Problem with motors and L298N when using WiFi on ESP8266
Hi, I’m working on a project with an ESP8266 and an L298N.
The goal is to control a car using a game controller. On my computer, I read the controller values and send them via WiFi to the ESP8266, which uses the L298N to drive the motors.
The problem is that the motors move backwards but don’t move forward, and this only happens when WiFi is enabled.
When I test the motors individually, they work fine.
The power supply is two 3.7V batteries in series.
Does anyone know what might be causing this or how to fix it?
#include <ESP8266WiFi.h>
const char* ssid = "*****";
const char* password = "******";
const int in1 = D0;
const int in2 = D3;
const int in3 = D4;
const int in4 = D5;
const int ena = D6;
const int enb = D7;
int vel0 = 255;
int vel1 = 255;
WiFiServer server(80); // Servidor en puerto 80
  WiFi.begin(ssid, password);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(ena, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  pinMode(enb, OUTPUT);
  Serial.print("Conectando");
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi conectado");
  Serial.print("IP: ");
  server.begin();
  WiFiClient client = server.available();
  if (client) {
    String data = "";
    unsigned long timeout = millis();
    while (client.connected() && millis() - timeout < 2000) {
      if (client.available()) {
        char c = client.read();
        if (c == '\n') break; // fin del mensaje
        data += c;
      yield();x
    //Serial.println("Recibido: " + data);
    // Convertir data a int[]
    int action[10]; // Ajusta el tamaño máximo esperado
    int index = 0;
    int start = 0;
    for (int i = 0; i <= data.length(); i++) {
      if (data[i] == ',' || i == data.length()) {
        String val = data.substring(start, i);
        action[index] = val.toInt();
        index++;
        start = i + 1;
    Serial.print(action[0]);
    Serial.print(", ");
    Serial.print(action[1]);
    Serial.print(", ");
    Serial.print(action[2]);
    Serial.print(", ");
    Serial.println(action[3]);
    if (action[0] > 0 && action[2] > 0 || action[1] > 0 && action[3] > 0){
      detener();
      if (action[0] > 0 ){ avanzaL(); } else { detenerL(); }
      if (action[1] > 0 ){ avanzaR(); } else { detenerR(); }
      if (action[2] > 0 ){ reversaL(); } else { detenerL(); }
      if (action[3] > 0 ){ reversaR(); } else { detenerR(); }
void detener(){
  detenerL();
  detenerR();
void avanzaL(){
  digitalWrite(in1, HIGH);
  digitalWrite(in2, LOW);
  digitalWrite(ena, HIGH);
  //Serial.println("AL");
void avanzaR(){
  digitalWrite(in3, HIGH);
  digitalWrite(in4, LOW);
  digitalWrite(enb, HIGH);
  //Serial.println("AR");
void reversaL(){
  digitalWrite(in1, LOW);
  digitalWrite(in2, HIGH);
  analogWrite(ena, vel0);
  //Serial.println("RL");
void reversaR(){
  digitalWrite(in3, LOW);
  digitalWrite(in4, HIGH);
  analogWrite(enb, vel1);
  //Serial.println("RR");
void detenerL(){
  analogWrite(ena, 0);
void detenerR(){
  analogWrite(enb, 0);
Sounds like a pin usage conflict. Perhaps you are trying to use the same pin for the L298 and the WiFi.
So if you simply disconnect ena pin from one motor, the other one works correctly when wifi is enabled?
If so, post details of your wiring, motors and power supply.
Which batteries exactly ? and
So how did you control the motor directions when WiFi was disabled?
So what do you mean by testing the motors individually? Is this just on the bench unconnected from a processor, or is this in code from a processor?
If the former then just reverse the motor’s wires, if the latter then please show the wiring of your circuit as a schematic.
I am assuming that you have kick back diodes on each motor, otherwise that can damage thing if you have not.
