint8_t bsecState[BSEC_MAX_STATE_BLOB_SIZE];
void errLeds(void)
    while(1)
        digitalWrite(PANIC_LED, HIGH);
        delay(ERROR_DUR);
        digitalWrite(PANIC_LED, LOW);
        delay(ERROR_DUR);
    if (bsec.status < BSEC_OK)
        Serial.println("BSEC error code : " + String(bsec.status));
        errLeds(); /* Halt in case of failure */
    } else if (bsec.status > BSEC_OK)
        Serial.println("BSEC warning code : " + String(bsec.status));
    if (bsec.sensor.status < BME68X_OK)
        Serial.println("BME68X error code : " + String(bsec.sensor.status));
    } else if (bsec.sensor.status > BME68X_OK)
        Serial.println("BME68X warning code : " + String(bsec.sensor.status));
    static uint16_t stateUpdateCounter = 0;
    bool update = false;
    if (!stateUpdateCounter || (stateUpdateCounter * STATE_SAVE_PERIOD) < millis())
        /* Update every STATE_SAVE_PERIOD minutes */
        update = true;
        stateUpdateCounter++;
    if (update && !saveState(bsec))
        checkBsecStatus(bsec);
    if (EEPROM.read(0) == BSEC_MAX_STATE_BLOB_SIZE)
        /* Existing state in EEPROM */
        Serial.println("Reading state from EEPROM");
        Serial.print("State file: ");
        for (uint8_t i = 0; i < BSEC_MAX_STATE_BLOB_SIZE; i++)
            bsecState[i] = EEPROM.read(i + 1);
            Serial.print(String(bsecState[i], HEX) + ", ");
        if (!bsec.setState(bsecState))
            return false;
    } else
        /* Erase the EEPROM with zeroes */
        Serial.println("Erasing EEPROM");
        for (uint8_t i = 0; i <= BSEC_MAX_STATE_BLOB_SIZE; i++)
            EEPROM.write(i, 0);
        EEPROM.commit();
    return true;
    if (!bsec.getState(bsecState))
        return false;
    Serial.println("Writing state to EEPROM");
        EEPROM.write(i + 1, bsecState[i]);
    EEPROM.write(0, BSEC_MAX_STATE_BLOB_SIZE);
    EEPROM.commit();
    return true;
    if (!outputs.nOutputs)
        return;
    Serial.println("BSEC outputs:\n\tSensor num = " + String(sensor));
    Serial.println("\tTime stamp = " + String((int) (outputs.output[0].time_stamp / INT64_C(1000000))));
	  int index = 0;
    for (uint8_t i = 0; i < outputs.nOutputs; i++)
        const bsecData output  = outputs.output[i];
        switch (output.sensor_id)
            case BSEC_OUTPUT_RAW_TEMPERATURE:
                Serial.println("\tTemperature = " + String(output.signal));
            case BSEC_OUTPUT_RAW_PRESSURE:
                Serial.println("\tPressure = " + String(output.signal));
            case BSEC_OUTPUT_RAW_HUMIDITY:
                Serial.println("\tHumidity = " + String(output.signal));
            case BSEC_OUTPUT_RAW_GAS:
                Serial.println("\tGas resistance = " + String(output.signal));
            case BSEC_OUTPUT_RAW_GAS_INDEX:
                Serial.println("\tGas index = " + String(output.signal));
            case BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE:
                Serial.println("\tCompensated temperature = " + String(output.signal));
            case BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY:
                Serial.println("\tCompensated humidity = " + String(output.signal));
            case BSEC_OUTPUT_GAS_ESTIMATE_1:
            case BSEC_OUTPUT_GAS_ESTIMATE_2:
            case BSEC_OUTPUT_GAS_ESTIMATE_3:
            case BSEC_OUTPUT_GAS_ESTIMATE_4:
                index = (output.sensor_id - BSEC_OUTPUT_GAS_ESTIMATE_1);
                if (index == 0) // The four classes are updated from BSEC with same accuracy, thus printing is done just once.
                  Serial.println("\tAccuracy = " + String((int) output.accuracy));
                Serial.println(("\tClass " + String(index + 1) + " probability = ") + String(output.signal * 100) + "%");
            case BSEC_OUTPUT_REGRESSION_ESTIMATE_1:
            case BSEC_OUTPUT_REGRESSION_ESTIMATE_2:
            case BSEC_OUTPUT_REGRESSION_ESTIMATE_3:
            case BSEC_OUTPUT_REGRESSION_ESTIMATE_4:
                index = (output.sensor_id - BSEC_OUTPUT_REGRESSION_ESTIMATE_1);
                if (index == 0) // The four targets are updated from BSEC with same accuracy, thus printing is done just once.
                  Serial.println("\tAccuracy = " + String(output.accuracy));
                Serial.println("\tTarget " + String(index + 1) + " = " + String(output.signal * 100));
            default:
void setupDevkit()
  // Desired subscription list of BSEC2 Classification outputs
  bsecSensor sensorList[] = {
          BSEC_OUTPUT_RAW_TEMPERATURE,
          BSEC_OUTPUT_RAW_PRESSURE,
          BSEC_OUTPUT_RAW_HUMIDITY,
          BSEC_OUTPUT_RAW_GAS,
          BSEC_OUTPUT_RAW_GAS_INDEX,
          BSEC_OUTPUT_GAS_ESTIMATE_1,
          BSEC_OUTPUT_GAS_ESTIMATE_2,
          BSEC_OUTPUT_GAS_ESTIMATE_3,
  EEPROM.begin(BSEC_MAX_STATE_BLOB_SIZE + 1);
  comm_mux_begin(Wire, SPI);
  pinMode(PANIC_LED, OUTPUT);
	delay(100);
  while (!Serial) delay(10);
  uint8_t state_write_otp = 0;
  for (uint8_t i = 0; i < NUM_OF_SENS; i++)
    // Sets the Communication interface for the given sensor
    commConfig[i] = comm_mux_set_config(Wire, SPI, i, commConfig[i]);
    // Assigning a chunk of memory block to the bsecInstance
    envSensor[i].allocateMemory(bsecMemBlock[i]);
    // Initialize the library and interfaces /
    if (!envSensor[i].begin(BME68X_SPI_INTF, comm_mux_read, comm_mux_write, comm_mux_delay, &commConfig[i]))
        checkBsecStatus (envSensor[i]);
    /* Load the configuration string that stores information
      * on how to classify the detected gas
    if (!envSensor[i].setConfig(bsec_config))
    // Copy state from the EEPROM to the algorithm
    if (state_write_otp == 0)
      if (!loadState(envSensor[i]))
      state_write_otp = COMPLETED;
    // Subscribe for the desired BSEC2 outputs
    if (!envSensor[i].updateSubscription(sensorList, ARRAY_LEN(sensorList), BSEC_SAMPLE_RATE_SCAN))
    // Whenever new data is available call the newDataCallback function
    envSensor[i].attachCallback(newDataCallback);
    updateBsecState(envSensor[i]);
  Serial.println("\nBSEC library version " + \
          String(envSensor[0].version.major) + "." \
          + String(envSensor[0].version.minor) + "." \
          + String(envSensor[0].version.major_bugfix) + "." \
          + String(envSensor[0].version.minor_bugfix));
void checkNewDevKitData() {
      /* Call the run function often so that the library can
     * check if it is time to read new data from the sensor
     * and process it.
    for (sensor = 0; sensor < NUM_OF_SENS; sensor++)
        if (!envSensor[sensor].run())
         checkBsecStatus(envSensor[sensor]);
loratx.h
#ifndef LORA_TX_H
#define LORA_TX_H
void lora_setup();
void lora_send_data(uint8_t data[], uint8_t len);
#endif
loratx.cpp
// lora_tx.ino
// -*- mode: C++ -*-
// Sketch to transmit gas classification virtual outputs from BSEC library
// using LoRa communication technology. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// level messaging abilities.
// BOARD: Adafruit Feather RP2040 RFM (LoRa rf95)
#include <SPI.h>
#include <RH_RF95.h>
#include "loratx.h"
// RF95 module pins for Feather RP2040 RFM:
#define RFM95_CS   16
#define RFM95_INT  21
#define RFM95_RST  17
// EU LoRa central frequency
#define RF95_FREQ 868.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
void lora_setup() {
  if (!rf95.init()) { // if initialization fails, block execution
    Serial.println("init failed");
    while(1);
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  // Set the right frequency for transmission, if it fails, stop execution
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
void lora_send_data(uint8_t data[], uint8_t len) {
  Serial.println("Sending to rf95_server");
  // Send a message to rf95_server
  rf95.send(data, len);
  rf95.waitPacketSent();
config.h (configuration values for the classification task)
#ifndef CONFIG_H
#define CONFIG_H
inline constexpr uint8_t bsec_config[] = {
0,1,6,2,189,1,0,0,0,0,0,0,127,7,0,0,56,0,1,0,0,168,19,73,64,49,119,76,0,0,97,69,0,0,97,69,10,0,3,0,0,0,96,64,23,183,209,56,43,24,149,60,140,74,106,188,43,24,149,60,216,129,243,190,151,255,80,190,216,129,243,190,8,0,2,0,0,0,72,66,16,0,3,0,10,215,163,60,10,215,35,59,10,215,35,59,13,0,5,0,0,0,0,0,100,254,131,137,87,88,0,9,0,7,240,150,61,0,0,0,0,0,0,0,0,28,124,225,61,52,128,215,63,0,0,160,64,0,0,0,0,0,0,0,0,205,204,12,62,103,213,39,62,230,63,76,192,0,0,0,0,0,0,0,0,145,237,60,191,251,58,64,63,177,80,131,64,0,0,0,0,0,0,0,0,93,254,227,62,54,60,133,191,0,0,64,64,12,0,10,0,0,0,0,0,0,0,0,0,45,5,11,0,0,0,2,230,28,3,63,132,158,57,62,174,81,14,61,85,190,100,63,120,204,139,61,230,199,160,189,142,162,12,190,31,30,133,190,176,197,186,62,180,203,149,190,249,97,177,62,155,0,177,189,32,243,58,189,80,194,79,189,81,251,184,62,15,42,44,190,11,223,33,190,121,52,214,62,122,115,33,62,86,147,135,61,59,165,132,190,59,165,132,62,0,0,0,0,0,0,0,0,39,206,135,190,10,103,50,63,2,109,43,191,167,233,163,190,98,102,145,63,38,115,8,63,246,180,198,190,221,91,68,62,108,60,51,191,107,67,243,61,31,28,164,189,29,132,137,190,115,54,189,188,110,72,69,61,15,173,167,61,142,161,23,190,14,127,41,191,63,70,181,62,67,44,197,188,55,86,56,62,47,88,87,190,76,187,24,61,35,227,62,62,62,60,235,62,198,136,129,190,68,111,175,190,142,110,84,190,48,186,107,62,117,139,153,189,94,162,25,63,124,191,153,190,167,92,239,190,42,76,146,62,145,66,47,62,219,57,36,191,171,47,195,190,204,61,94,62,189,69,155,190,247,130,91,63,179,224,44,191,171,226,221,190,195,35,60,189,177,194,146,190,121,224,136,62,83,55,120,190,77,49,181,62,141,156,157,62,234,143,181,190,186,105,138,61,143,22,21,190,196,148,108,190,155,243,42,190,186,204,183,190,116,115,70,190,79,180,215,62,66,157,28,191,139,135,47,190,6,63,68,191,180,100,40,62,111,27,230,190,193,93,14,191,230,253,177,190,48,15,230,62,251,120,101,61,13,216,198,189,250,181,184,62,234,62,3,63,229,36,75,61,86,114,149,62,214,183,163,190,239,159,87,189,217,253,199,62,144,243,156,62,1,39,11,189,248,18,87,63,237,208,167,189,100,0,211,189,84,180,164,62,124,153,35,191,144,249,166,62,64,151,195,190,170,96,27,62,138,122,213,62,221,44,205,62,98,93,52,191,126,21,26,190,128,101,26,62,150,115,196,189,198,135,232,189,24,219,53,62,6,126,239,189,198,184,171,188,72,60,82,63,192,112,131,62,177,192,147,190,36,18,157,190,134,82,135,63,204,214,155,190,0,217,162,62,175,32,22,191,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