problem with serial input
i'm trying to send a PWM signal to an led, through serial monitor, the LED lights up but the brightness doesn't follow the signal
int byteRead;
int led=9;
  pinMode(led,OUTPUT);
  if (Serial.available())
       byteRead = Serial.read();
       Serial.write(byteRead);
       analogWrite(led,byteRead);
When you send data to Arduino over the serial port, it arrives as a stream of ASCII numbers, therefore Arduino can't understand what you want these numbers to mean. It's a bit complicated (at least for me) to convert this, but I got some pieces of code from a tutorial by Nick Gammon and managed to do it. Here's the code with a few comments
const unsigned int max_input = 8;
byte brightness;
int ledPin = 9;
  pinMode(ledPin, OUTPUT);
  static char input_line [max_input]; // buffer to hold your data
  static unsigned int input_pos = 0; // index for your buffer
  if(Serial.available()){
    char inByte = Serial.read();
    switch(inByte){
      case '\n': // terminating new line character
        input_line[input_pos] = 0;
        brightness = (input_line[0] - '0') * 100 + (input_line[1] - '0') * 10 + (input_line[2] - '0');
        // the previous line of code converts the ASCII stream of characters to a byte
        analogWrite(ledPin, brightness);
        Serial.println(brightness); // check if you receive what you give
        input_pos = 0; //reset buffer for next time
      case '\r': // ignore carriage return
      default:
        if(input_pos < (max_input - 1)) // if buffer is not full, keep of adding
          input_line[input_pos++] = inByte;
So, if you send the number 100, Arduino will receive 49 48 48 (49 is ASCII for 1 and 48 is ASCII for 0). The line that converts that data is multiplying the first number by 100 (after it subtracts ASCII 0, which is '0'), the second by 10 (after subtracting '0') and leaves the third intact. Mind that when sending values less than 100 you'll have to prepend a zero (e.g. 050 for 50). Note that on the serial monitor you have to set the correct baud rate and sending the New Line.
Maybe there's a simpler way to do this, but I don't know any..
ok thanks a lot, I can't understand the code at all, but it works :grin:
