Problem with Serial Monitor on Arduino R4 Minima
Hi all,
I know this has been asked before, but I have tried a number of things which have been suggested in other posts in the forum.
I am having difficulty in getting the serial monitor to communicate with the Arduino IDE. I am using Version 2.21 and Windows 10.
The Arduino is detected in Device Manager :-
But every time I try and open the serial monitor, I just get a message saying that it cannot open the port - Port Monitor Error: Command Open Failed.
When it is trying to open the port, it gives the message
I have tried different cables, but this didn't make much difference.
I have also tried connecting a Nano to the same computer, but I get a similar message, but I couldn't install the drivers (this pc is limited by IT so I cannot install drivers or software)
I have managed to install Arduino V1 on a stand alone XP machine and the Nano worked. But I couldn't find the divers for the Uno R4.
I have also tried pressing the reset button twice and uploading the blink program which made zero difference.
I can upload to the Uno R4, but it wont communicate
So any suggestions?
Is the board faulty - the R4 Minima?
Just an update to this.
I have tried a brand new Uno R3 board, but when I try to connect to the Serial Monitor, I get a similar message -
"Port Monitor Error: Command 'open' failed: The Filename, directory name, or volume label syntax is incorrect"
The drivers in Device Manager for the Uno R3 are installed ok.
When I try and upload code to the R3, I get the message-
avrdude: ser_open(): can't open device "\.\COM5": The filename, directory name, or volume label syntax is incorrect.
Failed uploading: uploading error: exit status 1
I have tried a different cable and it is the same.
I have set the board in the IDE to Arduino Uno and Comm. Port 5.
I also tried using the Uno R3 on a Windows XP machine. The drivers install ok, and I can connect to the Serial Monitor ok. The IDE version on XP I am using is 1.8.18.
Any ideas please?