,87,1,159,62,246,61,5,61,222,219,165,62,86,238,169,190,123,129,187,62,41,245,244,61,88,33,166,60,240,167,65,62,14,0,145,61,117,196,211,60,119,63,251,191,172,173,248,190,137,171,234,63,109,240,64,190,178,59,230,191,134,22,84,62,230,174,24,64,47,106,0,192,73,176,225,63,164,244,254,63,53,39,0,63,49,120,167,187,197,85,146,190,102,61,45,62,216,161,17,63,137,55,168,61,244,153,192,189,46,81,211,62,190,255,35,190,234,223,133,59,25,217,9,63,124,232,2,191,166,186,173,62,126,226,187,190,80,214,59,62,64,157,20,191,61,247,161,189,166,19,106,63,118,1,205,61,24,102,242,61,57,220,15,191,72,22,0,190,112,116,124,63,96,119,202,190,174,163,85,191,127,46,3,62,12,209,62,63,27,110,46,191,6,158,160,63,197,3,89,63,39,110,168,189,198,255,171,61,13,141,227,62,167,61,169,188,89,35,77,191,204,168,254,61,54,229,206,62,10,27,201,190,246,149,89,62,69,126,32,63,100,49,20,62,73,213,98,189,218,125,37,191,188,136,55,62,143,182,0,63,63,157,124,190,212,158,48,191,116,112,60,63,167,142,67,191,87,6,68,191,212,130,226,190,182,206,61,61,170,22,27,63,43,220,14,63,56,54,59,191,243,121,145,62,236,178,12,63,177,61,183,190,139,206,192,62,200,34,72,63,184,199,176,63,115,1,186,190,58,128,163,191,12,58,248,189,197,106,201,63,57,83,122,62,221,174,249,190,83,201,38,63,224,174,185,191,72,75,162,191,176,43,223,190,36,97,8,191,232,38,13,62,104,21,136,190,180,51,1,191,186,92,227,189,47,184,149,61,132,218,220,190,234,229,57,62,132,15,48,63,180,20,40,191,186,132,129,63,0,0,0,0,0,0,0,0,24,56,88,62,182,62,6,190,0,0,0,0,0,0,0,0,137,130,129,63,40,4,114,191,0,0,0,0,0,0,0,0,223,217,54,63,77,112,139,190,0,0,0,0,0,0,0,0,221,161,182,191,97,118,116,63,0,0,0,0,0,0,0,0,219,244,47,189,112,253,146,189,0,0,0,0,0,0,0,0,71,170,183,63,178,1,68,191,0,0,0,0,0,0,0,0,1,143,170,191,28,249,122,63,0,0,0,0,0,0,0,0,1,198,2,64,138,166,225,191,0,0,0,0,0,0,0,0,80,229,171,63,73,198,138,191,0,0,0,0,0,0,0,0,10,10,2,234,72,106,71,54,106,158,74,34,20,125,74,33,42,53,74,82,132,71,72,91,3,50,72,96,67,35,72,183,51,65,71,44,54,111,71,200,148,132,71,0,0,0,0,0,0,0,0,0,0,0,0,211,244,214,70,51,235,69,74,142,64,31,74,173,179,231,73,227,141,213,71,86,209,186,71,93,226,168,71,95,65,133,70,139,31,151,70,54,80,158,70,0,0,128,63,0,0,128,63,0,0,128,63,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,145,1,254,0,2,1,5,48,117,100,0,44,1,112,23,151,7,132,3,197,0,92,4,144,1,64,1,64,1,144,1,48,117,48,117,48,117,48,117,100,0,100,0,100,0,48,117,48,117,48,117,100,0,100,0,48,117,48,117,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,8,7,100,0,100,0,100,0,100,0,48,117,48,117,48,117,100,0,100,0,100,0,48,117,48,117,100,0,100,0,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,44,1,44,1,44,1,44,1,44,1,44,1,44,1,44,1,44,1,44,1,44,1,44,1,44,1,44,1,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,112,23,112,23,112,23,112,23,8,7,8,7,8,7,8,7,112,23,112,23,112,23,112,23,112,23,112,23,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,112,23,112,23,112,23,112,23,255,255,255,255,220,5,220,5,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,220,5,220,5,220,5,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,48,117,0,5,10,5,0,2,0,10,0,30,0,5,0,5,0,5,0,5,0,5,0,5,0,64,1,100,0,100,0,100,0,200,0,200,0,200,0,64,1,64,1,64,1,10,1,0,0,0,0,0,9,166,0,0
 * Names of the configuration classes
inline const String gasName[] = {"Incenso", "Aria"};
#endif
