Hello,
I'm having a problem with a certain kind of button not playing nicely with a 'double-click' detect function.
Code:
#define buttonPin 7 // analog input pin to use as a digital input
#define ledPin1 5 // digital output pin for LED 1
#define ledPin2 6 // digital output pin for LED 2
#define ledPin3 12 // digital output pin for LED 3
// LED variables
boolean ledVal1 = false; // state of LED 1
boolean ledVal2 = false; // state of LED 2
boolean ledVal3 = false; // state of LED 3
// Set button input pin
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH );
// Set LED output pins (and turn all off)
pinMode(ledPin1, OUTPUT);
digitalWrite(ledPin1, ledVal1);
pinMode(ledPin2, OUTPUT);
digitalWrite(ledPin2, ledVal2);
pinMode(ledPin3, OUTPUT);
digitalWrite(ledPin3, ledVal3);
// Get button event and act accordingly
int b = checkButton();
if (b == 1) clickEvent();
if (b == 2) doubleClickEvent();
if (b == 3) holdEvent();
// Events to trigger
void clickEvent() {
digitalWrite(ledPin1, HIGH);
delay(3000);
digitalWrite(ledPin1, LOW);
void doubleClickEvent() {
digitalWrite(ledPin2, HIGH);
delay(3000);
digitalWrite(ledPin2, LOW);
void holdEvent() {
digitalWrite(ledPin3, HIGH);
delay(3000);
digitalWrite(ledPin3, LOW);
// MULTI-CLICK: One Button, Multiple Events
// Button timing variables
int debounce = 20; // ms debounce period to prevent flickering when pressing or releasing the button
int DCgap = 250; // max ms between clicks for a double click event
int holdTime = 2000; // ms hold period: how long to wait for press+hold event
// Button variables
boolean buttonVal = HIGH; // value read from button
boolean buttonLast = HIGH; // buffered value of the button's previous state
boolean DCwaiting = false; // whether we're waiting for a double click (down)
boolean DConUp = false; // whether to register a double click on next release, or whether to wait and click
boolean singleOK = true; // whether it's OK to do a single click
long downTime = -1; // time the button was pressed down
long upTime = -1; // time the button was released
boolean ignoreUp = false; // whether to ignore the button release because the click+hold was triggered
boolean waitForUp = false; // when held, whether to wait for the up event
boolean holdEventPast = false; // whether or not the hold event happened already
int checkButton() {
int event = 0;
buttonVal = digitalRead(buttonPin);
// Button pressed down
if (buttonVal == LOW && buttonLast == HIGH && (millis() - upTime) > debounce)
downTime = millis();
ignoreUp = false;
waitForUp = false;
singleOK = true;
if ((millis()-upTime) < DCgap && DConUp == false && DCwaiting == true) DConUp = true;
else DConUp = false;
DCwaiting = false;
// Button released
else if (buttonVal == HIGH && buttonLast == LOW && (millis() - downTime) > debounce)
if (not ignoreUp)
upTime = millis();
if (DConUp == false) DCwaiting = true;
event = 2;
DConUp = false;
DCwaiting = false;
singleOK = false;
// Test for normal click event: DCgap expired
if ( buttonVal == HIGH && (millis()-upTime) >= DCgap && DCwaiting == true && DConUp == false && singleOK == true && event != 2)
event = 1;
DCwaiting = false;
// Test for hold
if (buttonVal == LOW && (millis() - downTime) >= holdTime) {
// Trigger "normal" hold
if (not holdEventPast)
event = 3;
waitForUp = true;
ignoreUp = true;
DConUp = false;
DCwaiting = false;
//downTime = millis();
holdEventPast = true;
buttonLast = buttonVal;
return event;
Circuit:
What's happening is that this particular kind of button does not want to 'double-click' - the code above doesn't seem to pick up me double-clicking this button. I don't understand why that would be...this button works just fine - it picks up the double-clicks.
Both buttons do a regular, single click and a press-and-hold just fine.
