I'm having an issue with a stepper motor setup. I have an Arduino Mega 2560 and a Super Electric Slo M092-FF-409 Stepper Motor. The motor is connected to an older Geckodrive 210.
My problem is: I can smoothly operate the motor, in one direction (clockwise), using one of the examples from the stepper motor library. However, when I input a negative number of steps to move counterclockwise, the motor's motion is not smooth. It hesitates, going clockwise first, before proceeding to somewhat smoothly go counterclockwise.
I have the pins for both step and direction connected from my board to the Geckodrive. The problem seems to occur when the direction pin is connected to the Arduino. If I remove it, the motor operates perfectly but it cannot rotate counterclockwise. I'm not sure what's going on with the direction pin so if there is any remedy to the problem, please let me know.
If a picture of the setup is needed, I can provide soon. I don't have the setup at hand right now but I'll get those pictures up as soon as possible. I'm a complete beginner to stepper motors, but I'm willing to accept any critiques and advice.
You have not posted your program so all I can do is guess ...
The standard stepper library is not really suitable for a stepper driver that uses step and direction signals. The AccelStepper library is much more comprehensive.
I find it impossible to be certain how things are connected based on a photo of the hardware. Make a simple pencil drawing showng how everything is connected and post a photo of the drawing.
The program code is just as important as the drawing.
But be sure to try the AccelStepper library before replying to this as it may do what you need.
Sorry about that. Hopefully this diagram helps out.
I tried the AccelStepper Library and I run into the same problem. The motor jerks in the opposite direction before moving in the desired direction and then repeats the same behavior if there's a command to change it's direction.
If I remove the direction pin connected to the Arduino, the motor operates smoothly but cannot change directions. I'm not sure if that bit of information helps
Here is the simple code that I use to test rotation clockwise then counterclockwise
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution for your motor
int numberofsteps = 4; // number of rotations that we want to make
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9);
// set the speed at 60 rpm:
myStepper.setSpeed(100);
// initialize the serial port:
if (numberofsteps > 0)
// step one revolution in one direction:
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
delay(200);
// step one revolution in the other direction:
Serial.println("counterclockwise");
myStepper.step(-stepsPerRevolution);
delay(200);
numberofsteps -= 1;
Here is the code that I use from the AccelStepper Library. This one also runs into the same problem of switching directions.
The simple code that you showed me actually works very well. I'm wondering what could be the differences this and the ones used for AccelStepper.
Since I'm using this in conjunction with LabVIEW's LIFA library to simultaneously control the stepper and collect data, could I simply adjust the corresponding functions in the AccelStepper library from which LIFA incorporates in order to use this simpler code?
Thanks again for the reply and your patience.
// testing a stepper motor with a Pololu A4988 driver board or equivalent
// on an Uno the onboard led will flash with each step
// this version uses delay() to manage timing
byte directionPin = 9;
byte stepPin = 8;
int numberOfSteps = 100;
byte ledPin = 13;
int pulseWidthMicros = 20; // microseconds
int millisbetweenSteps = 250; // milliseconds - or try 1000 for slower steps
Serial.println("Starting StepperTest");
digitalWrite(ledPin, LOW);
delay(2000);
pinMode(directionPin, OUTPUT);
pinMode(stepPin, OUTPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(directionPin, HIGH);
for(int n = 0; n < numberOfSteps; n++) {
digitalWrite(stepPin, HIGH);
delayMicroseconds(pulseWidthMicros); // this line is probably unnecessary
digitalWrite(stepPin, LOW);
delay(millisbetweenSteps);
digitalWrite(ledPin, !digitalRead(ledPin));
delay(3000);
digitalWrite(directionPin, LOW);
// delayMicroseconds(pulseWidthMicros); // probably not needed
