Please give me some advice
my experimental with RF 433mhz ,315mhz went well, but IR part has given me a lot of trouble
been order different IRs but none of them go well for me. this is my latest part YwRobot IR transmitter http://www.ebay.com/itm/Wrobot-Digital-38KHz-IR-Sensor-Kit-/281002304748?hash=item416d0ae4ec
I used exactly senddemo code from ir library but never see IR lighted up(using camera viewer)
please take a look at my wiring .. if you see any problem.
Thankyou very much for you time.
* IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
* An IR LED must be connected to Arduino PWM pin 3.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
IRsend irsend;
if (Serial.read() != -1) {
for (int i = 0; i < 3; i++) {
irsend.sendSony(0xa90, 12); // Sony TV power code
delay(40);
Where does the IR pin get declared? there is no pin setup in your sketch to drive the IR transmitter.
Doc
In the IRDemo.ino you can read:
- IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
- An IR LED must be connected to Arduino PWM pin 3.
The library use timer, on Arduino Uno timer 2 so you can use pin 3 (or 11)
void IRsend::mark(int time) { // Sends an IR mark for the specified number of microseconds. The mark output is modulated at the PWM frequency.
TIMER_ENABLE_PWM; // Enable pin 3 PWM output
delayMicroseconds(time);
You have the Mega. You can use 5 different timer. Open the file IRRemoteInt.h under library e see something like this:
// Arduino Mega
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
//#define IR_USE_TIMER1 // tx = pin 11-12
//#define IR_USE_TIMER2 // tx = pin 9-10
//#define IR_USE_TIMER3 // tx = pin 2-3-5
#define IR_USE_TIMER4 // tx = pin 6-7-8
//#define IR_USE_TIMER5 // tx = pin 44-45-46
On my library I use TIMER4 (define without comment simbol), so pin 6,7 or 8
EDIT: where you download the library? From your link I can see a zip with a very very old IRRemote library (I think not compatible with Mega) !!!
Use this link: GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols
Thanks nid69ita will try that
Thanks Docedison I though it was declared in the .h file let me take a closer look at the sketch.
nid69ita you are the man, you pointed out the exactly the problem
checked IRremoteInt.h , mega2560 using pin9 for ir transmitter.. run the sketch again ..wow panasonic tv is ON.
Thanks alot man. have a great day.
