Hello,
I have problem with keypad and joystick library, what am i doing is button box with keypad and two on - off - on toggles. In code below i would like to implement toggle so if button 52 and 53 are released it will press joystick button 56, same with 54 and 55 then press joystick button 57.
//MicroUSBButtonBox by Les O'Reilly
//Arduino IDE 1.6.6 (or above) !
//This Makes a ZERO Axis with 56 Button USB Controller (Game pad)
//Keypad will configure the Buttons 0-55
//A3,A2,A1,A0 Are the Row Pins for the Keypad D0-D10,D14-D16 are the Column Pins
//Button 0 wires as A3+D16 Where A3 is Row and D13 is Column, Button 13 - A3+D0
//Button 14 wires as A2+D16 ...Button 27 A2+D0
//Button 28 wires as A1+D16...Button 41 A1+D0
//Button 42 wires as A0+D16....Button 55 A0+D0
#include <Keypad.h>
#include <Joystick.h>
#define NUMBUTTONS 56
#define NUMROWS 4
#define NUMCOLS 14
//define the symbols on the buttons of the keypads
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3,4,5,6,7,8,9,10,11,12,13},
{14,15,16,17,18,19,20,21,22,23,24,25,26,27},
{28,29,20,31,32,33,34,35,36,37,38,39,40,41},
{42,43,44,45,46,47,48,49,50,51,52,53,54,55},
byte rowPins[NUMROWS] = {21,20,19,18}; //connect to the row pinouts of the keypad
byte colPins[NUMCOLS] = {16,15,14,10,9,8,7,6,5,4,3,2,1,0}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
//initialize an Joystick with 56 buttons;
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, 60, 0,
false, false, false, false, false, false,
false, false, false, false, false);
Joystick.begin();
CheckAllButtons();
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i = 0; i < LIST_MAX; i++)
if ( buttbx.key[i].stateChanged )
if(i >= 1 && i <= 56) {
// do toggle things
else {
// do non-toggle things
switch (buttbx.key[i].kstate)
case HOLD:
Joystick.setButton(56, 0);
case IDLE:
case RELEASED:
Joystick.setButton(56, 1);
switch (buttbx.key[i].kstate) {
case PRESSED:
case HOLD:
Joystick.setButton(buttbx.key[i].kchar, 1);
delay(0);
case RELEASED:
case IDLE:
Joystick.setButton(buttbx.key[i].kchar, 0);
delay(0);
