Little Background
Hi I'm still new to Arduino Forum, and its programming(especially C++). I was trying to make Serial Monitor to print out the current date and time. However I had no idea how, I tried downloading libraries but there were tons of libraries out there about RTC (Real Time Clock), so I finally tried it one by one, but no luck, I can't print out current date and time.
I read about DS3231, and try to download it, however this are one of the libraries in which the examples doesn't work. I have tried this but it seems that it's not working for me.
Here's my code (it's actually from example)
#include <DS3231.h> //mengincludekan library DS3231
DS3231 rtc; // inisialisasi penggunaan i2c
// Setup Serial connection
// Uncomment the next line if you are using an Arduino Leonardo
//while (!Serial) {}
// Initialize the rtc object
rtc.begin();
// The following lines can be uncommented to set the date and time
//rtc.setDOW(WEDNESDAY); // Set Day-of-Week to SUNDAY
//rtc.setTime(12, 0, 0); // Set the time to 12:00:00 (24hr format)
//rtc.setDate(1, 1, 2014); // Set the date to January 1st, 2014
// Send Day-of-Week
Serial.print(rtc.getDOWStr());
Serial.print(" ");
// Send date
Serial.print(rtc.getDateStr());
Serial.print(" -- ");
// Send time
Serial.println(rtc.getTimeStr());
// Wait one second before repeating
delay (1000);
Here's my error code
Arduino: 1.8.9 (Linux), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
/home/jippy98/Arduino/arduino_time_test/arduino_time_test.ino: In function 'void setup()':
arduino_time_test:13:7: error: 'class DS3231' has no member named 'begin'
rtc.begin();
/home/jippy98/Arduino/arduino_time_test/arduino_time_test.ino: In function 'void loop()':
arduino_time_test:24:20: error: 'class DS3231' has no member named 'getDOWStr'; did you mean 'getDoW'?
getDoW
arduino_time_test:28:20: error: 'class DS3231' has no member named 'getDateStr'; did you mean 'getDate'?
getDate
arduino_time_test:32:22: error: 'class DS3231' has no member named 'getTimeStr'; did you mean 'getMinute'?
getMinute
exit status 1
option enabled in File -> Preferences.
I am using Arduino Nano, anything else I should provide? If so, then please ask. Thank you.
I tried out, the sketch you refer to, and I get this error
arduino_time_test:4:1: error: 'RTC_DS3231' does not name a type; did you mean 'DS3231'?
RTC_DS3231 rtc; //the object rtc is created from the class RTC_DS3231
DS3231
arduino_time_test:11:3: error: 'rtc' was not declared in this scope
rtc.begin();
/home/jippy98/Arduino/arduino_time_test/arduino_time_test.ino:11:3: note: suggested alternative: 'getc'
rtc.begin();
getc
arduino_time_test:20:22: error: 'rtc' was not declared in this scope
DateTime nowTime = rtc.now();
/home/jippy98/Arduino/arduino_time_test/arduino_time_test.ino:20:22: note: suggested alternative: 'getc'
getc
arduino_time_test:23:19: error: 'class DateTime' has no member named 'dayOfTheWeek'; did you mean 'dayOfWeek'?
int x = nowTime.dayOfTheWeek(); //dyOfTheWeek() is a pre-defined method
dayOfWeek
exit status 1
I'm guessing that I installed the wrong library? There's another error before, but that's because I don't have RTClib.h after I installed it I get the error above.
You are probably not putting the libraries in the right place. Just make sure they are in the same folder as all the other libraries - i.e. SD, wire etc.. If you are just after date and time, you don't actually need any libraries, and indeed it is a bit more efficient to do without them. This works for DS3231, same as DS1307. I had a bit of a bad time with RTC libraries, and have never bothered to use them since.
I have tried the sketch in my two NANOs (for the first time); the sketch is compiled; but, there is uploading problem. When I changed the Board to 'NANO Old Boot-loader', the sketch is uploaded; but, the date/time are wrong! (The sketch works well with UNO and MEGA.)
The Sketch:
#include <Wire.h> //needed because DS3231 uses I2C Bus
#include <RTClib.h> //needed becuase we have ready-made functions of this librray
char daysOfTheWeek[7][4] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
#define deviceAddress 0x68
rtc.begin();
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));//auto update from computer time
//rtc.adjust(DateTime(2018, 12, 23, 9, 15, 17));//set date-time manualy:yr,mo,dy,hr,mn,sec
//--read Date and Tme from DS3231 using the method now()---------------------;
//--store the Date and Time into another user define object bamed nowTime
//---show Day and Date on Top Line of LCD--------------
Serial.print(daysOfTheWeek[x]); //days of the Week[] is the user defined array
Serial.print(": ");
Serial.print(nowTime.day());
Serial.print("/");
Serial.print(nowTime.month());
Serial.print("/");
Serial.print(nowTime.year());
Wire.beginTransmission(deviceAddress); //START, Roll Cal
Wire.write(0x00); //set SEC Register address
Wire.endTransmission(); //Execute the above queued data, ACK, STOP
Wire.requestFrom(deviceAddress, 3); //SEC, MIN, and HRS to read from RTC as BCD
byte bcdSeconds = Wire.read();
byte bcdMinutes = Wire.read();
byte bcdHours = Wire.read();
Serial.print(bcdMinutes >> 4);
Serial.print(bcdMinutes & 0x0F);
Serial.print(':');
//shiw SEC
Serial.print(" Time: ");
//show HRS--
Serial.print(bcdHours >> 4);
Serial.print(bcdHours & 0x0F);
Serial.print(':');
//show MIN--
Serial.print(bcdSeconds >> 4);
Serial.print(bcdSeconds & 0x0F);
You need to make sure to use the library that the sketch was written for. In the case of common components like DS3231, there will often be several Arduino libraries with the same or similar names, but incompatible APIs. To make things more confusing, sometimes the library author will change the API over time. If so, you need to get the specific version of the library the sketch was written for. You should usually have good luck if you use the example sketches that come with the library.
Guys, it's been a while since I posted this. I had no idea what went wrong at the time I'm posting. I think I was really newbie and I had no idea how to use the library. It turns out as I learn there are a lot of libraries that works, and doesn't.
However now that I'm much more 'experienced' than earlier, I have solved it. I just want to update my current status. Thanks to all of you member and staff of Arduino Community!
Nick_Pyner:
3rd party libraries should actually go in the libraries directory in the sketch directory, not in the installation directory.
