Hey guys ive reached a roadblock and I cant seem to figure out the problem im have(not very good at code).
Anyways what im trying to do is use an HC-SR04 to measure height in a tank and display it on a SSD1306 OLED. My issue is that when I enable my function to get the measurement my OLED screen stays black. If I leave it commented out the display works perfect. I’ve tried it in the main loop and within my display function. What am i doing wrong?
I forgot to add that my “Serial.println(Menus[encoderPos]); Serial.println(TankLevelVal);” inside the OLED function does work and send the text through the serial monitor.
#include <Encoder.h>
#include <NewPing.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define MenuItems 4
//Encoder Pins
static int pinA = 2; // Our first hardware interrupt pin is digital pin 2
static int pinB = 3; // Our second hardware interrupt pin is digital pin 3
volatile byte aFlag = 0; // let's us know when we're expecting a rising edge on pinA to signal that the encoder has arrived at a detent
volatile byte bFlag = 0; // let's us know when we're expecting a rising edge on pinB to signal that the encoder has arrived at a detent (opposite direction to when aFlag is set)
volatile byte encoderPos = 0; //this variable stores our current value of encoder position. Change to int or uin16_t instead of byte if you want to record a larger range than 0-255
volatile byte oldEncPos = 0; //stores the last encoder position value so we can compare to the current reading and see if it has changed (so we know when to print to the serial monitor)
volatile byte reading = 0; //somewhere to store the direct values we read from our interrupt pins before checking to see if we have moved a whole detent
#define EncBTN 4
//Sonar Sensor pins / settings
#define TRIGGER_PIN 5 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 6 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 30 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#define TANK_MAX 8 //Tank depth from sensor in cm when full
#define TANK_MIN 25 //Tank depth from sensor in cm when full
//Setup for OLED
#define OLED_MOSI 9
#define OLED_CLK 10
#define OLED_DC 11
#define OLED_CS 12
#define OLED_RESET 13
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
byte Counter = 0;
byte BTNState = 0;
byte oldBTNState = 0;
float TankLevelVal = 0;
long oldPosition = -999;
int DisplayInterval = 250;
unsigned long previousMillis = 0;
char* Menus[] = {"< Menu >", "<PullShot>", "< Steam >", "<Settings>"};
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
pinMode(EncBTN, INPUT_PULLUP); // enable pull-ups
pinMode(pinA, INPUT_PULLUP); // set pinA as an input, pulled HIGH to the logic voltage (5V or 3.3V for most cases)
pinMode(pinB, INPUT_PULLUP); // set pinB as an input, pulled HIGH to the logic voltage (5V or 3.3V for most cases)
attachInterrupt(0, PinA, RISING); // set an interrupt on PinA, looking for a rising edge signal and executing the "PinA" Interrupt Service Routine (below)
attachInterrupt(1, PinB, RISING); // set an interrupt on PinB, looking for a rising edge signal and executing the "PinB" Interrupt Service Routine (below)
display.begin(); //SSD1306_SWITCHCAPVCC
display.clearDisplay();
Serial.println("starting");
TankLevel() ; //Get Tank Level
Serial.println("...");
if (oldEncPos != encoderPos) {
oldEncPos = encoderPos;
// ButtonStatus(); // Check for user inputs
//TankLevel() ; //Gets tank level in percent
OLEDDisplay();
// Fuction calls
void OLEDDisplay() {
Counter++;
if (Counter ==40){
// TankLevel() ;
Counter = 0;
if (currentMillis - previousMillis >= DisplayInterval) {
display.setCursor(0, 0); display.setTextColor(WHITE); display.setTextSize(2);
display.print(Menus[encoderPos]);
display.setTextColor(WHITE); display.setTextSize(1);
display.print('\n'); display.print('\n'); display.print("Tank level: "); display.print(TankLevelVal); display.print("%");
display.display();
void TankLevel() {
int Reading[3];
float AvgReading;
for (int i = 0; i <= 3; i++) {
unsigned long x = millis();
Reading[i] = sonar.ping_cm(); // Send ping, get distance in cm and print result (0 = outside set distance range)
while (millis() - x < 30) { // Wait 30ms between pings 29ms is the min
AvgReading = (Reading[1] + Reading[2] + Reading[3]) / 3 ; // Store Average result
TankLevelVal = (AvgReading / (TANK_MIN - TANK_MAX)) * 100 ; //Convert avg to percent
TankLevelVal = 100 - TankLevelVal ;
if (TankLevelVal < 0) {
TankLevelVal = 0;
if (TankLevelVal > 100) {
TankLevelVal = 100;
void PinA() {
cli(); //stop interrupts happening before we read pin values
reading = PIND & 0xC; // read all eight pin values then strip away all but pinA and pinB's values
if (reading == B00001100 && aFlag) { //check that we have both pins at detent (HIGH) and that we are expecting detent on this pin's rising edge
encoderPos --; //decrement the encoder's position count
if (encoderPos == 255) {
encoderPos = 0;
bFlag = 0; //reset flags for the next turn
aFlag = 0; //reset flags for the next turn
else if (reading == B00000100) bFlag = 1; //signal that we're expecting pinB to signal the transition to detent from free rotation
sei(); //restart interrupts
void PinB() {
reading = PIND & 0xC; //read all eight pin values then strip away all but pinA and pinB's values
if (reading == B00001100 && bFlag) { //check that we have both pins at detent (HIGH) and that we are expecting detent on this pin's rising edge
encoderPos ++; //increment the encoder's position count
if (encoderPos == 4) {
encoderPos = 3;
else if (reading == B00001000) aFlag = 1; //signal that we're expecting pinA to signal the transition to detent from free rotation
void ButtonStatus() {
unsigned long y = millis();
unsigned long z = 0;
while (digitalRead(EncBTN) == 0) {
y = millis();
z = y - x;
if (z < 50) {
BTNState = 0;
if (z > 50) {
BTNState = 1;
if (z > 2000) {
BTNState = 2;
if (BTNState != oldBTNState) {
oldBTNState = BTNState;
Serial.println(BTNState);
