Problem with internet connection with proxy
Hello together,
I want to install Arduino software at an employees notebook. Internet access is only possible trought network proxy.
I tried to set the proxy in the arduino-cli.yaml and also in the application itself, and i also tried using DNS hostname and IP address, but the IDE does not use it.
Everytime it tries to connect to the internet, is appears as blocked in the firewall log. So the proxy is not used. Otherwise I would see entrys in the proxy log.
Is this a known problem, that IDE does not use a proxy that is set ?
Does anybody have an idea, what I can try to solve this ?
Thank you !
Best regards,
itworker
