Hello,
Sorry for posting into not correct topic of the forum.
My schematic is very basic one to have working DS3231 and LCD which you can find in the internet. Everything is working like I want. This code is used from example and a little bit modified for my purpose.
I'd like to share my code below:
Also, I've attached code in TXT file to make it more easier to to check it.
#include <LiquidCrystal.h>
#include <Wire.h>
#include "ds3231.h"
LiquidCrystal lcd(12, 11, 4, 5, 6, 7); // LCD pajungimo kontaktai
#define BUFF_MAX 128
uint8_t time[8]; // nustatomi 8 bitai laikui
char recv[BUFF_MAX]; // buferis priima max
unsigned int recv_size = 0;
unsigned long prev, interval = 1000;
//void parse_cmd(char *cmd, int cmdsize);
Wire.begin();
DS3231_init(DS3231_CONTROL_INTCN);
memset(recv, 0, BUFF_MAX);
Serial.println("GET time");
lcd.begin(16, 2); // LCD paleidimas
lcd.clear (); // LCD išvalymas
//Serial.println("Setting time");
//parse_cmd("T000515419112020",16); // Nustatoma esama data pirmo paleidimu
char in;
char buff[BUFF_MAX];
unsigned long now = millis();
struct ts t;
// show time once in a while
if ((now - prev > interval) && (Serial.available() <= 0)) {
DS3231_get(&t); //Gaunam laiką
//parse_cmd("C",1);
lcd.clear();
lcd.setCursor(0, 0); // Pirmos ekrano eilutės kursoriaus vieta
lcd.print("Data:");
lcd.print(t.year); // Išveda į ekraną metus
printMonth(t.mon); // Išveda i ekraną mėnesį
lcd.print(t.mday); // Išveda į ekraną dienas
lcd.setCursor(0, 1); //Antra ekrano eilutė
lcd.print("Laikas:");
lcd.print(t.hour);
lcd.print(":");
if (t.min < 10)
lcd.print("0");
lcd.print(t.min);
lcd.print(":");
if (t.sec < 10)
lcd.print("0");
lcd.print(t.sec);
//lcd.print(' ');
//lcd.print(tempF);
//lcd.print((char)223);
//lcd.print("C ");
prev = now;
if (Serial.available() > 0) {
in = Serial.read();
if ((in == 10 || in == 13) && (recv_size > 0)) {
parse_cmd(recv, recv_size);
recv_size = 0;
recv[0] = 0;
} else if (in < 48 || in > 122) {
; // ignore ~[0-9A-Za-z]
} else if (recv_size > BUFF_MAX - 2) { // drop lines that are too long
// drop
recv_size = 0;
recv[0] = 0;
} else if (recv_size < BUFF_MAX - 2) {
recv[recv_size] = in;
recv[recv_size + 1] = 0;
recv_size += 1;
uint8_t i;
uint8_t reg_val;
struct ts t;
//snprintf(buff, BUFF_MAX, "cmd was '%s' %d\n", cmd, cmdsize);
//Serial.print(buff);
// TssmmhhWDDMMYYYY aka set time
if (cmd[0] == 84 && cmdsize == 16) {
//T355720619112011
t.sec = inp2toi(cmd, 1);
t.min = inp2toi(cmd, 3);
t.hour = inp2toi(cmd, 5);
t.wday = inp2toi(cmd, 7);
t.mday = inp2toi(cmd, 8);
t.mon = inp2toi(cmd, 10);
t.year = inp2toi(cmd, 12) * 100 + inp2toi(cmd, 14);
DS3231_set(t);
Serial.println("OK");
} else if (cmd[0] == 49 && cmdsize == 1) { // "1" get alarm 1
DS3231_get_a1(&buff[0], 59);
Serial.println(buff);
} else if (cmd[0] == 50 && cmdsize == 1) { // "2" get alarm 1
DS3231_get_a2(&buff[0], 59);
} else if (cmd[0] == 51 && cmdsize == 1) { // "3" get aging register
Serial.print("aging reg is ");
Serial.println(DS3231_get_aging(), DEC);
} else if (cmd[0] == 65 && cmdsize == 9) { // "A" set alarm 1
DS3231_set_creg(DS3231_CONTROL_INTCN | DS3231_CONTROL_A1IE);
//ASSMMHHDD
for (i = 0; i < 4; i++) {
time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // ss, mm, hh, dd
byte flags[5] = { 0, 0, 0, 0, 0 };
DS3231_set_a1(time[0], time[1], time[2], time[3], flags);
} else if (cmd[0] == 66 && cmdsize == 7) { // "B" Set Alarm 2
DS3231_set_creg(DS3231_CONTROL_INTCN | DS3231_CONTROL_A2IE);
//BMMHHDD
time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // mm, hh, dd
byte flags[5] = { 0, 0, 0, 0 };
DS3231_set_a2(time[0], time[1], time[2], flags);
} else if (cmd[0] == 67 && cmdsize == 1) { // "C" - get temperature register
Serial.print("temperature reg is ");
Serial.println(DS3231_get_treg(), DEC);
} else if (cmd[0] == 68 && cmdsize == 1) { // "D" - reset status register alarm flags
reg_val = DS3231_get_sreg();
reg_val &= B11111100;
DS3231_set_sreg(reg_val);
} else if (cmd[0] == 70 && cmdsize == 1) { // "F" - custom fct
reg_val = DS3231_get_addr(0x5);
Serial.print("orig ");
Serial.print(reg_val, DEC);
Serial.print("month is ");
Serial.println(bcdtodec(reg_val & 0x1F), DEC);
} else if (cmd[0] == 71 && cmdsize == 1) { // "G" - set aging status register
DS3231_set_aging(0);
} else if (cmd[0] == 83 && cmdsize == 1) { // "S" - get status register
Serial.print("status reg is ");
Serial.println(DS3231_get_sreg(), DEC);
Serial.print("unknown command prefix ");
Serial.println(cmd[0]);
Serial.println(cmd[0], DEC);
void printMonth(int month)
switch (month)
case 1: lcd.print("-01-"); break;
case 2: lcd.print("-02-"); break;
case 3: lcd.print("-03-"); break;
case 4: lcd.print("-04-"); break;
case 5: lcd.print("-05-"); break;
case 6: lcd.print("-06-"); break;
case 7: lcd.print("-07-"); break;
case 8: lcd.print("-08-"); break;
case 9: lcd.print("-09-"); break;
case 10: lcd.print("-10-"); break;
case 11: lcd.print("-11-"); break;
case 12: lcd.print("-12-"); break;
default: lcd.print(" Klaida "); break;
Code.txt (5.55 KB)
