Problem with java.lang.StackOverflowError
I have written a program, and expanded it abit to breakout some code into routines, and when I try to compile it I get 'java.lang.StackOverflowError'. :frowning:
I have got ver 12 Alpha of the compiler, running on Vista. I have also re-installed java, but have no idea how to check the version.
Any ideas of how to fix would be very welcome 8-).
Thanks,
Martin
Here is the code:
/*          Wheel encoder multi test 4
 *    This test is designed to test 6 motor driver
 *  Mapping so far (Default direction in bracketts):
 *   1-Not Working
 *   2-Base     (CounterClockwise)
 *   7-Shoulder (ClockWise)
 *   4-Not Working
 *   5-Gripper   (Close)
        int MotorSpeed1 = 0;
        int MotorSpeed2 = 0;
        int MotorSpeed3 = 0;
        int MotorSpeed4 = 0;
        int MotorSpeed5 = 0;
        int MotorSpeed6 = 0;
        int PinPulse1 = 3;
        int PinDirection1 = 2;
        int PinPulse2 = 5;
        int PinDirection2 = 4;
        int PinPulse3 = 6;
        int PinDirection3 = 7;
        int PinPulse4 = 9;
        int PinDirection4 = 8;
        int PinPulse5 = 10;
        int PinDirection5 = 12;
        int PinPulse6 = 11;
        int PinDirection6 = 13;
        int SerialStreamByte = -1;
        int StepSize = 128;
            for (int x = 2; x < 14; x++)
                pinMode(x, OUTPUT);
                digitalWrite(x, LOW);
            Serial.println("P4 Ready");
           // ExecCommand('r');
            SerialStreamByte = ListenForCommand();
            if (SerialStreamByte != -1)
                ExecCommand(SerialStreamByte);
                DebugMotorSpeeds()
                LimitHardware();
                InterfaceHardware();
        int ListenForCommand()
            if (Serial.available() > 0)
                return Serial.read();
            return -1;
        void LimitHardware()
            MotorSpeed1 = constrain(MotorSpeed1, -255, 255);
            MotorSpeed2 = constrain(MotorSpeed2, -255, 255);
            MotorSpeed3 = constrain(MotorSpeed3, -255, 255);
            MotorSpeed4 = constrain(MotorSpeed4, -255, 255);
            MotorSpeed5 = constrain(MotorSpeed5, -255, 255);
            MotorSpeed6 = constrain(MotorSpeed6, -255, 255);
        void InterfaceHardware()
            analogWrite(PinPulse1, abs(MotorSpeed1));
            digitalWrite(PinDirection1, MotorSpeed1 > 0 ? HIGH : LOW);
            analogWrite(PinPulse2, abs(MotorSpeed2));
            digitalWrite(PinDirection2, MotorSpeed2 > 0 ? HIGH : LOW);
            analogWrite(PinPulse3, abs(MotorSpeed3));
            digitalWrite(PinDirection3, MotorSpeed3 > 0 ? HIGH : LOW);
            analogWrite(PinPulse4, abs(MotorSpeed4));
            digitalWrite(PinDirection4, MotorSpeed4 > 0 ? HIGH : LOW);
            analogWrite(PinPulse5, abs(MotorSpeed5));
            digitalWrite(PinDirection5, MotorSpeed5 > 0 ? HIGH : LOW);
            analogWrite(PinPulse6, abs(MotorSpeed6));
            digitalWrite(PinDirection6, MotorSpeed6 > 0 ? HIGH : LOW);
        void DebugMotorSpeeds()
            Serial.print("MotorSpeed 1=");
            Serial.print(MotorSpeed1, DEC);
            Serial.print("            MotorSpeed 2=");
            Serial.print(MotorSpeed2, DEC);
            Serial.print("            MotorSpeed 3=");
            Serial.print(MotorSpeed3, DEC);
            Serial.print("            MotorSpeed 4=");
            Serial.print(MotorSpeed4, DEC);
            Serial.print("            MotorSpeed 5=");
            Serial.print(MotorSpeed5, DEC);
            Serial.print("            MotorSpeed 6=");
            Serial.print(MotorSpeed6, DEC);
        void ExecCommand(int Command)
            switch (Command)
                case 'r':
                    Serial.println("Reset");
                    MotorSpeed1 = 0;
                    MotorSpeed2 = 0;
                    MotorSpeed3 = 0;
                    MotorSpeed4 = 0;
                    MotorSpeed5 = 0;
                    MotorSpeed6 = 0;
                case '1':
                    MotorSpeed1 += StepSize;
                case '!':
                    MotorSpeed1 -= StepSize;
                case '2':
                    MotorSpeed2 += StepSize;
                case '\"':
                    MotorSpeed2 -= StepSize;
                case '7':
                    MotorSpeed3 += StepSize;
                case '&':
                    MotorSpeed3 -= StepSize;
                case '4':
                    MotorSpeed4 += StepSize;
                case '
                   MotorSpeed4 -= StepSize;
               case '5':
                   MotorSpeed5 += StepSize;
               case '%':
                   MotorSpeed5 -= StepSize;
               case '6':
                   MotorSpeed6 += StepSize;
               case '^':
                   MotorSpeed6 -= StepSize;
Could you try something for me please? Could you change the line:
                case '\"':
to:
                case 34:
and then recompile and see if anything changes. I've seen a stack-dump recently where a mis-matched quote was present in a source file. I'm suspicious of that escaped double quote.