If I compile and upload only the devkit code (removing references to loratx.h file in the main .ino file) everything goes smoothly and the Serial Monitor periodically prints some data like this:
BSEC library version 2.6.1.0
BSEC outputs:
	Sensor num = 1
	Time stamp = 1992
	Temperature = 27.28
	Pressure = 1000.83
	Humidity = 60.29
	Gas resistance = 17339.47
	Gas index = 0.00
This is fine since the code for the sensors is just a slightly modified version of the code made available by Bosch. But when I compile (successfully without any warning) and upload the whole project, even calling only the setup function for LoRa communication in the .ino file, the Serial Monitor does not give any output (not even the output of the setupDevkit() which is called before lora_setup()). Moreover, I can no longer upload any code to my board without pushing the BOOT button since I get this problem when uploading regularly, without pushing BOOT
Sketch uses 124092 bytes (1%) of program storage space. Maximum is 8384512 bytes.
Global variables use 48564 bytes (18%) of dynamic memory, leaving 213580 bytes for local variables. Maximum is 262144 bytes.
Resetting COM17
Converting to uf2, output size: 283136, start address: 0x2000
Scanning for RP2040 devices
No drive to deploy.
To recover normal upload behavior, I upload a simple Blink sketch while pushing BOOT, so that the IDE is again able to upload any sketch without the need of manually press BOOT on the board.
Hardware
Additional Info
For those having the hardware (which I think is quite unlikely), you need to add an entry to your board.txt file under C:\Users\user\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\4.1.1
adafruit_feather_rfm.build.mcu=cortex-m0plus
so that the linker does find a precompiled binary of the bsec2 library, otherwise you'll get an error when compiling.
Huge thanks to everyone that will try to help me
EDIT: I also tested the example sketches of LoRa transmission from RadioHead library and they work fine (I have several boards of this kind so I transmitted some mock data back and forth from two Adafruit Feather RP2040 RFM95 boards). So the pins used for SPI communication with the RF95 module are the right ones.
I can see you are using a RP2040 microcontroller
have you tested the LoRa module and other modules in separate programs to ensure that they work OK?
EDIT: see you are using a RFM95 LoRa module - how have you connected it to the RP2040
EDIT2: have not connected a RFM95 to a RP2040 but have connected a RA-02 LoRa module so
// RP2040 connections
// RP2040 SPIO0 SCK pin GPIO18  to RA-02 SCK
// RP2040 SPI0 Rx pin GPIO16  to RA-02 MISO
// RP2040 SPI0 Tx pin GPIO19  to RA-02 MOSI
// RP2040 SPI0 CSn pin GPIO 17  to RA-02 SS
// RP2040 GP20 to RA-02 Reset
// RP2040 GP21 to RA-02 DIO0
Sorry I forgot to specify that I also tested the example sketches of LoRa transmission from RadioHead library and they work fine (I have several boards of this kind so I transmitted some mock data back and forth from two Adafruit Feather RP2040 RFM95 boards).
Regarding your question, the RP2040 uses SPI to connect with RFM95 LoRa module, using the pins that I posted on the loratx.cpp file. The module is built in on the board as you can see on the product page of Adafruit.
The problem arises when I include the loratx header file inside the .ino file. I was thinking about a CS pin conflict with the devkit but I'm just guessing.
