Hello, I would like to learn Arduino. I'm trying to modify a "simple" program (LEDS). For this I use the serial monitor for entering values. In the added sketch you can see the program.
I would like to achieve the following: a) Entering a value for the yellow and a value for the red LED. b) After this I would also like to enter separate values for the "time on" and the "time off" of the red and yellow LED.
- I want to enter a value for the yellow and red LEDs via the serial monitor. The input of 1 LED goes well and also carries out the command of this LED. If you immediately want to enter the value of the second LED, this will be skipped. In the program you can see that you can enter both values one after the other. If I "disable" the first part, it works fine for the second part. If I disable the 2nd part, the 1st part works fine. In this program it is not possible to enter 2 values and have them both flash.
I've tried everything but haven't found a solution yet.
Who can help me learn Arduino?
Thank you in advance
The program:
// Hier is de opdracht dat je uiteindelijk alle vaste waardens variabel gaat
// maken zodat je deze via invoer seriele monitor deze waardens kunnen wijzigen.
// We beginnen met Yellow
int redLEDPin=9; //Declare redLedPin an int, and set to pin 9
int yellowLEDPin=10; //Declare yellowLEDPin an int,and set to pin 10
int redOnTime=500; //Declare redOnTime an int, and set to ?? msec
int redOffTime=500; //Declare redOffTime an int,and set to ?? msec
int yellowOnTime=1000; // Declare yellowOnTime an int, and set ?? msec
int yellowOffTime=1000; // Declare yellowOffTime an int, and set to ?? msec
int numYellowBlinks; // Number of times to blink yellow Led
int numRedBlinks; // Number of times to blink red Led
String redMessage= "The Red LED is Blinking"; // Declaring a String Variable
String yellowMessage= "The Yellow LED is Blinking"; // Declaring a String Variable
String OnYellow= "On Time yellow ="; // Time yellow is on
String OnRed= "On Time red ="; // Time red is on
String OffYellow= "Off Time yellow ="; // Time yellow is off
String OffRed= "Off Time red ="; // Time red is off
Serial.begin(9600); // Turn on the Serial Port
pinMode(redLEDPin, OUTPUT); // Tell Arduino that redLEDPin is an output pin
pinMode(yellowLEDPin, OUTPUT); //Tell Arduino that yellowLEDPin is an output pin
Serial.println("How Many Times Do You Want The Red LED to Blink?");
while (Serial.available() ==0){ } // Waiting for input
numRedBlinks = Serial.parseInt();// Read user input
Serial.println("How Many Times Do You Want The Yellow LED to Blink?");
numYellowBlinks = Serial.parseInt();//Read user input
Serial.print("Het aantal knipperen is nu: ");
Serial.println(numYellowBlinks );
//Serial.println(redMessage);
for (int j=1; j<=numRedBlinks; j=j+1) { // Start our for loop
Serial.print(" You are on Blink #: ");
Serial.println(j);
digitalWrite(redLEDPin,HIGH); //Turn red LED on
delay(redOnTime); //Leave on for redOnTime
digitalWrite(redLEDPin,LOW); //Turn red LED off
delay(redOffTime); //Leave off for redOffTime
Serial.println(" ");
Serial.println(yellowMessage);
for (int j=1; j<=numYellowBlinks; j=j+1) { // Start our for loop
Serial.println(j);
digitalWrite(yellowLEDPin,HIGH); //Turn yellow LED on
delay(yellowOnTime); //Leave on for yellowOnTime
digitalWrite(yellowLEDPin,LOW); //Turn yellow LED off
delay(yellowOffTime); //Leave off for yellowOffTime
The serial monitor shows this:
Het aantal knipperen is nu: 0
You are on Blink #: 1
You are on Blink #: 2
You are on Blink #: 3
You are on Blink #: 4
You are on Blink #: 5
