Problem with IDE or libraries Edit: with board or connector
Are you just being a troll for a laugh, or do you not read the replies, or do you not understand the replies? You clearly have "wires" as you have been using a pump!!, a relay!, a DHT and an LCD. I am hoping (2) and (3), but (1) seems close.
You have been given exact instructions. Here is a video showing what you will be seeing and doing, from the instructions in Post #24. Start the video at 2:10.
Do you mean you don't have two boards?
Then this part should have clued you in that you can't do this:
I am talking about connecting cable
USB cable? Only one.
ISP Arduino needs a cable for data abd power.
Target Arduino does not need a USB cable.
Single core, jumper wires connect ISP to Target, supplying data and power from the ISP to the Target.
Did you not read post #24 or watch the video in Post #41?
@xfpd I'm sorry I saw the post but yesterday I was busy therefore I didn't see video!
Did you not read Post #24? You do not need to explain yourself, just be an active part of your own request.
I didnt understand post 24 therefore I was gonna watch video but you know school homework and things...
I hope post #44 helps explain the further questions you had, indicating did not understand.
Guys @ptillisch @xfpd @arduinojanuary @evanmars @sterretje I am ordering a new nano. Not a original one cuz that almost 5 times my pocket money, or should I?
What are the results of the steps in Post #24? That costs nothing.
still same error
And I still have the same questions:
@ptillisch I think its a upload error
I have a nano whose light is not blinking as programmer and the blinking one as target
That won't work because you must be able to upload the "ArduinoISP" sketch to the programmer board:
You must have a functional Arduino board to use as the programmer board.
I think it is a good idea. You will need a functional board if you want to try to use a "Burn Bootloader" operation to recover your boards. As I warned you, there is no guarantee that the "Burn Bootloader" operation would recover the boards after all. More likely they have suffered permanent physical damage.
And even if you do manage to eventually recover the two boards, the Nano is a very nice board and so I'm sure you will find a use for all three of them eventually!
@ptillisch Yes I agree with that and therefore thank you for your help. I'll mention you when I am in a problem! Good day!
