Hey guys, I'm working with an Arduino Uno and the HM-10 BLE module, but my transmission connection is acting weird. It connects properly and I get a quick TX RX blinks on my Uno board and the correct info on my serial monitor, but after a second or so it starts to blink really slowly and the info transmitted comes a second at a time even if I stopped sending info a while ago. Any ideas on why that's happening?
#include <Arduino.h>
int x = 0;
int y = 0;
while (Serial.available() > 0) {
x = Serial.read();
y = Serial.read();
Serial.print("x: ");
Serial.println(x);
Serial.print("y: ");
Serial.println(y);
Two devices (HM-10 and serial monitor) on the same serial port can cause problems. May I suggest that you use a software serial port (several libraries available) for the Bluetooth module and save the hardware Serial (USB) for upload and program output and debug?
As for the two devices on the serial port, that might be it, I was already looking for the SoftwareSerial library to try and solve this, they are probably using the same lanes and causing trouble on the comms.
in your loop() code you are reading 2 bytes if at least one byte is available. That is not the most reliable way to do it.
What is the app sending? Can you provide a sample?
What is printed with this simple test code? Copy and paste the serial monitor results to a new post, please. You will need to wire the Blutooth module to the Uno as shown in the test program to use Software serial.
#include <SoftwareSerial.h>
// connect bt TX to Uno pin 4 and BT RX to Uno pin 5
SoftwareSerial BTserial(4, 5); // RX | TX
BTserial.begin(9600); // **** change for your module if necessary
if (Serial.available())
BTserial.write(Serial.read());
if (BTserial.available())
Serial.print(char(BTserial.read()));
I would recommend that you get things working with a standard ble terminal app before using a custom App Inventor program.
groundFungus:
Will try to answer you later, sorry to take so long, I'm really busy! I'll reply in some time.
Thanks for taking your time to answer me!
groundFungus:
Already fixed the two byte readings asking for only one byte available. I was a mistake I made while not paying attention!
The app I have sends The X and Y values for a "joystick" that is on screen, just like this one.
The blocks on App Inventor are basically the same, just adapted for BLE.
The sample code prints random things, can't see anything useful from it
