Problem with NewSoftSerial on PORTB
I moved my SoftSerial tx_pin from 6 (PORTD,5) to 11 (PORTB,2). All I get is gibberish on the LCD. Has anybody else had problems with SoftSerial on portb?
This is the craziest thing. I moved the txpin and applied the following piece of code at the same time. I checked the pins are not cross defined.
void resetPot (void)
      pinMode(INC,OUTPUT);
      pinMode(POT_SELECT,OUTPUT);
      pinMode(UD,OUTPUT);
      digitalWrite(INC,HIGH);
      digitalWrite(POT_SELECT,SELECT);
      digitalWrite(UD,DOWN);
      for(char i=0;i++;i<100)
        digitalWrite(INC, HIGH);   // sets the pin on
        //delayMicroseconds(50);     // pauses for 50 microseconds
        digitalWrite(INC, LOW);    // sets the pin off
       // delayMicroseconds(50);     // pauses for 50 microseconds
      digitalWrite(POT_SELECT,HIGH);
      delay(20);
Note I commented the delayMicroseconds(50) statements out. This way the code work. If I include them the gibberish on the LCD is actually a crashed state. Any takers?
If I use delay() it is ok. Any suggestions please?
Can you post all the code, often problems are elsewhere, for example
makes no sense in the above context because "DOWN" is not a standard symbol, maybe it's been defined somewhere else and maybe that definition was incorrect.
Rob
Marius:
Don't know about other crazy things, and can't say whether this contributes to any problems you are experiencing, but the following loop is never entered:
          // Never gets here.  Really.  Never.
Regards,
Dave
AWOL:
Never, ever?
You sure?
Yes.
Regards,
Dave
The second "term" is the termination (continuation, more like) condition. It's zero the first time through the loop, so the loop doesn't do anything. You probably wanted for(char i=0;i<100; i++)
Rob,
Sorry for the long delay. I took some time off.
These are the defines. The rest of the code is a lot and mostly belongs to the party I am writing it for. Don't know if it is right to post it?
// POT
#define POT_SELECT 6
#define INC 1
#define UD 5
// Pot
#define UP 1
#define DOWN 0
#define SELECT 0
#define UNSELECT 1
Dave,
You found the problem. This is what you get when you still sit and code at 2 in the morning.
Thanks gents- sorted out.
