I've tried several available sketches using the I2S audio protocol, for example, for a simple internet radio. None of them work with the Arduino Nano ESP32 processor and the Adafruit MAX98357 audio board. However, when I use another ESP32 processor like the ESP32 WROOM DA, all the sketches work without problems.
Is there something I'm missing in implementing I2S with the Arduino Nano ESP32?
The board I have selected in the IDE is the "Arduino Nano ESP32". When I mouse over this selection a tooltip appears with "arduino:esp32:nano_nora". I will also add that other sketches not using I2S run okay.
I assume that nothing there works out either ?
And it's not a matter of PinNumbering "by Arduino" vs "by GPIO" ?
( Here, someone with a NanoESP32 has posted in 'Hardware' -- cf. people with non-Nano (viz. wroom etc) almost always post in NanoESP32. How to fix this? )
In file included from C:\Users\Owner\Favorites\Electronics\Arduino\ESP32\I2S\Internet Radio\esp32-i2s-simple-radio_1-0.ino\esp32-i2s-simple-radio_1-0.ino.ino:16:
C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\libraries\I2S\src/I2S.h:61:3: error: conflicting declaration 'typedef enum i2s_mode_t i2s_mode_t'
} i2s_mode_t;
In file included from C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13/tools/sdk/esp32s3/include/driver/include/driver/i2s.h:16,
from c:\Users\Owner\Favorites\Electronics\Arduino\libraries\ESP32-audioI2S\src/Audio.h:29,
from C:\Users\Owner\Favorites\Electronics\Arduino\ESP32\I2S\Internet Radio\esp32-i2s-simple-radio_1-0.ino\esp32-i2s-simple-radio_1-0.ino.ino:15:
C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13/tools/sdk/esp32s3/include/hal/include/hal/i2s_types.h:127:3: note: previous declaration as 'typedef enum i2s_mode_t i2s_mode_t'
} i2s_mode_t;
Multiple libraries were found for "SD.h"
Used: C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\libraries\SD
Not used: C:\Users\Owner\AppData\Local\Arduino15\libraries\SD
exit status 1
Read the error msg, it is trying to tell you the problem. It is likely brought on by the migration to 3.x. Just eliminate one of the dupes (yes there is a correct one)
Have you put the NANO-EsP32 into ESP32 mode? If so, are you using the ESP32 numbered pins? You also have to put the board into ESP32 mode.
The GREEN numbers are what you must use.
Ok, those are the NANO pins, if you want the ESP32 pins then the second picture is what you want. Either move the wires to the correct pins, or rename D7, D8, D9 to D4, D5, D6 respectively.
The D7 for the NANO mode is different from the D7 for the ESP32 mode, same for D8 and D9. It would be much easier to use a normal esp32, is there a reason you need this very special NANO-ESP32 board?
I am 99.999% sure the problem is he is using the wrong pins. The sketch compiles and runs fine showing output on Serial. I have ordered the audio amplifier and speakers to prove it's a wiring error. Should be here Monday. He is using the multi-core NANO-ESP32-S3 as I am.
Indeed, you did, but the OP is unable to read or understand and follow directions. I am going to the expense and bother of ordering some hardware I don't need just to prove that it works IF the board is in ESP32 mode and the ESP32 pins are used. I should know by Monday.
