Problem with lcd
This code samples an analog signal from a guitar, detects its frequency, and displays the results on an LCD. However, the LCD is displaying random stuff instead of printing frequency value despite correct wiring, as it works properly with simpler examples. The issue likely lies within the ADC configuration or interrupt handling affecting the LCD operation.
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//clipping indicator variables
boolean clipping = 0;
//data storage variables
byte newData = 0;
byte prevData = 0;
unsigned int time = 0;    //keeps time and sends vales to store in timer[] occasionally
int timer[10];            //sstorage for timing of events
int slope[10];            //storage for slope of events
unsigned int totalTimer;  //used to calculate period
volatile unsigned int period;      //storage for period of wave
byte index = 0;           //current storage index
volatile float frequency;          //storage for frequency calculations
int maxSlope = 0;         //used to calculate max slope as trigger point
int newSlope;             //storage for incoming slope data
//variables for decided whether you have a match
byte noMatch = 0;   //counts how many non-matches you've received to reset variables if it's been too long
byte slopeTol = 3;  //slope tolerance- adjust this if you need
int timerTol = 10;  //timer tolerance- adjust this if you need
//variables for amp detection
unsigned int ampTimer = 0;
byte maxAmp = 0;
volatile byte checkMaxAmp;
byte ampThreshold = 30;  //raise if you have a very noisy signal
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  pinMode(13, OUTPUT);  //led indicator pin
  pinMode(12, OUTPUT);  //output pin
  cli();  //diable interrupts
  //set up continuous sampling of analog pin 0 at 38.5kHz
  //clear ADCSRA and ADCSRB registers
  ADCSRA = 0;
  ADCSRB = 0;
  ADMUX |= (1 << REFS0);  //set reference voltage
  ADMUX |= (1 << ADLAR);  //left align the ADC value- so we can read highest 8 bits from ADCH register only
  ADCSRA |= (1 << ADPS2) | (1 << ADPS0);  //set ADC clock with 32 prescaler- 16mHz/32=500kHz
  ADCSRA |= (1 << ADATE);                 //enabble auto trigger
  ADCSRA |= (1 << ADIE);                  //enable interrupts when measurement complete
  ADCSRA |= (1 << ADEN);                  //enable ADC
  ADCSRA |= (1 << ADSC);                  //start ADC measurements
  sei();  //enable interrupts
ISR(ADC_vect) {  //when new ADC value ready
  PORTB &= B11101111;                           //set pin 12 low
  prevData = newData;                           //store previous value
  newData = ADCH;                               //get value from A0
  if (prevData < 127 && newData >= 127) {       //if increasing and crossing midpoint
    newSlope = newData - prevData;              //calculate slope
    if (abs(newSlope - maxSlope) < slopeTol) {  //if slopes are ==
      //record new data and reset time
      slope[index] = newSlope;
      timer[index] = time;
      time = 0;
      if (index == 0) {      //new max slope just reset
        PORTB |= B00010000;  //set pin 12 high
        noMatch = 0;
        index++;        //increment index
      } else if (abs(timer[0] - timer[index]) < timerTol && abs(slope[0] - newSlope) < slopeTol) {  //if timer duration and slopes match
        //sum timer values
        totalTimer = 0;
        for (byte i = 0; i < index; i++) {
          totalTimer += timer[i];
        period = totalTimer;  //set period
        //reset new zero index values to compare with
        timer[0] = timer[index];
        slope[0] = slope[index];
        index = 1;           //set index to 1
        noMatch = 0;
      } else {    //crossing midpoint but not match
        if (index > 9) {
          reset();
    } else if (newSlope > maxSlope) {  //if new slope is much larger than max slope
      maxSlope = newSlope;
      time = 0;  //reset clock
      noMatch = 0;
      index = 0;  //reset index
    } else {      //slope not steep enough
      noMatch++;  //increment no match counter
      if (noMatch > 9) {
        reset();
  if (newData == 0 || newData == 1023) {  //if clipping
    PORTB |= B00100000;                   //set pin 13 high- turn on clipping indicator led
    clipping = 1;                         //currently clipping
  time++;  //increment timer at rate of 38.5kHz
  ampTimer++;  //increment amplitude timer
  if (abs(127 - ADCH) > maxAmp) {
    maxAmp = abs(127 - ADCH);
  if (ampTimer == 1000) {
    ampTimer = 0;
    checkMaxAmp = maxAmp;
    maxAmp = 0;
void reset() {   //clea out some variables
  noMatch = 0;   //reset match couner
  maxSlope = 0;  //reset slope
void checkClipping() {   //manage clipping indicator LED
  if (clipping) {        //if currently clipping
    PORTB &= B11011111;  //turn off clipping indicator led
    clipping = 0;
  checkClipping();
  if (checkMaxAmp > ampThreshold) {
    frequency = 38462 / float(period);  //calculate frequency timer rate/period
    lcd.setCursor(0, 1);
    lcd.print(frequency, DEC);  //print results to LCD
    Serial.print(frequency);
    Serial.println(" hz");
  delay(100);  //delete this if you want
  //do other stuff here
Try and use 38462.0 instead. I see a risc for integer math and numbers gretaer then 32767 will overflow or do other strange things.
i tried but it didn't fix the problem
You may have a conflict with the LCD's pin 12 in the ISR of the ADC:
Thanks a lot. That was the problem
